Question about Troy-Bilt Pony Garden Tiller
What type of oil do I need to use for this tiller?
What type of oil goes in the crank case in a Scotts model 6070S, rear tine tiller?
normal engine oil in the engine sump
gear oil 80 oep in the gear box
Jul 21, 2016 | Garden
I need to know what brand and type of oil to put in my cub cadet rt 65 tiller
As 1st option,It would be best to call the manufacturer Cub Cadet,or their Authorized Repair Center,and ask them directly.
Refer to the manual that came with the tiller.
As 2nd option, a general small engine repair shop can be helpful too.
Have a nice day.
Apr 23, 2016 | Horizontal Ohc Engine 190cc,gc...
Can you buy a service manual for mtd tiller
Every 25 hours change the oil using SAE30 or 10W30 oil. Go online to the manufacturer for service manual.
Aug 18, 2014 | Garden
What type of oil does a troy built tiller use? I have lost my book.
This is dependent upon what the engine application on the tiller is. If it's 2-stroke, use a quality synthetic or semi-synthetic 2-stroke oil mixed with the gas. If it has a 4 stroke engine use SAE30 oil, unless you run synthetic (which I highly recommend), then you can use a multi-viscosity oil if you like, say 10W-30.
May 24, 2011 | Troy-Bilt Pony Garden Tiller
Oil in my tiller
Unless you live in a cold climate, ordinary 30W motor oil is fine. In cold climates, 10W-30 may make starting easier. You don't need expensive synthetic oil. Sounds like you want to take good care of your equipment. Tip: the air filter is a critical component in tillers since they work in dirt constantly. Check it regularly and change it when dirty. That will do the most to prolong the life of the engine. Good luck, and please rate my advice if you find it helpful, thanks!
Jun 10, 2010 | Husqvarna PRRT850X 960920015 CA 17" Rear...
How much gear oil 72'' tiller
In Gearboxes use gear oil (type GL5-85W 140 or Triple Zero
Grease; which can be poured, and has "EP" i.e. "Extreme Pressure" additives.) Fill the gearbox to approximately half-full level.
Apr 09, 2010 | King Kutter II Gear Driven Rotary Tiller...
My neighbor let us use his troy built tiller and it needs oil but he doesn't know what type of oil to put in the transmition. please help
The recommended lube for a Troy Bilt transmission is 140 Gear Lube. It's tough to find. If you use lighter oil, the trans seals will likely start to leak.
Jun 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
What engine oil do I need for a gasoline Tiller CT2067 - 6.5HP
Find what type engine, go to that engine site, they should have specs.
Mar 27, 2009 | Garden
What type oil goes in the tranmission?
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Feb 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy-Bilt Pony Garden Tiller Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
