Question about HP Wireless Optical Mouse
I have an HP wireless mouse, and when connected the cursor lags horribly. What can I do to fix it?
  • 569 Answers
Try changing the batteries in the mouse.
Posted on Mar 27, 2011
How do I connect a microsoft wireless moblie mouse 3000 to my laptop?
Press the button on the back of the mouse to free the battery cover on top.
Remove the battery cover and put the supplied AA battery into the mouse.
Replace the battery cover.
Insert the wireless USB dongle into a USB port on the laptop or desktop computer.
Move the mouse and watch your computer screen.
Confirm that the mouse is connected by making the cursor move.
Hope this helps
Sep 26, 2012 | Microsoft Wireless Mobile Mouse 3000
The "mouse" on my Hp Pavillion laptop stopped working last night---it will not move the cursor. Can I fix this and if so, please explain in basic layman's terms so I can understand the instructions?
Is this a wireless mouse, or a wired one? If it is wired, there could be 1) so much dirt between the ball and the contacts inside the mouse housing that it won't move (usually there is a way to remove the ball and use tweezers to try and remove all the accumulated stuff); 2) the connection (plug) could have worked loose. Pull the plug out, reinsert it, and reboot. 3) the cord could have a bend or been steppedon and have a poor or no connection. A new mouse is in order. If it is a wireless mouse, batteries are the probable culprit. We put new rechargeable batteries in less than a week ago in ours, and even though our mouse goes in a charger when we are not using it, it would not work until I put new rechargeable batteries in. Remember - even new things can be bad.
Aug 13, 2010 | HP Computers & Internet
I have an hp wireless mouse, and it doesn´t work!! Tried everything...
Wireless device like the mouse needs a wireless connectivity to a computer like a bluetooth or a wireless receiver. Make sure that your mouse batteries are all working and the wireless receiver is properly plug into the USB(Universal Serial Bus) port of the computer. The wireless receiver don't need battery so you don't have to worry about it. The two both have a push button, press both buttons to activate the connection. Wireless connections has limit in distance so make sure that you are not too far away from the receiver while using the mouse and that is 9 feet or 2.7 meters so keep that in mind. When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Hope this could help you a lot..:-) Thanks..
Dec 27, 2009 | HP Wireless Optical Mouse
Hp wireless mouse not working
HP wireless mouse may not work due to improper connection of the receiver. If unknowingly you connect the receiver to a different port, then it may cause serious issue with HP wireless mouse.
If the connected port is corrupt and if the port is experiencing any problem, then the wireless mouse may not work properly.
In order to resolve this issue, you need to repair the port.
Get more information to fix HP Wireless Mouse Not Working . Hope this information helps you.
Oct 29, 2009 | HP Wireless Optical Mouse
Why wireless mouse doesn't move the cursor?
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.and use the mouse pad .
Sep 21, 2009 | Computers & Internet
The cursor on my laser wireless mouse won't move
You need to sync the mouse with the USB receiver. They'll be a similar button on the receiver. Push both at the same time.
Apr 07, 2009 | HP Wireless Optical Mouse
Mouse doesn't work
LOOK FOR A BUTTON TO RESET THE MOUSE AND THE USB CONNECT SHOULD ALSO HAVE A RESET SWITCH ON THE USB CONNECT YOU NEED TO PUSH BOTH AT THE SAME IME SO THE CAN GET INSINK OR THE CHANNEL TO SET. SOME TIMES THE MOUSE HAS TO BE TAKEN APART AND CLEANED JUST LIKE THE OLD MOUSE BALL ONE, AND RESET THE MOUSE SETTING IN CONTROL PANAL, UPDATE DRIVE MAY ALSO HELP IF THERE IS ANY NEW FIXS
ROD
PS SOME TIMES THE LEAD TO THE BATTARY CONNECTION NEED THE THE SPRING PULLED OUT A LITTLE OR THE OTHER END WITH METAL TAB ON IT NEEDS PULLED OUT BECAUSE THE PLAY IN THE BATTERY COMPARTMENT IS LOOSE AND THE CONNECTION IS INTERMITTING A VOLTAGE CHANGE AND CAUSES THE MOUSE TO LOOSE ITS SIGNAL TO THE TRANSMITTER OR SET FREQANCES.
ROD
Feb 09, 2009 | HP Wireless Optical Mouse
Jumping mouse cursor
I think some where in the cable there is a broken wire, it is inside the cable, cause there is a certain position that it work properly. You can also test it by tyring other mouse if the problem still the same.
Oct 16, 2008 | HP Wireless Optical Mouse
Microsoft Wireless Optical Comfort Desktop and Mouse combo Freezing Prob.'s
have you tried pressing the connect button on the reciever then on the mouse so it picks it back up again?
May 01, 2008 | Microsoft Multimedia Optical...
HP Wireless Optical Mouse Logo
375 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
