Question about RCA RS2028 CD Shelf System
The cd player will not work and the the screen say reset, but there is no reset button . i found the manual online and it said there is a reset button on the back but i can't seem to find it. Where is it at?
Trying to reset dvd pioneer 270 out of progressive mode and nothing is working can hear sound but no picture
I just had that same problem with my Pioneer dvd player. I found the online manual for my dvd player. For restoring the default settings simply turn off your dvd player, then press the STOP button on the front panel of your dvd player while turning the dvd player on again.
Sep 05, 2011 | Pioneer DV-270-S DVD Player
Phillips mp3 player froze up on the gogear screen.
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Feb 26, 2009 | Philips Sport Personal CD/MP3 Player
Discs stuck inside CD Player. Screen says ''Reading.''
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
Nov 15, 2008 | Cambridge Soundworks 740I CD Player
Kenwood CD player KDC-MP825
Some units have a reset button, have you tried to reset the unit?
Feb 10, 2008 | Kenwood Sirius KDC-MP825 CD Player
Changed settings
Press and hold the Stop button on the DVD player itself it should reset back to factory settings
Sep 08, 2007 | Cyberhome CH-DVD 300 DVD Player
Error #'s on screen 37-67 at boot up
I have a unit with the same problem, did you ever get anywhere with this fault ?? Regards, Stuart
Aug 21, 2006 | Denon DN-961FA CD Player
CD do not eject
I have the same prob with mine right now and thats why I came here was to find the manual. In the manual it states that that when something like this happens you need to hold two buttons for a few seconds and what it does is it resets the cpu in the deck. I had to do it before and yes I was kind of leary of the solution also but IT WORKED!! Now I'll have to dig before posting this otherwise I didnt just create a common solution I talked about it. Ok while holding power/ATT press eject for more than two seconds, and it says careful not to drop the cd~~~DAAA Or to reset the unit: While holding SEL (select) press power/ATT for more than two seconds and that will reset the unit to factory defaults. And this was actually from my owners manual of which I found...
May 26, 2006 | Jwin JCCD200 CD Player
RCA RS2028 CD Shelf System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
