Question about GPS
My satnav is saying f3008 map data is missing and am having difficulty to solve the error.
3 Suggested Answers
  • 13433 Answers
SOURCE: Managed to wipe entire software
1st lets try updateing the firmware on your gps
Here are instructions for updateing the firmware
http://www.blaupunkt.com/uk/download/guide_luccasoft_0685os1131_en.pdf
And then you can find the firmware itself from here (EUROPE)
http://www.blaupunkt.com/uk/downloads_3_6.asp
Posted on Apr 28, 2008
SOURCE: how to amend the map data on the satnav from mapsource
ues mapinstaller and add them to the removable card
select the removable card when it asks to find device,
Posted on Apr 09, 2010
My garmin keeps saying no data available everytime you hit anything on the Where To screen. How do i fix that?
There's 3 possibilities;
1. The map is unselected (which is the most likely)
2. The map is locked or
3. The software is out of date and needs to be upgraded.
You'll find the solutions to 1 and 2 at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing. There's more information there than you'll need so to select the map if it's unselected go to paragraph 5.
If the map is locked start at paragraph 2.
If the software needs updating download and install WEBUPDATER from http://www8.garmin.com/support/collection.jsp?product=999-99999-27. to your computer.
Connect your satnav to your computer with the mini USB lead and run WEBUPDATER. It will check for updates and install them to your satnav.
I hope this solves your problem.
Apr 29, 2011 | Garmin Nuvi 265W GPS Receiver
Tip
No Detailed Maps Found That Support Routing
A lot of people have looked for solutions to the message "No detailed maps that support routing" which can appear on Garmin Nuvi satnavs.
This solution can also be used when the message doesn't appear but no maps are loaded. When no maps are loaded try the instructions in paragraph 5 below Selecting Maps on your Garmin Satnav
If that doesn't solve your problem the maps may be locked. In this case return to paragraph 2 below and follow the instructions to the end
(This solution is for both PC and MAC users. Follow the instructions only for whichever you use).
The "No Detailed Maps Found That Support Routing" message may appear on your Garmin nuvi satnav for the following reasons:
  • The Satnav is missing it's unlock code
  • The maps on the Satnav have been disabled
1. To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to Paragraph 5. below Selecting Maps on your Garmin Satnav
2. To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it, connect the satnav to your computer and go to www.garmin.com. Select your country from the dropdown list and click "Register your garmin device". Follow the prompts. You'll be asked to create a username and password. Keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
3. Retrieving your unlock codes:
  • Log into your myGarmin account
  • Select Manage Maps
  • Select Details
  • The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  • Plug your Garmin device into the USB port
  • Double-Click on My Computer or Computer located on the desktop
  • Right-Click on the Garmin or nuvi drive
  • Click Explore
  • Double-Click on the Garmin folder
  • Right-Click in a blank space in this window
  • Move your mouse over the word New
  • Select Text Document
  • Press Enter / Return on your keyboard
  • Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  • Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  • Select File
  • Select Save As
  • Change the Save As Type to All Files
  • Type gmapprom.unl in all lower-case letters for the File name
  • Select Save
  • Close the Notepad window
  • Delete the New Text Document file
  • Disconnect the Satnav from your computer
Creating an unlock code file for Mac:
  • Open the TextEdit application located in the Applications folder on the Mac HD
  • Click Format
  • Select Make Plain Text
  • Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  • Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  • Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
4. If you have a second maps you may also need to unlock it e.g. if the first map is USA and second is EUROPE this may also need to be unlocked
  • Click Explore
  • Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  • Select File
  • Select Save As
  • Type gmapprom1.unl in all lower-case letters for the File name
  • Select Save
5. Selecting maps on your Garmin Satnav:
  • Touch the wrench icon on the Where to/View map screen
  • Touch Settings (or Locale on some models)
  • Touch Map
  • Touch Map Info
  • Press the checkbox next to the maps to be selected on the satnav
    A tick will appear in the box. The map is now selected.
on Sep 28, 2010 | GPS
Tip
How to update your Garmin Satnav maps
To update your garmin satnav map you must have your satnav registered. If it's already registered skip to paragraph 2 below.
1. To Register your Garmin Satnav
  • Connecty our satnav to your computer and go to www.garmin.com
  • Select your country
  • Click on Register your garmin product
  • Follow the prompts
Note you will be asked to create a username and password. Write them down and keep them safe as you'll need them again anytime you want to update your maps
2. To update your maps
  • Connect your satnav to your computer and go to www.garmin.com
  • Click on myGarmin and log in
  • Click on myMaps.
