Question about Samsung SyncMaster 205BW LCD Monitor
My monitor goes out every now and then for a few seconds. This is occurring after I re-loaded my system software on my Mac Mini (system 10.4.11). I had do do a clean install and re-load everything and since then, my monitor will go black for about 10 seconds and then come back, every 5 to 10 minutes. Is there a patch or a setting that I can add or change? Thanks in advance
    Top Expert:
  • Samsung Master
  • 12,962 Answers
Nope, there is something wrong with your power supply and in time the anomaly will become permanent. Start saving some money.
Posted on Sep 04, 2017
peping
  • 99 Answers
SOURCE: screen suddenly goes blank
when you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem.
Posted on Apr 01, 2008
volto
  • 101 Answers
SOURCE: Samsung SyncMaster 915N monitor
Go into advanced settings from the settings tab of "display properties" and select the "monitor" tab, from there, try changing the refresh rate. Toggle "hide modes that this monitor cannot display" if you do not see any other settings in the drop down other than the one that is already selected.
Posted on Jul 16, 2008
  • 23 Answers
SOURCE: Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Posted on Aug 14, 2009
SOURCE: Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
hello i have the same problem, there are 4 lamps (bulbs) inside the monitor when some of them falls the system turn off, cheks and good look
Posted on Oct 27, 2009
  • 237 Answers
SOURCE: Samsung SyncMaster 512N 15 inch
go to control panel then power option then change setting to TURN OF DISPLAY "NEVER"
Posted on Aug 21, 2010
I bought an old Mac Mini Intel Core 2 Duo, 2 GB Hard Drive, OS X Yosemite, with serial # C07CS2TPDD6H. What adapter cord could I use to connect it to an iBox C1752, TFT LCD Monitor?
That Mac has a hdmi port and a mini display port. The monitor has a saga port. So ether a hdmi-svga. Or miniDisplay port-svga.
Any usb keyboard will work. So any Mac keyboard newer than 12 years should be good, and newer pic keyboards will work. Beware of older keyboards that have round plugs. On macs these were ADB ports. On PC's, they used PS2 (ADB, ps2, usb are all different, you want the flat rectangle USB)
U.S. pc keyboards also have two modifier keys wired different than the U.S. Mac keyboards, but this can be adjusted in the system preferences. Can't say for non U.S. KBs. They are the windows/alt keys. Vs Opt/Command keys. That is, if you are soused to using a Mac, the key that is closest to the spacebar (command key) is applied by the second key over rather than the first. Again, this can be modified in the Sys Prefs.
Jun 06, 2015 | Apple Mac Mini Desktop
How to planar touch screen to mac mini
Try downloading and installing the latest drivers for your particular model.
Drivers and Software
Oct 15, 2014 | Computers & Internet
How to put the monitor cable in to the mac mini
You need the correct monitor or adapter that works with your mini.
Feb 16, 2013 | Apple MAC MINI 266GHz Intel Core 2 Duo 8...
I have a sony handy cam DCR - DVD105, I want to know all the ways of being able to connect it to a laptop and extract the files to use in other softwares, like Window's Movie Maker, or Power Direct 09.
How to load Mini DVD to Mac
  • Though Mini DVD can not be played back in Mac slot loading player, we have other ways to load Mini DVD to Mac.
  • Method 1 If Mini DVD camcorder has FireWire or USB; just connect the Mini DVD camcorder to Mac using FireWire, or USB to load Mini DVD to Mac.
  • Method 2 If Mini DVD camcorder has not FireWire or USB; just shop for external mini-DVD drive that uses either a USB or Firewire connector cable, and then connect the external mini-DVD drive to your Mac and install any extra software that came with it. Insert the mini-DVD into the external drive, and then access the files on the mini-DVD as you normally would to load Mini DVD to Mac.
  • Method 3 If Mini DVD camcorder has not FireWire or USB; buy an adapter that converts a mini-DVD to a normal DVD by adding on a circular plastic piece that emulates the full size of a regular DVD. Attach the adapter to the mini-DVD and load it into the Mac's DVD drive to access the files. (Check the specifications of the adapter before purchasing, as several on the market do not work in vertical-loading drives like those found on the MacBook Pro.)
  • Method 4 If Mini DVD camcorder has not FireWire or USB and you don't want to buy a separate external drive or full-size adapter either, but you do have access to a PC, you can transfer the files on the mini-DVD onto the PC, then put them onto a USB flash drive, which will work on your Mac.
more detailed at http://www.bigasoft.com/articles/easy-solution-to-import-midi-dvd-into-imovie.html
Apr 21, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
The monitor is black with a error message :input signal out of range We are connected to a Mac Mini This problem seemed to happen after the monitor was accidently disconnected and then when it was...
Can you please get me the make and model of the monitor? Also did you check to see if the refresh rate of the monitor matches with that of the mac mini?
Nov 21, 2010 | Hannspree Computers & Internet
Everytime i conect my monitor into my mac mini the screen shows up for a brief second and disapeers. How can i fix this
You need to lower down the screen resolution. Check the setting of your mac mini then adjust the screen resolution to the lowest.
Jun 09, 2010 | Acer V193w LCD Monitor
Everytime i conect my monitor into my mac mini the screen shows up for a brief second and disapeers. how can i fix this
Hello sir, hi, you need to try another good working monitor, and confirm if the problem is your monitor or your Mac mini, or test your monitor on another mac, and see if the same symptoms appear. you now have an idea of where is the problem. let me know your progress
Apr 26, 2010 | Acer V193w LCD Monitor
Mac mini and Planar PL2010MW contectivity
have you tried changing the display resolution to lower at first so you can at least get a signal ?
Dec 27, 2008 | Planar PL2010MW Monitor
HDMI blank picture
Check to see if the TV can support the resolution and refresh rate (ie 1920X1080 at 60HZ) Most HDTV's have a limited number of resolutions and refresh rates that they are compatible with. When the computer is booting up, it is probably using a default resolution that is compatible with the tv. Then after the computer finishes loading all of it's drivers, the resolution changes to one not supported by your tv
Dec 27, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Samsung SyncMaster 205BW LCD Monitor Logo
88 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
