Question about Garmin GPS
My interior speaker not working how do i fix it
  • 391 Answers
Hello there are 6 tabs holding the case together, 2on each side. once the screws are out, i just run my finger nail allong the seem to unset them. but if you have a small plastic flat head screw driver this will also open the tabs goodluck
Posted on Mar 27, 2011
How do i hook up my sony vgp-sp1 speakers and subwoofer to my pc
Opening speakers will irreparably damage it. The interior volume is calculated to provide optimum performance. For this reason they are essentially sealed with tape and are not meant to be opened.
Apr 02, 2014 | Sony Audio Players & Recorders
'96 maxima with no tail light, no radio power, sometimes the car's interior light does not work too. Would like to try and fix it myself. Your help will be highly appreciated.
Taillights: Check 7.5A fuse 14 in the fuse block
Radio: Check 7.5A fuse 40 and 10A fuse 21 in the hybrid electric control unit. If you have the midline radio with separate amplifier, check 15A fuse 25 as well. If you have the premium radio, check 15A fuse 22 rather than 25. The wiring may have gotten mangled during the earlier speaker installation.
Jan 17, 2014 | Nissan Maxima Cars & Trucks
Left back interior speaker will not work before or after being changed
soud like a broken wire or wire has a bare spot and is goin to ground replace wire should fix problem. take new wire tape good to old wire then pull it should fallow old wire in to place.
Oct 04, 2013 | 2003 Ford Taurus
My center speaker connection is faulty?
There should be some fault to internal output circuit.
May 11, 2013 | Philips Audio Players & Recorders
When key is in ignation and truck is off bell wont ring, also interior lights dont go on when opening door, then somtimer when driving it saya driver door ajar and interior lights go on and automatic door...
you have a serious electric/wiring problem. if you recently did some do-it-yourself work (like installing speakers) you may have messed something up while inside the "car's guts". I suggest you take it to a mechanic qualified to fix electrical wiring problems. I know it's the expensive choice, but it's only a matter of time until your windows won't go up.
Oct 04, 2009 | 2003 Chevrolet Avalanche
Peugeot 307 speaker changing
There is no way around with out removinf the panel, u ll have to remove then only u can gain access to the fixing screws to replace the speaker.
For your Sunvaley...
You have to remove all the below listed to remove the door pad
  • The switch block bolt
  • The switch block
  • The exterior mirror fasteners interior cover
  • The interior opening control trim
  • The 3 fasteners (screws) 3 on the trim
  • Slowly pull out the trim without excessive force, to avoid brekage of the clips inside
Apr 25, 2009 | Peugeot 307BR Wrist Watch
I am about to put my 6x9 speakers in my car. i would like a little advice if possible. it will not be a tricky job as all the connections have been done (by a car garage). all i need to do is put the...
Typically the best way would be to remove the interior trim piece from the shelf. Then have a friend hold the MDF board up from inside the trunk. Then run either screws or bolts/nuts through from the interior all the way through the MDF. Replace interior trim piece and it should be held in tight.
Another less intrusive way would be to use a strong adhesive, such as "Liquid Nails" to secure the MDF to the bottom of the shelf. You'd need to figure a way to hold the MDF to the bottom of the shelf for quite awhile (8-24 hours) to make sure their is good adhesion.
Jan 31, 2009 | Car Audio & Video
Interior speakers cut out when the volume is turned up
You may have speakers of an incorrect impedance attached to the unit since the problem occurs when audio signal level is increased and the current goes up.The unit is shutting down to prevent damage. I would check the speaker connections and make sure that the speakers impedance are matched for the unit you are using.
Sep 03, 2007 | Eclipse EA3422 Car Audio Amplifier
GPS Logo
19 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
