Question about Welding Tools
What gauge exstention cord do i use for a lincoln weld pak 100?
  • 407 Answers
Hi:
Weld pak 100 is a 120 volt unit, you will be ok with a gage 12.
Most 120V commercial extensions out there are 14 gage, if you want to buy one, choose no longer than 25 ft long.
With a 12 gage you can go to 50 ft. with no problems.
If this was useful to you please vote. Thanks.
Posted on Mar 27, 2011
Lincoln weld pak 100 welder no dc volage to wire feed motor
If the cooling fan motor comes on and the the machine “clicks” when you close the trigger, use your index finger and push in on the on/off switch, if the feed motor turns replace the on/off switch
Dec 05, 2017 | Lincoln Welding Tools
Lincoln weld pak 100, no heat penatration on the D setting
I believe your voltage control rheostat (potentiometer) must be worn out. Check your owner's manual for the part number and request it, it's not expensive and it is an easy part to replace. If you are doing that would be a good idea to do the same for your speed control rheostat.
Or clean them if you can, take off all the carbon particles that it build up with the time.
Mar 20, 2014 | Welding Tools
Weld-pak 100 Hd Problem
There is a reset button located in the wire feed spool compartment,
check to see it stays in when pushed. It is a safety when the machine
overheats, it normally resets when machine cools off. If it is working properly I suggest contacting Lincoln Electric Dealer for service.
Mar 03, 2012 | Lincoln Welding Tools
Where can I get a gas diffuser for a Lincoln Electric Weld Pak HD wire feed welder?
Gas diffusers are sold at any welding store, look up praxair site for your nearest location. The part number you are looking for is: TWE-35-50 about 6.00 bucks or less.
Jun 13, 2011 | Lincoln Electric Welding Tools
My weld pak 100 will not feed the wire
you Ned to check if the voltage selector is in good condition if not replaced.
Jan 03, 2011 | Lincoln Electric Century Portable Plasma...
I have a Lincoln Weld Pak 100 that was working fine. I shut down the machine though and when I came back to it about 5 hours later the wire feed motor wouldn't turn anymore. Has anybody else had the same...
Check the voltage at the wire feed motor when the trigger is pulled.
I had a Weld Pak 100 that with 0 volts at the wire feed motor, and the problem wound up being that 2 of the big power (stud) diodes were shorted.
Feb 26, 2010 | Welding Tools
Lincoln Weld Pak 100 arc welder troubleshooting
There can be a switch that makes the wire electrically "dead" so it can be fed through the liner. Also suitcase style welders have a sensor wire with a clamp that must be connected for the arc to be able to be struck.
Nov 22, 2009 | Welding Tools
My lincoln welder lost its heat penetration
It only produces 100amps. You can only weld thinner metal 3/16" comfortably. Any thicker will resuld in less/no penetration.
Mar 17, 2009 | Welding Tools
Welding Tools Logo
303 people viewed this question
Top Welding Tools Experts
Bill Boyd
Marvin
Marvin
Are you a Welding Tool Expert? Answer questions, earn points and help others
