Question about ATI FireGL X1, (128 MB) AGP Graphic Card
I have a Dell PC with an ATI Fire GL X! video card connected to wide screen monitor. Aspect ratio seems wrong This is very noticable in Autocad where circles appear as elipses and squares as rectangles etc.I cannot find how to correct this - please help
  • psycada Mar 27, 2011
    What operating system are you using?
  • David Petry Mar 27, 2011
    Is you resoluiion correct?
  • 11,800 Answers
You need to change the screens resolution to the one of the monitor: right click on an empty part of the desktop, click Properties, click Setting then move the slider till the native resolution of the monitor is selected. Now click Apply and OK.
Posted on Apr 18, 2011
Widen the screen on Westinghouse tv
Screens are controlled by ASPECT RATIO.
Monitors can have 4:3 16:9 and 16:10 ratios.
You are doing 1 of 3 things.
  1. You have a regular monitor and the tv and are duplicating the screen.
  2. You have a regular monitor and the TV and are extending the screen.
  3. You have just the tv connected.
Your video card has to have a screen resolution that meets the tv's ratio to have the tv take the full screen.
If your configuration is 1. the tv will only match the monitor resolution, so if you change the screen resolution, you may get bars on the monitor, and the tv will go wide screen.
if your configuration is 2. the tv is controlled independently and you can select it to change its resolution to an appropriate aspect resolution. *this requires that your video card gives you the correct screen resolution for your tv. not all displays will work.
If your configuration is 3. the tv is the only resolution that is being pushed and just adjust the resolution til the screen is filled in.
To adjust the screen resolution, right click on the desktop where there isnt an icon and select either Properties (windows xp) or Screen Resolution (windows vista, 7 and 8).
if you have 2 screens press the identify button and it will put a number on each screen. click the appropriate screen and go to the resolution dropdown below. Change, apply and if it doesn't look right, revert and try a different setting. if you try them all and it won't take up the full screen, then the video card can't push the video resolution your monitor wants.
Sep 30, 2014 | Computers & Internet
I accidently hit recall on my monitor settings. I now have a smaller veiwing screen with black edges
You didn't say which OS you're using but it sounds like you've changed the aspect ratio of your video signal. Different screen resolutions have somewhat different aspect ratios. The aspect ratio indicates the ratio of the number of pixels of width to those of height. For example: my video driver offers a resolution of 1280 x 960 or 1280 x 720 which would give screen aspect ratios of 1280/960 = 1.33 :1 and 1280/720 = 1.77 : 1. The latter would produce a narrower image. You can compensate somewhat by increasing your horizontal sweep voltage with your monitor menu. A better solution would be to select a resolution that more closely matches your monitor's screen size.
Aug 10, 2011 | Dell D1028L 17" CRT Monitor
I connected my media center PC to my new Sanyo DP50740 50" Plasma Television using the PC input on the back of the television. The instructions say that it supports 1360X768 with a 16:9 aspect ration...
No,13060 resolutions will not support by some tv correctly,will shift whole picture about to 6 inches to the right.That why,must use the PC Control panel to adjust to 1024 for the video to center.For the wide aspect 16:9 ratio,just find another aspect ratio to for expandsion to fit the entire screen.
Feb 05, 2011 | Sanyo Televison & Video
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
When darwing in AutoCad, circles appear as eggs!
It is because your monitor is not getting the correct navtive resolution from your PC, the aspect ratio is not correct, the PC video output should be set to 1680x1050 @60Hz for this monitor. This monitor 16:10, not 16:9 like other 16:9 monitor.
Mar 21, 2010 | AOC 2219S1 22 in. LCD TV
Are Dell monitors not compatible with older HP Pavilion Computer? I tried to connect my HP CPU to a Dell monitor and it will not recognize it at all.
It shouldn't make any difference which monitor you are connecting to any computer. In fact, I am running a 19" HP Flat Panel on my Dell Dimension 2400 right now. It is NOT a wide screen monitor as the Dell built in graphics card will not support the RESOLUTION RATIO required for the wide screen. Check what setting is "native resolution" for your monitor and see if your graphics card will support it. If not, using your old monitor, try different resolution settings. Right click on your desk top, click on properties and that should bring up the display properties box. Try a lower setting as larger settings are the ones that will give you a black screen. It will probably give you a smaller picture on your old monitor, or perhaps smaller or larger icons on the desk top. Accept the new settings, turn off your computer and switch monitors, and turn your computer back on. If you get a picture, but it does not fill the whole screen or the icons seem too large or small, then go back into properties from the desktop and try a different resolution ratio until the picture seems correct.
Jul 18, 2009 | Dell Computers & Internet
NEW WIDESCREEN TOOOOOO WIDE
Use menu button on monitor.
select menu.
select image setting
select aspect ratio
change aspect ratio to "Fit"
Jun 21, 2009 | Hannspree HW191D LCD Monitor
Hannspree 22" wide monitor won't recognize hdmi to dvi cable connection
First, fire up monitor in VGA. You can then use the monitor menu to select the hdmi instead of vga. Restart andf it should work Ok.
Jul 27, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Monitor image size
There is nothing wrong with the monitor, the issue is that the web page you are looking at is designed for a lower resolution than you LCD is set for (Web pages are normally designed for 800 x 600 or 1024 x 768) you like have a wide aspect ratio monitor.
As I sit here writing this on my 12" wide aspect LCD I have a 2" wide white space on each side of my screen due to my 1280 x 800 aspect ratio.
The issue is one of WEB PAGE DESIGN not the fault of your computer video settings. The web page is written using page frames and fixed aspect ration settings to ensure that the page displays properly regardless of monitor type.
If you had a high end LCD (WUXGA 1920 x 1200), the web page would fill the upper left 1/4 of the screen.
If you lower the resolution of your display, then you'll have fuzzy icons and text, so essentially, get used to it.
Eventually, wed design will catch up with current display technology.
Jul 24, 2008 | Computers & Internet
Aspect ratio changing on ATI radeon hd2400 pro
My wifes DELL has a F key with a blue icon that does that
take a look at the BLUE symbols and see if there is one showing a rectangle with either blue bars on each side or similar
When she presses it the screen changes to a 4:3 aspect with black bars on each side
Jul 03, 2008 | Computers & Internet
ATI FireGL X1, (128 MB) AGP Graphic Card Logo
81 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
