Question about Kenmore Dishwashers
Dishwasher: Kenmore ultra wash sensor quiet guard plus. I'm in a rental so I don't have the manual or model number. A few days ago it just wouldn't start the wash cycle. When you press normal wash then start the no heat dry and lock lights flash every other second or so but nothing happens. I can hit the cancel button and it will make sounds like its trying to drain, and after about 5 minutes stops. I've done the heated wash/ no heat dry sequence to try to reset but no luck. Also tried turning the lock off, wasn't the issue. Can any one help?
SOURCE: Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
My guess is that the foil that the buttons are mounted to is defective.  The control module "reads" the buttons that are pushed by the fact that the resistance between two pins on the circuitboard becomes zero ie. your pushing the button shorts out two pins.  the foil could have moistire damage or the resiistance of the tracks could be too high.  Solution for both would be to replace the control panel button foil.
Posted on Oct 17, 2007
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 4 Answers
SOURCE: quiet guard 3 dishwaher
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
SOURCE: Kenmore ultra wash quiet guard 3 dishwasher problem
The sequence of "Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses)" worked for us. Many thanks!
Posted on Oct 14, 2008
  • 117 Answers
SOURCE: The IRONY of my Quiet Guard!! SO LOUD!!!!
Yes the wash arm can be removed to get to the sump area. Take the model number for your dishwasher and enter it into a site like partselect.com. There you can get a blown up diagram of the components that need to be removed to get to the cause of the grind noise. Usually a seed or some other hard object has found its way down there.
Posted on Feb 26, 2009
Why is my kenmore ultra wash quiet guard blinking clean?
You can go to Kenmore's website, list your machine model and the
problem and you can get an answer. Usually you have to re-program
those machines every 400 hours. Hope this helps
Jul 06, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
I see the pressure tower for a Kenmore Ultra Wash Quiet Guard dishwasher laying in the bottom of the dishwasher. I've just rented the house and haven't used the dishwasher yet. Does this pie
No, the designers put it in there for a reason; it won't work as well without it, as it would with it in. Probably the mounting tabs are broken or sprung. A new tower isn't very expensive. You can probably get one from SearsPartsDirect.com, RepairClinic.com, EasyApplianceParts.com, or AppliancePartsPros.com.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 28, 2012 | Kenmore Dishwashers
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Suddenly stopped working - won't run on any cycle.
First check the electrical supply. I have seen dozens of dishwashers which did not have the hot wire connected tightly enough (inside the connection box behind the lower panel). Sometimes the loose wire caused the breaker to blow. If you have control lights but the dishwasher will not start it could be a bad door latch saftey switch. $10 part, cheap. Hope this helps, Ken
Apr 24, 2009 | Dishwashers
Feb 06, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Help
wow that could be a tough one there is no door lock on a dishwasher only a door latch what happens when you depress the door latch and can you send me a model number so i can pull up the blue prints and see if we can figure out a way to open it try pushing on the door and depressing the latch at the same time let me know what happens
Jan 10, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
That looks more like the serial number. Check again to confirm the model number.
Sep 09, 2007 | Kenmore 17252 Free-standing Dishwasher
Dishwashers Logo
106 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
