Question about Nokia 1100
Charging problem! Nokia 1100 type: RH-18 No response to charger if i will insert a charger. I tried replacing a new charging terminal but it is still. Is it a hardware related problem? Please share me your solutions and troubleshooting techniques with regards to this problem. Thank you!.........
  • 304 Answers
The easiest way to test if the jack has a bad connection is to use a meter and an old nokia cord. Cut the plug off the end of the old nokia cord and strip back the 2 wires just long enough to touch them with the leads of the meter (1/4"). Set the meter to measure ohms and touch the 2 leads of the meter together and the meter should Zero out. Now touch the leads of the meter to the exposed leads of the plug. Have the test plug inserted in the phone of course. If you do not get a reading on the meter there is an open circuit. The phone will have to be disassembled and you must solder the jacks connectors back to the main circuit board. Many times these jacks dislocate from being droppedor hanking the plug out too rough or on an angle. I'm sure you already tested the battery and made sure the contacts were clean and free of obstructions. It only takes 1 small particle to keep the contacts from mateing properly. If non of this is the problem the main circuit card itself may be cracked. Visually inspect it. If any cracks are found use an exacto knife and scrape the coating off down to the copper traces themselves then carefully solder single strands of copper wire bridging the gaps in the cracked cicuit board. Then apply a layer of epoxy to the damaged section of the board to prevent further flexing and lenghtening of the crack in the board. If you have any question or need professional help feel free to ask me. [email protected] Hope this points you in the right direction.
George
Posted on Aug 04, 2008
SOURCE:
Tracfone will not charge
try dismantling the phone, keep it disassembled for sumtime... assemble again.. try recharging..
if it still doesnt work, have your charging port checked with an electronics mechanics..
Dec 11, 2009 | Nokia 1100
FORGET MY SECURITY CODE
hi there,
IMEI: 357077006216748
Security Mastercode: 3773206630
Good Luck!!!
neo
Jan 17, 2009 | Nokia 1100
Forgot my nokia 1100 security code
In case you forgot the original SECURITY CODE, then try 1234 or 12345.If you have given a new SECURITY CODE, the only solution is to go to a service centre and get retrieved.
Jan 10, 2009 | Nokia 1100
Nokia 1100 RH-18
take the phone and have the lcd replaced
Sep 08, 2008 | Nokia 1100
Charging problem!..no any response to a nokia charger.
change the charger pin it might be loose conatct
Aug 04, 2008 | Nokia 1100
Nokia 1100 Logo
71 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
