Question about Behringer Europower Pmp5000 Powered Mixer Pmp5000
We just got a PMP6000 and this has to be the worst manual ever written. Not a word about bridge mode except that it has one. Do I have to rewire a speaker cable or what? Which fader would control the mains? Can I still use the crossover on MONO to feed a sub amp?
  • Behringer Master
  • 5,603 Answers
Yes, in bridge mode you will wire ONE Speakon that will have the two speaker wires connected to pins "1+" and "2+". You do NOT need the manual to do this, the info is right on the back of the PMP6000 itself. You will plug that Speakon into channel "B".
PLEASE note that you CANNOT go below 8 ohm speaker impedance. If your speakers are 4 ohm you MUST connect two in SERIES which requires special cables and the speakers MUST be identical. You can connect TWO 16 ohm speakers in parallel by daisy chaining, however 16 ohm speakers are NOT very common. With 8 ohm speakers you can connect EXACTLY one in bridged mode UNLESS you connect four of them in series-parallel which requires special cables and great care. Believe me you do NOT want to have an accident with this amp as repairing is extensive.
Lastly, put the speaker configuration switch down to the bridged mode.
This is how bridged mode works: Sliding the switch down basically configures the two power amps in monaural and one amp is inverted so there outputs are out of phase by 180 degrees effectively doubling the voltage.
Remember that BOTH wires in bridged mode are HOT and grounding one while amp is on will likely blow out one side or more.
Posted on Mar 27, 2011
I'm Ziro. I need a part list for the main power supply board for behringer pmp4000 mixer, two transistors were removed from it and I need to know the part numbers of each in order to install them.
In my opinion, due to the physical appearance of pmp4000 and pmp3000 look the same, it will most likely also have a common circuit and parts list (at least, most).
Usually Behringer (and all the manufacturers), with the same series / sequence, using the same circuit, the difference is the number of channels only. You can compare the parts list on PMP3000 schematic, with your PMP4000.
PMP4000.
PMP3000
You can download from this link.
http://elektrotanya.com/behringer_pmp3000_sch.rar/download.html
Hope this helps.
Regards.
Oct 05, 2015 | Behringer Music
I have two B215 600 watts speakers. Smoke started to come out of one when it was in use. I continued to use the other one, and about an hour later, the bass on that quit working. Any help with...
Sorry, those speakers are rated at 250 Watts RMS continuous, NOT 600. The speakers are nominally 8 ohms. The PMP6000 will deliver about 250 watts RMS to an 8 ohm load so the speakers should be able to take this as long as you had one per side and NOT using bridged mode of the PMP6000. It is possible that you fried the amp, although the PMP amps have a speaker protection network that shorts the output should the amp hard over. It is strange that you could draw smoke with the setup. Hopefully you were not generating very low frequencies that were below what the speaker could handle OR that you did not crank up the bass with the EQ such that frequencies below the speakers rating were sent at high levels. Your speakers are rated for a low end at 55 HZ. You should have the eq cut the gain below that. The leftmost EQ (50 Hz) should NOT be higher than center... if you boost that one, you likely will be buying new speakers. If you need power below that, then you need to be using subwoofers. Hopefully you haven't damaged the PMP6000... I assume that was the amp you were using, although you haven't stated that. At this point, unless the stuff is under warranty, you nee to open the speakers and see what has blown... could be the woofers or the crossover network...Use an ohmmeter to check the woofer DC resistance... should be between 7 and 9 ohms. If it is open circuit, the voice coil is blown.
Sep 19, 2011 | Behringer PMP6000 / B215XL Powered Mixer...
I accidentally used the two outs (A & B) at turning on the pmp 5000 in the bridge mode. The mixer was normal during the first 10 minutes, then the mixer shut down and stop working, and now it doesn't...
Insufficient information ! Were you using a special cable used for bridged mode or used regular cables and just changed the slide switch to bridged mode? IF you had regular cables for A/B and just had the switch to the bridged mode NO DAMAGE WOULD RESULT. The bridged mode switch really only sets both amps to be driven from the same mixing buss as monaural. If you had a bridged cable and a plain one you would have overloaded one side amp. The amps have an "electronic" over current fuse and if you trip it you have to leave the power off for a minute or so and then re-power the amp. There is a HAZARD that I have written a tip in Fixya about PMP mixers. The sleeve of a 1/4 inch plug connected to side A is the HOT signal out of the amp as opposed to the B channel being the tip of the 1/4 inch plug...this assumes you might be using Speakon to 1/4 inch speaker cables. DO NOT under any circumstances use Speakon to 1/4 inch adapter cables as the barrel of the adapter female part on channel A is HOT to ground and you will pop the A amp.!!!! I am afraid that if you were using regular cables taht another failure occurred not related to the setting to bridged mode. The speaker leads for bridged mode are configured by the way the special bridged mode Speakon cable is wired... The slide switch only configures where the amps get there audio be it stereo busses or singly from one side. If after being off for a few minutes the amp still is totally dead, check the main power fuse which is alongside the power input connection in a plastic boat you pull out. IF THE FUSE IS BLOWN do NOT replace it as it will likely cause additional damage. Have unit repaired. There is a weak spot in these that results in arcing between layers of a multi-layer circuit board.
