Question about Dishwashers
Low water pressure; not enough water gets to the dishwasher
  • 1,531 Answers
This could be caused by a bad water valve.restricted water lines,bad float switch cutting off to early.
you will need to check the water line for any kinks or restrictions and maybe change the water inlet valve.
Posted on Mar 27, 2011
Water pressure in dishwasher low
Failed pump or clogged lines ?
Jun 25, 2012 | GE GSD2000J Dishwasher
Model LD 12AW2 not drawing water displaying 1E error
Hi afarugia,
The IE error you are seeing means Inlet Error, this shows because your dishwasher is not getting enough water through in a specific time frame - Please check the following:
- Is the Inlet hose kinked in any way? (This could lead to low water pressure to the solenoid) Straighten it.
- Is the Inlet hose filter (Found when unscrewing the hose form the inlet on the machine) dirty? Clean it.
- Is the tap completely open? (Low pressure)
- Has your home gone under any plumbing alterations? (This could have also caused low water pressure - Too little water)
If all of these come back OK, and it still gives the same problem, I'd suggest replacing the inlet valve (Found on the opposite side of the inlet pipe - inside your Dishwasher), could also be a pressure switch (Found at the bottom of your Dishwasher - accessible from the bottom).
This should solve any problems.
Kind Regards :-)
Jedemeyer1
* If you found this solution helpful - please rate it
Jul 10, 2011 | LG Dishwashers
Gets a 1E code. already checked water is on
Hi shadyron11,
Kind Regards :-)
Jedemeyer1
Jul 08, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
Displaying code IE
Hi jakkirker,
Kind Regards :-)
Jedemeyer1
Jun 15, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
My lg ld 1403w1 dishwasher fills with water and then error code I.E appears have bailed out water and tried it three times same result
Hi june1245,
I.E means Inlet Error, this shows because your dishwasher is not getting enough water through in a specific time frame (varies on model) - Make sure of the following first:
- Is the Inlet hose kinked in any way? (This could lead to low water pressure to the solenoid) Un-kink it.
Kind Regards :-)
Jedemeyer1
Jun 06, 2011 | LG Dishwashers
Dishes in top rack don't clean
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 05, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Water pump presure is low
Obstruction I would say. check connection from supply, hose not folded or whatever.
Apr 14, 2009 | LG LDF6810 Built-in Dishwasher
Sprayer arm is not spinning, water comes up through weakly.
your water supply is too low. he watervalve (inlet valve) may be clogged. With insufficent supply you get a low fill and not enough water to fully enage the pump's power.
Apr 08, 2009 | Dishwashers
Doesn't clean
check theres enough water getting into machine are you on tank water or low pressure water.
Feb 09, 2008 | Asko 24 in. 1585 Built-in Dishwasher
Low water pressure
Is the hot water faucet under the sink open all the way?
Miss Midget
Nov 02, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
