Question about Vehicle Parts & Accessories
I have a 1999 ford tarus and i cant get it to start i think its the fuel pump but what else could cause this problem?
  • 176 Answers
It can be a number of different things, if your check engine light is on then it would help tremendously if you could read the code and post it for me.
You're right though, a bad fuel pump can cause the vehicle not to start. So will a bad battery, starter, if the key lost it's immobilizer code, etc etc.
I will be happy to further assist you if you were interested in trying to trouble shoot the issue. Goodluck
Posted on Mar 27, 2011
Replaces fuel filter, but 2006 Ford tarus still starts somestimes and not others
even though you replaced the fuel filter , it still passes dirt through the filtration system , so what i recommend is 2cups of acetone 1 cup for 1/2 a tank of fuel and if its full then two cups , this solution will clean your fuel injectors , if you use those advertised chemicals that clean fuel injector , those have a chemical varnish which causes to gum up ,but i assure you acetone is pure alcohol and it will not harm your engine , you will see an improvement in your fuel milage as well .
Mar 21, 2014 | 2006 Ford Taurus
2004 ford tarus wont start but cranks over... fuel pump or filter?
It could be a fuel system concern. I would check the fuel pressure with a gauge. You can check the fuel pump by sound.. if its coming on. Have someone turn the key to the run postion and listen near the fuel tank to hear a slight whine noise that will last about 3 sec. If you hear a noise..thats a good sign that power is getting to the pump...but the pump still could be faulty. If you hear nothing..its probably the pump. If you think its the fuel filter...just replace it...that's the best way to see if its the filter.
Nov 25, 2012 | 2004 Ford Taurus
I have a 1999 f350 that will turn over, but wont start. i cannot smell any diesel. think it is a problem concerning fuel pump. checked power distribution box fuse. Is ok. is there an actual fuse...
The fuel injection in this engine is digital electronically controlled, to start the diagnosis you must have the Powertrain electronic control module (PCM for short) scanned to see if any fault info exist in its memory. The system is just way to complicated to diagnose at home, you need any special tools.
Jan 20, 2012 | 1999 Ford F350 Regular Cab
It turns over but will not start we have a 1999 ford tarus 24v
Hello! Do you have spark (bright blue)? Pull a plug wire and push a long screwdriver into the tip...Locate screwdriver near a ground...Turn key to start and watch for spark...Also when you turn the key to start do you hear the fuel pump clicking?...Send a comment on these two items...Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Sep 27, 2011 | 1999 Ford Taurus
My ford tarus/1999 'serve engine"
The blinking engine light indicates your problems are severe and could cause more damage to the engine if not corrected. You will need to have a diagnostic scan run to retrieve the trouble codes that are causing the light to come on & flash. From those codes, repairs needed can be determined.
I hope this helps.
Sep 23, 2011 | 1999 Ford Taurus
1999 Taurus: Do you have to drain gas tank to change fuel pump ...
No. Just drop the tank.Easier if you remove most of the fuel
May 17, 2010 | 1999 Ford Taurus
2002 ford tarus cranks but wont start. 32000 miles. I did not drive much during the last 6 months. I started it and it ran fine drove to a neighbors house when i tried to start it cranked but would not...
First, verify that there is gas in the vehicle. Next, listen for the pump to energize when you turn the ignition switch to the on position. If you dont hear anything, check the fuel pump relay. Swap it with another one next to it, they are often the same part. If it still doesn't energize, its most likely the pump thats failed. If you hear the pump energize, then the pump pressure needs to be checked. A fuel gauge needs to be connected under the hood on the fuel rail to read system pressure. Verify that its at factory specs. If not, replace the pump.
Apr 21, 2010 | 1999 Ford Taurus
97 Tarus wont start
recheck spark by putting a plug into one of the plug wires and place on valve cover, crank engine and see saprk in that plug. check fuel pressure during cranking to verify fuel supply. If you have no fuel pressure check fuses and fuel pump relay, in fuse box and power distribution box under the hood. If all are good check for power at the fuel pump connector with the key in start position, in run position the power will only be there for about 5 seconds, you are correct with fuel and spark it should run, let me know what you find
May 21, 2009 | 1996 Ford Taurus
Vehicle Parts & Accessories Logo
54 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
