Question about Air Tools & Compressors
I need a pressure regulator valve for a air ace air compressor. the air compressor is a 5 peak hp, the tank is a 26 gallon verticle tank. the item number is TD258120VL. it is a 120 volt/60 HZ, 90 psi. The serial number on the tank is 109590 and the date of manufacture is 200406
5 Suggested Answers
emissionwiz
  • 79865 Answers
SOURCE: 80 psi and it stops
adjust the pressure regulator
Posted on Jun 17, 2009
compman66
  • 169 Answers
SOURCE: Hi, I bought a used Air Ace air compressor. 5 Peak
send me a photo of the compressor and if there are any model numbers or serial numbers and I will see if I can identify the pump for you. my e-mail is steve@morrismachineservicesllc.com
Posted on Jan 15, 2010
Testimonial: "I will get that info over the weekend and sent it to your e-mail Thanks"
SOURCE: Need new pressure regulator for Campbell Hausfeld
Friend had some pressure regulators and one of them fit. It is also a step up from a direct replacement OEM part. Thank you for your responce to my question.
Posted on Feb 01, 2010
  • 54 Answers
SOURCE: air compressor starts up and
Any idea of HP rating? It doesn't take much compressor to trip a regular 15A breaker.
Posted on Apr 02, 2011
Have mod.# wL651004aj put new piston and ring kit in still does not build air pressure nee help
I would suggest checking the valves . Make sure they are good,no trash ,seating properly. other items to look at include, head gasket,installed correctly? air filter plugged or inlet blocked with something
Aug 08, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Can an air crompressor check valve be cleaned
Only on very rare occasions can a tank check valve be cleaned and still work. The main reason is air pressure is usually high enough inside the tank that when the check valve closes after the pump turns off it usually damages the valve or seat just enough that a leak forms. It is extremely hard to fix a valve or seat so they will seal up again. Without your specific model number I can't tell you which part number you need but most check valves cost $17 to $25 for these types of compressors.
May 04, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Compressor will only build pressure to 75 psi and stop and compressor keeps running what could be wrong
If you can hear air bleeding off through the air filter when you turn it off then the check valve has failed on the compressor discharge to tank line and cannot overcome the tank pressure. If there is no air coming out through the air filter than the intake and dischare valves have become weak or are broken/not seating. Post your findings, I wil see if i can help I worked on compressors for 5+ years
Jan 19, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Hi, I bought a used Air Ace air compressor. 5 Peak HP, 26 gallon tank. I need a manual for this and can't find one anywhere. Thanks
Jan 14, 2010 | Air Tools & Compressors
How do I tighten the pipe on to the air regulator and the husky 26 gallon tank at the same time? they all need to be turned the same way, I do not understand
This can be a tricky dominoe affect depending whats in the way when you make a complete revolution while turning. Take everything off. If possible screw the pipe into the regulator first, then the pipe and regulator into the tank. If you are not getting the desired postion or alignment when you tighten it, then you will need to apply a few layers of teflon around the thread to achieve proper location.
Dec 05, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a Husky model Y6010 air compressor.
First remove the valve using probably about a 1/2" wrench but make sure there is no pressure in the tank before you do so. check the cone and seal by loosening the valve by hand and check for debris. If there is no debris then the problem is either the pressure relief valve or weak pressure regulator but may also be a bad piston seal if it is a direct drive unit.
Apr 28, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
25 gallon air compressor wont shut off,changed air regulator
You have a valve plate problem . It could be a slipped "o" ring to a bad reed valve. There are rebuild kits for that purpose. The kits include a valve plate assembly. It covers all the bases. When you look at this area pay attention to the partitions of the head gasket/"o"ring. You may avoid the cost of the kit.
Feb 25, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
