Question about Kodak Cameras
I have a Kodak V1073 and the zoom control does not work can this be resolved quickly as I am visiting UK from Aus and need the camera - what local shop can I take it to. It is only 3 months old.
    Master:
    Sergeant:
  • 398 Answers
Go to Kodak.com and click on support.
Posted on Aug 04, 2008
SOURCE:
The zoom on my Kodak V1073 seems to fluctuate and won't return to wide angle when pressing down on toggle. Half of my pictures are fuzzy even on smart photo.
I have the same exact problem. It started doing that on my camera about 2 months after I had. For 10 mega pixels the picture quality really isn't that great, nor is the quality of the camera itself.
Feb 20, 2010 | Kodak EasyShare V1073 Digital Camera
Will not zoom needs a new button where can I buy just the zoom button
KODAK doesn' sell any spare parts to any of their models.
An out of warranty repair for this fault is about 25 pounds.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 15, 2010 | Kodak EasyShare V1073 Digital Camera
Device driver was not successfully installed. Why?
I?m not sure if you?re fault code is showing on the computer, Easy Share Software, or the camera itself. Therefor I will list 2 possible solutions: If the fault message is on the LCD on the camera: There is no firmware available online for this camera model. Therefor you do need to set up a "repair" with KODAK directly. An Out of Warranty repair for this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price. In order to arrange your repair/Trade up: Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490 If this fault message is on your computer, Easy Share Software: Please do a Clean Install on the software: Please follow the instructions: Uninstall Easy Share software: Select Start > Settings > Control Panel > Add / Remove Programs. For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs. Select Kodak Easy Share software. Select Remove (or select Change, and then select Remove). Run the Clear utility: Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear Click the Download button, and then follow the on-screen prompts. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Dec 06, 2009 | Kodak EasyShare V1073 Digital Camera
The LCD screen freezes and turns all white then cuts off when taking pictures.
was the camera drop?
are you using the recommended battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7004
Here are the steps you need to do
-Try to use your camera without Memory card
-Turn on camera and press the zoom button make sure that the lens will move properly., If camera hungs it means the camera lens is the problem
-If youturn on the camera then it will just display white screen and shuts off when taking picture Charged the battery for 4hrs
-after charging the battery and still camera freeze it means your camera needs of service please call kodak toll free 1 800 235 6325., Gudluck!
Oct 31, 2009 | Kodak EasyShare V1073 Digital Camera
My camera shuts off when I my zoom is nearly halfway through
Make sure your batter is fully charged, and is not bad. This kind of reaction can happen with a weak battery or partly charged.
If that is not it, then the camera needs repair.
Sep 27, 2009 | Kodak EasyShare V1073 Digital Camera
Camera shuts off when I try to go into digital zoom.
Here are the steps:
1. Make sure you will install a new or fully charged
battery/batteries into your camera.
2.Remove the battery/batteries and the memory card from
your camera
3.Reinstall the battery/batteries into your camera
4. Without the memory card,turn on your camera.
5. Try to use the digital zoom again.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Regards,
Neerak21
Sep 22, 2009 | Kodak EasyShare V1073 Digital Camera
When I zoom in my camera shuts off
Mine was doing the same thing and after chatting with Kodak Tech Support to no avail I wiped the lens barrel (the rings that slide in and out) with a paper towel dampened with a little alcohol and it started working again. There's a sensor that shuts down the camera if the lens can't move freely and apparently a film can build up on the rings that causes just enough friction to make it turn off. I then wiped it with a tiny bit of WD40 on the towel and it's working perfectly. Be very careful if you try this to not get anything on the glass lens itself, and don't use enough to soak the towel, just barely dampen it.
Aug 26, 2009 | Kodak EasyShare V1073 Digital Camera
Need to change language
Your manual is located at this link. It should be able to tell you how to change the language back.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00839/V1073_V1273_UG_GLB_en.pdf
Jul 25, 2009 | Kodak EasyShare V1073 Digital Camera
No sound on video with Kodak v1073 dig. camera
Uninstall the quictime player from your OS then obtain a new copy. www.apple.com
Jul 06, 2009 | Kodak EasyShare V1073 Digital Camera
My v1073 turns off right after i turn it on. i dont get a pic or anything.
Make sure the camera is fully charged. It will shut off if it can not pull enough power off the battery. If you have a dock that you use to recharge it or a wall plug-in, plug the camera into it. Push the power button. Having it plugged in by-passes the battery. It should turn on when it is docked or plugged into the wall. If plugging or docking the camera does not turn the camera on, you have an issue that Kodak will need to resolve. Don't forget to have proof of purchase and check to see if your warranty is still valid. Hope that helps.
Jan 16, 2009 | Kodak EasyShare V1073 Digital Camera
Cameras Logo
76 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
