Question about MSI Wireless-G RG54G3 Router
It is a new laptop and i cant find any wireless adapter in the search list
    Problem Solver:
  • 11 Answers
I was facing a similar issue a while ago when I stumbled upon www.ijinni.com. The site was exceptionally well laid out and easy to navigate. All I had to do is, pose my question. The resolution was provided very promptly. They offer some excellent technical guidelines which cover a wide range of topics from installing network drivers to cleaning your mouse JUST FOR $10. So if you are looking for online technical support for any kind of computer related issues with knowledgeable specialists who come up with perfectly acceptable solutions, www.ijinni.com is the right pick.
There are 4 ways to reach them.
1. Once you open the website just click on the live chat where one of the IJINNI technicians will be in touch with you.
2. If you have Skype installed in your machines just add the contact "ijinni.com" (free call).
3. You can email at support@ijinni.com
4. You can dial at +1 512 879 3546.
For any issue you are facing with the computer just call IJINNI
Clean, straightforward and effective!
Posted on Mar 28, 2011
Motorola 1c743 wireless adapter reset
You modem needs to be powered on, linked to your cable or phone connection, and then linked to your router with an Ethernet cord. You also need a base computer (connected to the router with Ethernet as well) to adjust your router settings, like password and router name, and assure that you are communicating with the Internet.
Install your wireless adapter software to your laptop or computer that will be using the Internet wirelessly.You will be prompted at some point during the installation to plug in the adapter. (If prompted, restart your computer.)
Plug the adapter into your computer or laptop. Some adapters come as USB-compatible (Universal Serial Bus) plug-and-play devices, and others are PCMIA (Personal Computer Memory Card International Association) cards that go into a special wide slot in laptops.
Go to your computer control panel and click on Network Connections when the software download is complete (if the control panel does not load automatically). Your new adapter should be now be listed. Select the icon and look at the description to make sure that it is connected. If not, right-click the adapter icon and click Enable.
Double-click the adapter to search for a wireless connection. Refresh the list of connections available until you find the name of your router. Enter any passwords that you set up for your wireless router and then connect to the Internet.
Apr 07, 2013 | Motorola Computers & Internet
I have a sony vaio laptop do i need a wireless card.
Almost all laptops being manufactured even 10 years ago has built it wireless card. I believe yours have built in one and no need to buy an external wireless card.
To further verify if you have it installed, you can check in in the Device Manager under Network adapters (if the wireless card driver is installed). To bring this up, follow the steps below.
For Windows XP:
Start -> Run -> devmgmt.msc (Type in the box) -> Expand "Network adapters" (You should see wireless and ethernet adapters listed)
For Windows Vista and 7
Start -> devmgmt.msc (Type in the start search box) -> Expand "Network adapters" (You should see wireless and ethernet adapters listed)
If you want to further check if you really have the wireless card installed, please post the make and model of your laptop.
Hope this helps.
Jun 26, 2011 | Sony Computers & Internet
When i started my laptop the adapter is not showing in device list, when i deleted all network devices from the list and restart the laptop and searches thru system bios setup then this will work for one...
Donot use an extension cable or a USB hub. Connect the wireless adapter directly to the computer. Try with different USB ports on the computer. Try updating the latest driver. Check it with a different computer so that we can isolate if it is the issue with the computer.
Sep 03, 2010 | Broadcom (BCM94318MPG) 802.11g/b Wireless...
On my HP laptop, my wireless internet isn't
With the provided information - nothing could be concluded with regards to where the issue is.. however try the below steps .. this should work
Step 1 :
> click on start (assuming it to be a windows OS)
> right click on "my computer" and select "Properties"
> you will have the system Properties window pop-up
> under the Hardware tab, click on Device manager button
> under the device manager list look for network adapters
> you should now be able to see your wireless card under network adapter - check if the adapter is enabled ( if not kindly enable by right clicking on the adapter)
> once the adapter is active - it will have a green icon with not error on it.
> close all the windows opened till now
Step 2 :
> click on start
> Select Run - new window will pop-up
> type "Services.msc" - new window pops up
> scroll down to the bottom of the list
> right click on "Wireless Zero Configuration" and Start (if not already started)/Restart the service.
> now close all the windows and search for wireless networks again
you should be able to find it
May 10, 2010 | HP (407576-001) 802.11a/g/b Wireless...
Packard Bell easynote R1938. Can't connect wirelessly, wirelss lan indicator in task bar, but, in network connections, no wireless. Drivers are installed, HELP please ( just re installed xp, had this...
Try Control Panel/Add hardware, have Windows search for new hardware. It will "search for new hardware that has been connected recently but not installed". Choose 'yes I have already connected...'. It will display a list of hardware that is on your laptop; search down the list until you find your wireless adapter. Highlight it, click next. I am betting that the "hardware is installed but has a problem"; it is probably disabled. It will prompt you to open a troubleshooter that will allow you to enable the wireless.
Mar 12, 2010 | Acer Aspire 4720 Notebook
Can't power on wireless adapter. worked fine since
my laptop lenovo 500 cant find any networks, have done the usual searches and checks but to no avail. any ideas
Feb 13, 2010 | Lenovo 3000 N500 Notebook
I have a laptop running 802,11 g/b and vista and I Cant connect to linksys wag160n wireless router(802,11 n). laptop sometimes recognises network but when I try to connect it wont. could you help ?
Hi, You cannot connect across wireless protocols. In other words to connect to 802.11 n you need an "n" adapter.
Now, the router should be backward compatible & provide wireless g/b but you may find that when you search for networks it will be listed as a seperate network name (from the same router)
Try searching for this other network. Your router documentation should advise you of its default name & any set up process
Dec 23, 2009 | Acer Computers & Internet
CAN NOT CONNECT WIRELESS ADAPTER SO AS TO USE MY LAPTOP WITH SKY BROADBAND
i connect to the wireless adapter its very easy go to the wireless adapter & refresh to the network list if your notification area will have a wire less network when the wireess adapter search any connection then you see a option connect then click connect
Sep 17, 2009 | Adapters.com Computers & Internet
Wireless connection disapeared from computer
Hello!
I am not sure exactly where you are checking for Wireless connections.
Anyhow, now a days we are hearing many Wireless adapter missing from Device manager issues.
Please get back to us with the Brand name of your laptop, OS installed.
Also check in Device manager for Wireless adapter.
Please follow these steps to open Device Manager:
1. Right Click on 'My Computer' icon on Desktop and choose Properties.
2. The System properties Window opens.
3. Click Hardware tab and then click the Device Manager button.
Expand + Network adapter and check if the Wireless adapter is listed there or not.
If it is not listed there, then the issue is with the Wireless adapter itself.
This is most comon issue in HP COMPAQ notebooks.
if you are not aware of the Wireless adapter under + Network adapters in Device manager, then get back to us with the complete information under + Network adapter.
So thatI can help you in better way
Aug 09, 2008 | Computers & Internet
MSI Wireless-G RG54G3 Router Logo
23 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
