Question about Maytag Neptune MAH5500B Front Load Washer
My maytag washing machine will not spin dry, can u please help, what can b the cause
  • Maytag Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Mar 27, 2011
SOURCE: maytag lat8840baw washing machine.
my maytag lat8840 will not fill with water on any cycle...wants to spin and rinse when I turn it to those points
Posted on Jan 28, 2009
SOURCE: Hi, I have a Maytag
Several items can cause no spin or slow spin. I'm assuming the motor runs during spin and the water all drains out. A worn or damaged belt can cause your problem. Always replace the drive belt and pump belt at the same time.
Check for smooth and non binding motion of the motor in it's carriage.
A failing bearing (either tub bearing or spin bearing) will restrict tub motion in spin.
A garment in between the inner and outer tub will also restrict tub spin performance.
Posted on Apr 28, 2009
heatman101
  • 43501 Answers
SOURCE: Does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 20, 2010
  • 3 Answers
SOURCE: maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Posted on Jan 08, 2011
  • 6277 Answers
SOURCE: My washing machine is Maytag Performa. I have the
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 06, 2011
Testimonial: "Thank you for your speedy reply. "
Maytag Bravos wash machine agitates during wash cycle, and drains, but does not spin
hi JJ.
Most Frequent Causes for Washer won't spin. The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity
this link might help you out as well.
maytag washing machine not spinning Google Search
Dec 11, 2017 | Maytag Washing Machines
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Maytag washing machine does not spin completely dry model # LA846 have repaced water pump and main drive belt but still does not spin completely dry
First be sure that your drain hose is not kinked.If your hose is not kinked then I would suggest that you buy the roller kit for the motor plate and replace the rollers.
Apr 29, 2011 | Maytag Washing Machines
Wont spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 05, 2011 | Maytag Washing Machines
My maytag atlantis top load washer doesn't spin dry. The belt and bottom spin, not the tub.
Sorry to read about your problem, I hope this helps you out.
you must have a defective transmission. you will need to call a service company
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer won't shift to rapid spin dry (only slow back & forth)
Hi Jim, you issue could be caused by a couple either one of a of the following,
1) Draining problem, cant empty the water from the machine within the prescribed time limit - preventing the spin programme to commence. check pump filter is clear and waste water is pumping from the end of the waste hose, the hose itself could be blocked with limescale and detergent residue.
2) Unbalanced load, most machines wont spin 1 item, its a safety thing, if a machine spins with one heavy item it puts the drum out of balance resulting in excessive drum movement possibly damaging the inside of the machine and put indue stress on the bearings. Try putting it on a spin cycle with no clothes in
Unbalanced load detection can also be caused by a faulty motor tacho, this usaually positioned at the rear of the motor, this sends an electrical signal to the programmer telling when it is 'Safe' to spin. There also the posibility that the programmer is not reading the tacho signal or misinterpriting it.
May 20, 2009 | Maytag Washing Machines
Hi, I have a Maytag Washing Machine. Model Number: LAT7793ABV It seems to wash fine, but when it gets to the "Spin" part of the wash, sometimes it doesn't spin, and if it does spin, the clothes...
Apr 28, 2009 | Washing Machines
Maytag Dependable Care Plus LAT8824
I think that you mean "Agitate" some of the time that you write "Spin" Yes?
If I understand you correctly, you have no agitation during the "wash" cycle, this is almost certainly a corroded agitator shaft seized up in the transmission.
Oct 05, 2017 | Maytag Dependable Care LAT9706
Maytag Neptune MAH5500B Front Load Washer Logo
125 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
