Question about Memorex MLT3221 32 in. LCD TV
BACK OF THE TV IS SMOKING - Memorex MLT3221 32 in. LCD TV
The TV started smoking. Thought it might be dust. doesn't appear to be.
Your tv is burning part of it's electronics. Turn it off and unplug it. Either take it to a repair ship or replace it.
Mar 27, 2015 | Philips 47PFL3603D/F7 LCD HDTV, 47...
Tv smoking
Hi, Sounds like power board issue. Take to repair man.
Good luck.
Feb 11, 2014 | Dynex "- 42"" Class - LED - 1080p - 60Hz -...
Tv smoking
if you say you heard a hissing sound that can be fly back cap or the eht leaking electrolytic capacitors can over heat due to lack of discharge as the are about to open or "bust" best way check for dry joints or any physical damage.
Aug 13, 2013 | Dynex Computers & Internet
My 47PFl3603d\27 47 in. LCD TV is smoking from the right top side of the tv vent i need to know whats wrong with it
If you don't know about electronics you should probably take this to a repair shop. If you do and you plan on fixing this yourself then [unplug] take the back off the unit and have a look. It should be rather obvious what was smoking. The board may look burned in the area. You already know which side it was from. If it was a cap it will look puffed. The solder on the bottom may have cracks from the heat. Maybe a resistor burned up. If you find out which component burned up, I might suggest buying two replacement parts because, odds are, there's a reason that one fried. That part will be up to you to figure out. Maybe a transistor or a diode shorted out somewhere. You'll have to trace the circuit back through and test out other components. Good luck.
May 01, 2011 | Philips 47PFL7403D 47 in. LCD TV
Screen went black smoke coming from back tv is 2007 according to back sticker still have sound
Smoke = overheating = big short = big failure of a part.
Unplug the tv immediately - you don't want t set your house on fire - and call a repaiman. Since the tv has been smoking then the damage will be extensive - a lot of parts, even entire boards, have been damaged. Te repair will be costly.
Oct 05, 2010 | Element Electronics FLX3210 32 in. LCD TV
Phillips magnavox smokes
Replace the bad cap:
Capacitor C506 = 680pF 2kv = 483512247584 part number
Buy at tritronics by credit card: 800-638-3328
Oct 24, 2006 | Philips Magnavox 27MS343S 27" TV
Phillips tv smokes
Im sorry I do not have a schematic on this set, now the RCA I do that is under the heading. If you get a schematic from http://www.servicemanuals.net and send me a copy I will be more then happy to assist you with this repair.
Oct 23, 2006 | RCA 32F531T 32" TV
Memorex MLT3221 32 in. LCD TV Logo
52 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