  • If there's an update available it will be shown beside the name of your map.
  • Click on Get Update and follow the prompts.
Note map files are large so you'll need a broadband connection to download them. If you don't have broadband you'll have an option to buy the update on DVD.
  1. If The Map Is Too Large To Install To Your Satnav
    When you go to download the map by default it tries to download it to the satnav i.e. not the SD/Mini SD card. You need to change this. When the website recognises the satnav follow the prompts. It will give you 3 options for the download destination.
    • Download to satnav,
    • Download to Computer and Satnav or
    • Download to computer.
    As the website is updated, from time to time, the method of selecting the download destination changes. Sometimes it shows up as a drop box with a drop-down arrow showing your satnav name. Click the drop-down arrow and select the option to download the map to your computer. Sometimes it shows the 3 options as text headings with tick boxes beside them and you get to tick the option you want. Whichever way it shows up select the option to download the map to your computer. This will install it on your computer's hard drive.
  2. After it's downloaded the map should begin to install automatically. (If not double click on it and it will). It should be allowed to install to your satnav first as Garmin will not allow it to install to your SD/Mini SD card unless it's first partly installed to the satnav. This is so they can ensure that it's installed to the correct satnav.
  3. To Install The Full Map To Your SD/Mini SD Card
    To install the map to your SD/Mini SD card, insert the card into the card slot of your satnav and connect it to the computer. Click the windows start button on your computer. Then click the GARMIN progam and then MAPINSTALL. This runs the map installation program. When the install program finds your satnav and you get the option to install the map there again by default. Click on the drop-down arrow, where it shows your satnav as the destination, and select the drive letter of the SD/Mini SD card. This will be different to the drive letter for your satnav. The map will then be installed to your SD/Mini SD card.
  4. Problems With Older Nuvi Satnavs Reading Maps On 4 Gb Or Higher SD Cards
    When you install a map to an SD card older nuvi satnavs can have difficulty getting the satnav to read it. It will install to it without problem but when you try to operate the satnav then it cannot load the map and will close down the satnav unless you remove the SD card. The reason for this is that 4 Gb and higher cards are SDHC which operate differently from SD. To solve this problem you should use a class 2 SDHC card, which is the slowest type available. You can identify the class by the small figure on the card. It will be either 2, 4, 6, 8, or 10. Before you install the map format the card as described below. Also use webinstaller to check that you have the latest version of operating software on your satnav.
  5. Format the SD card with "Panasonic SD Formatter" available from http://panasonic.jp/support/global/cs/sd/download/sd_formatter20.html rather than the standard windows format function. Select the fast format option and be sure you have selected the drive letter of your SDHC card as it will format your hard drive or indeed your satnav just as easily if you select one of them by mistake.
  6. To update your software or check that you have the latest version, you can download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
    Connect your satnav to the computer and run the program. It will search for any updates to your software.
Class 2 SDHC cards are harder to find in shops today as they are being replaced by the faster classes. They are however still easily available on ebay if you can't find one in the shops.
on Aug 17, 2010 | GPS
Hello how can I update my Carmin nuvi 660 and download the map of new zealand ? thank you
Details of how to update your garmin satnav are at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
To get a new map of NZ you need to have your satnav registered. Details of how to do so are at the above link also. When you're registered go to www.garmin.com
  • Click on the myGarmin tab
  • Log in using your username and password
  • Click on the myMaps tab
There you'll see the map installed on your satnav. On the left hand side of the screen you'll see in blue writing a link saying "Shop for new maps" and then on "View additional maps for this product"
Scroll down as far as the map of NZ and select it. Follow the prompts.
If the map you already have on your satnav is not NZ and you want to save that too it's unlikely that both will fit on your satnav. If this is the case follow the instructions, at the above link, under the heading If the map is too large to install on your satnav for downloading to your computer and installing from your computer to your memory card rather than the satnav. Be advised maps installed on memory cards will not always work on garmin nuvi satnavs particularly if the memory card is larger than 2 Gb. Please read the article at the link above before buying.
Feb 26, 2011 | Garmin Nuvi 660 GPS Receiver
My maps are gone how do I fix it
The map may be unselected. To select it;
  • Press TOOLS (the spanner icon) in the bottom right corner of the WHERE TO and VIEW MAP screen
  • Press SETTINGS (or LOCALE on models that don't have a settings icon)
  • Press MAPS and then MAP INFO at the bottom of the screen
This should show you the maps installed on your satnav. There should be a tick beside the map name if it's selected. If not press the map name and the tick will appear. This should solve the problem.
