Question about Mitsubishi VS-45609 TV
I have a mitsubishi vs 45609 with what appears to be a convergence problem. Using the menu convergence settings everything is correct. So it appears that the color guns are out of allignment but I'm not sure that it has individual guns. So how do I correct this issue.
  • Mitsubishi Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changedI have a mitsubishi vs - 578ba6c.jpg/>578ba6c.jpg
TV
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Posted on Apr 15, 2011
Colors do not line up to each other
I would replace your convergence chips and see if it fixes the problems. I know some tv's also have a menu for fixing the convergence. Try that first.
Oct 22, 2012 | Mitsubishi VS-45609 TV
My Mitsibushi VS-45609 tv/ convergence and picture size acts up once in a while
Try to download the repair manual to your set from internet. It sounds that you have to get into its service mode adjustments. All details are in the repair manual.
Apr 21, 2012 | Mitsubishi VS-45609 TV
The picture looks like 3D on my mitsubishi projected tv
You may be having a convergence problem. Convergence focuses the different color guns of the tv. This is usually a way to set the convergence via your menu. If this doesn't work, you may need new IC chips. This is fairly expensive. It cost me around $300 last time I had it done and it was hard to find anyone to do it. Good luck!
Mar 07, 2010 | Mitsubishi VS-45609 TV
Convergence problem again
I think you might need to do an advanced convergence. this is done threw the service menu. it is complicated and time consuming. however there is still a possibility that the green convergence circuit has failed. there is very little green correction since it is in the middle. most sets don't even have a green convergence circuit. however this one does. these pico fuses are "tiny yellow" look like a small resistor. chech for b+ on all 3 conv.ic's.
Jan 04, 2010 | Mitsubishi VS-45609 TV
Mitsubishi VS 45609 Blue Shadow On TV Picture
you need to replace the convergence IC STK393-110 you can get it as well as picture installation instructions as well as free online tech support at the link I posted very good prices
http://servicemanuals.vstore.ca/
May 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Vs-45609
I think you convergence ic are bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 06, 2008 | Mitsubishi VS-45609 TV
VS-45609 TV Problem:
convergence ic bad
Nov 18, 2007 | Mitsubishi VS-45609 TV
Convergence board
It wouldn't be the entire convergence board, you more than likely have a bad convergence STK-IC. Replacing the IC will take a good bit of knowledge and training as far as electronic repair is concerned, plus a complete convergence set up. In other words, unless your certified, you need to contact a tech. The convergence set up alone has driven men to drink.....
Aug 28, 2006 | Mitsubishi VS-45609 TV
Mitsubishi VS-45609 TV Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