Apr 15, 2011 | Behringer Europower Pmp5000 Powered Mixer...
I want to rewire my DiMarzio Dp-159 evolution bridge pickup installed in my Fender Japanese HSS Floyd strat, to be split (single coil) in the 4 position, just like in the Fender powerhouse mexican strat....
My advice is that if you need to ask how to do it, you don't have enough experience to execute this properly and safely. Please take it to an expereinced professional.
Oct 28, 2017 | Dimarzio Dp159 Evolution Bridge Pickup...
What is the bridge amp setting mean on the pmp6000?
In bridged mode, both sides are used to drive the same speaker. One side is phase inverted relative to the other so the two sides add their voltage. It is important to note that you cannot go below 8 ohm speaker in this mode. The amps can generate about 60volts peak or about 43 volts RMS. So the net will be about 86 volts between the two sides. With 86 volts on 8 ohms you can get about 925 Watts max... yeah it is not the claimed 1200, but it is a lot closer than the shop vacuums claiming 4Hp when running on 120 volts... Those are peak values that have LITTLE to do with actual true values.
You can't run stereo in this mode because BOTH sides are used as a single power source. The PAN controls will have little effect as the system is in monaural mode.
Mar 18, 2011 | Behringer Europower Pmp5000 Powered Mixer...
New to the mixer world. i have a dicontinued pmp5000. can't get the bridge mode to work
You require a special cable with the Speakon copnnector wired a special way. Refer to your user manual for the correct pin connections to use bridged mode and then put the slide switch in the position closest to the effects display.
Refer to figure 4.6 on page 10 and figure 4.7 showing the connection for bridge mode.
NOTE: you cannot go below 8 ohm speaker on the bridge mode... that USUALLY means a singl speaker of 8 ohms... you CANNOT parallel two 8 ohm speakers.
The single speaker cable will plug into the "B" output connector. Remember bothe the barrel and the tip of the connector if using 1/4 inch plugs is HOT and grounding either inadvertently will fry the amp.
Jan 19, 2011 | Behringer Europower Pmp5000 Powered Mixer...
My pmp6000 wont work in mon1/ mono mode. I have one speskon channel going to two mains and the other to two monitors Can't get sound.
OK... from the schematics it appears that when in mon1/mono mode you use ONLY the MON1 gain controls, including the channel MON1's and the MON1 slider. Make sure you have each of those turned up as needed. In this mode, MON2,s and the MON2 slider are unused. The MONO slider controls the MAIN output.
Dec 03, 2010 | Behringer Europower Pmp5000 Powered Mixer...
I just both the Europower pmp6000 powerd mixer and Eurolive b215xl speakers and i need help conecting the speaker to the mixer. I will be using it with some mics at a function in an hotel. How do I connect...
use 1/4 inch speaker cables. hook one speaker up to "main 1 R" out and the other to "main 1 L" out. if you have additional main speakers, hook them up the the "main 2" outputs.
look for the "bridge amp mode" switch and move it to the "main L- main R" position.
Nov 06, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Hi, We have recently purchased a Behringer PMP6000/VP1220/VP1220F PA package we have a pair of speckon to 1/4 TS connectors and a pair of 1/4 TS to 1/4 TS connector cables we have the mains on tripods and...
Please read a tip I just posted regarding a hazard of the Speakon to 1/4 inch cables when used with these PMP mixers.
If you are using your main speakers as stereo, then you will need either powered monitor speakers OR an additional seperate amp for them. The mon outputs on the mixer are LINE LEVEL and are not driven by a power amp. Use TRS (balanced) interconnect cables from these to POWERED monitor speakers.
You can parallel your two mains providing the parallel impedance is 4 ohms or greater (two 8 ohms in parallel at most). The the monitor speakers can be paralleled and the switch set to Main/Mon so that one side of the power amp drives the mains and the other drives the monitors.
To prevent damage to the mixer, make sure all speaker leads are secure before powering the system. Run the speaker leads through the handles of the speakers to prevent inadvertent unplugging due to personell tripping over cables.
DO NOT use the bridge mode in your use.
Aug 07, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Behringer Europower Pmp5000 Powered Mixer Pmp5000 Logo
392 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