If this does not solve the problem the map may be locked or deleted. If the map is locked it should say so at the map name. If there's no map name then the map may be deleted.
You can get details on how to unlock your map at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
If the map has been deleted you may be able to download it again from the garmin website depending on how old it is. Generally you can download the map for about 6 months after it was first installed.
  • To download the map again go to www.garmin.com
  • Click on the myGarmin tab at the top of the page.
  • If you haven't already registered your satnav do so on this page by clicking "Register your garmin product" and follow the prompts
  • When you're registered log in using your username and password
  • Click on the myMaps tab at the top of the page
  • Your satnav name will be on the left hand side of the page and your map name in the centre. On the right it will either say "No update available" or "Update available"
  • If there's an update available downloading and installing it will solve the problem but you'll have to pay for it. Alternatively click on where it says "Details" in blue under your map name
  • This brings you to a screen where, if the map is not too old, you get the option to download it again. Click on "Download again" and follow the prompts to reinstall it.
Jan 25, 2011 | Garmin nuvi 265WT Car GPS Receiver
My garmin nuvi 1300 keeps saying "no map data available" I'm a truck driver and really need assistance asap..
There's a solution to your problem at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
The article deals with all possible reasons for there being no map data available but if your satnav is working other than that it may be just that the map is not selected. If you can get into the menus first try selecting the map by
pressing TOOLS
then SETTINGS or LOCALE on models that don't have a settings menu
Press MAP and then at the bottom of the screen press MAP INFO
Your map name should be there and a box with a tick beside the name.
If the box is not ticked press on the map name and it will cause the tick to appear. This might solve the problem. If not the map is probably locked. You'll find details of how to unlock the map at the above link.
Jan 06, 2011 | Garmin nuvi 1300 Car GPS Receiver
I went in and removed all my pictures from the unit and all languages except english. Now my map is gone, poi screen is blank and when I try to set a destination it only shows the interstate no city...
Check if your map is selected.
  • Press TOOLS the spanner icon on the WHERE TO and VIEW MAP page
  • Press SETTINGS the spanner icon (Or LOCALE on some models, the blue icon)
  • Press MAPS
  • Press MAP INFO on the bottom centre of the screen
Your map name should be there with a tick beside it. If the tick is not there press the map name and it will appear. This may solve the problem.
If the map is not there you'll need to download it again. If you've got a garmin account log into myGarmin. If not you'll need to register your satnav first. To register it
  • Connect the satnav to your computer and go to www.garmin.com.
  • Select your country from the dropdown list and click "Register your garmin device".
  • Follow the prompts.
  • You'll be asked to create a username and password. Keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
Once you've registered you'll be able to log into myGarmin. When you're logged in click on the myMaps tab. There you'll see the name of the map on your satnav. Under the map name you should see a link in small blue writing DETAILS.
Click on DETAILS and it should give you an option to download the map again. Download it to your computer or direct to the satnav and it should solve the problem. If you download to the computer use MAPINSTALL, which will be installed into a GARMIN folder in your programs list, to install the map to your satnav.
Nov 30, 2010 | Garmin nuvi 750 GPS Receiver
I've bought a Garmin Nuvi 215w. The gps does not display all the road names on the map. Is there any way i can update the firmware?
I don't think updating the firmware will solve the problem however if you want to try you can update the firmware by connecting your satnav to the computer and downloading webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 When you have it set up it will automatically check for the latest version of software for your satnav. I don't think that will solve your problem though. The satnav will only show road names that are on the map.
Before trying to update the software try this solution first. On the satnav press Tools, then Settings, then Map. Under Map Detail press whatever it says and you'll get a list of options. Press Most. This will show the most map details and will show any roadnames that are on the map.
Jul 30, 2010 | Garmin nuvi 215 GPS Receiver
My garming says no detailed maps found that support routing what can i do to fixed
Press Tools, then press Settings, then press Map, then press Map Info. There should be a tick beside the map name. If not press the map name and a tick will appear. The problem should then be solved.
If that doesn't solve the problem it may be because the map is locked. If so go to www.garmin.com and if the satnav is registered click on My Garmin, then on Maps where you'll find the unlock code. If the satnav is not registered you'll need to connect it to the computer and register it first.
Jul 30, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Software update cant be found for my medion p4410 can anyone help pls!!!!!!!!!!!!!!
If you have gone to the manufacturers web site and have found no update for your unit then one is not available for it yet. Keep checking back about once a month and you will/might finally find one.
Jun 11, 2010 | Medion Go Pal P4410 GPS Receiver
GPS Logo
60 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
