Question about Cisco Catalyst 6500 WS-X6724-SFP (WSX6724SFPRF) Expansion Module
WS-X6724-SFP problem how to anable WS-X6724-SFP module in 6509-E switch the following error is observed C6KPWR-SP-4-DISABLED: power to module in slot 1 set off
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
Serch on :Fiberstore.com .all kinds of sfp transceiver module in Fiberstore .Tt is a fiber optic products online store. you can access to fiber optic transceiver directly.
Posted on Mar 16, 2012
    New Friend:
    Teacher:
  • 17 Answers
Check out the SFP
Maybe you should use other sfp transceiver or new sfp.
Posted on Feb 24, 2012
  • 39 Answers
Try this:
hw-module slot 1 start
ZXR
Posted on Aug 04, 2008
SOURCE:
Does 6509-31 sawzall have thermal overloads
No the 6509 does not have a thermal overload.
Start by checking the brushes & brush springs then test the switch & cord
It is possible you burnt the armature out but brushes, switch, or cord is more likely.
Mar 07, 2015 | MILWAUKEE ELECTRIC TOOL CORP Milwaukee...
What is the difference between WS-C2960X-24TS-L and WS-C2960X-24TS-LL?
The main difference between WS-C2960X-24TS-L and WS-C2960X-24TS-LL as below:
WS-C2960X-24TS-L 4 SFP Uplink, WS-C2960X-24TS-LL 2 SFP Uplink.
WS-C2960X-24TS-L supports FlexStack-Plus stacking while WS-C2960X-24TS-L does not.
WS-C2960X-24TS-L with LAN Base feature set, WS-C2960X-24TS-LL with Lan Lite feature set.
I hope it can help you.
WS C2960X 24TS
Mar 05, 2015 | Cisco Computers & Internet
Huawei GE optical port with 1310 SFP module can connect to Cisco 3750X GE ports with GLC-LH-SMD?
The Cisco switch will probably err-disable the port when you plug it in. The workaround is to add these commands:
Switch(config)#service unsupported-transciever
Switch(config)#no errdisable detect cause gbic-invalid
It'll either work or it won't!
Feb 11, 2015 | Cisco Computers & Internet
I forgot ip address and password and want to factory reset
Connect the console cable, open a connection to the serial port via a utility such as PuTTY, and do the following:
1) Enter the user name "recover" and password "recover" to place your unit in password recovery mode. The unit will remain in password recovery mode for 30 seconds max.
2) Perform a hard reset by removing power, waiting 10 seconds, and then re-applying power.
3) Once the switch has rebooted, enter a new password for the "admin" user account.
4) Enter enable to leave password recovery enabled, or enter disable to turn it off. You are now logged in as the default "admin" user.
Note: If password recovery has been disabled, the only way to recover access is to return the switch to 3com.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
I just installed a sup730-3b to the 6509 chasis with 3000W power supply. System powers up normally but after a while (approximately 10 minutes later) the system shuts down itself. Then i changed the chasis...
It sounds like you computer is shutting itself off because the cpu is overheating. I would suggest making sure the thermal grease between the cpu and heat sink/fan is replaced and if the heat sink/fan isn't the best consider purchasing a new one.
Feb 28, 2011 | Cisco 7604 Chas 4-slot 2 SUP720-3B 2 PS
PROBLEM IN 6509 SWITCH.
you need to upgrade the dram of the unit or the processor board
Oct 22, 2009 | Cisco Catalyst 6509
Open Questions:
See all Cisco Catalyst 6500 WS-X6724-SFP (WSX6724SFPRF) Questions
Cisco Catalyst 6500 WS-X6724-SFP (WSX6724SFPRF) Expansion Module Logo
809 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
