Question about Miele Refrigerators
Miele k2316 fridge
My fridge isn't cooling down at all, the only way i can get it cool is by pressing the 'super cool' button. do i need a new thermostat, the gas refilled? your help would be very appreciated.
  • 619 Answers
SOURCE: KBFA20ERSS- Fridge stopped staying cool; thermostat doesn't work
Hi, if you can find the input of cool air there a slider to shut it make little way to in cool air to keep cool down.
If there a possible thermostat make it lesser so that thew thermostat will on and off.
Posted on Jan 18, 2008
  • 54 Answers
SOURCE: Indiset Fridge not cooling
If the compressor is running and not cooling then there is no refrigerant circulating in the refrigerator or no air moving across the one or both coils. No ice in the freezer section indicates that no cooling is taking place at all, pointing to a lack of refrigerant rather than poor air circulation due to a bad fan or frozen coil.
You can try a manual defrost to ensure it's not a frozen coil by unplugging the unit for several hours with doors open then starting it again. If there is still no cooling occurring you need to check the refrigerant level. If its low you will have to find and seal the leak, pressure test with nitrogen, evacuate and weigh in the correct amount and type of refrigerant listed on the unit.
Hope this helps, needless to say be sure to find a reputable qualified technician to open and service your refrigerant circuit this will make or break your unit.
Posted on Mar 15, 2008
  • 1462 Answers
SOURCE: Liebherr larder fridge not working in normal mode
thermostat is faulty - supercool just bypasses the stat
Posted on Sep 24, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Westinghouse RP423 Freestyle fridge cooling failure
I am going to assume you are in the UK. the voltage is higher than most household refrigerators here in the USA. Disconnect power to refrigerator and check continuity on two of the three terminals of the compressor at a time until you measure the resistance in the windings all the way around. The terminals should be marked R, S and C. (Run, Start and Common) you should get a reading with your multimeter all the way around. When you have done this and have the readings I want you to touch one end of your multimeter to the metal pipes or any clean metal outside the compressor and the other to one of the three terminals one at a time like you tested before. With your multimeter set up the same, see if you get a reading from metal housing to the three pins, or terminals c, r and s. You should get no reading. If you do, the compressor is a burn out and on the first test if you don't get a reading on the two at a time test between two post that is considered to be open or broken windings. The compressor does have an internal overload that may be open also. But if cool at time of test, and it shows up the compressor in bad. Let me know what you find...Thanks, Sea Breeze
Posted on Apr 24, 2009
  • 864 Answers
SOURCE: hopoint ff200e fridge freezer is not freezing and
Unplug it for 30 seconds and plug it in again to see if it will reset.
Posted on Jul 29, 2009
I have a Miele Kfn 8452 sd who blink 2 leds both in the same time, freezer and super freeze,and i hear the sound alarm, i need to know whats the problem, what is damaged?
Press alarm button once
either left door open too long or temperature too low
adjust fridge to 4 centigrade
freezer to -17 centigrade
Dec 28, 2015 | Miele Refrigerators
How do I set the temperature for miele fridge freezer pigeon pair kfn 9753 iD?
Wait for it to cool
while it dies you will see flashing bars
wait
it will cool
Feb 24, 2015 | Miele Refrigerators
Hi I have a problem. My Miele fridge K8952 SD ed is cooling more than it should and freezes all the food inside. I can not turn it off and the stat indicates 5 degr C although it is colder inside the...
Can't turn it off, or set higher temp with coin slot thermostat? Might need new one, stuck closed. 5C is 41F which should be great for fridge, but you say food freezes. If need manual to get more info=
http://www.fridge-manual.com/manuals/miele/Miele_K_8952.pdf
Jan 29, 2014 | Miele K8952SDED Refrigerator
Ive just bought a hot point ffa74 fridge freezer an it's now been plugged in for around 3/4 hours and the freezer isn't getting cool neither is the fridge, on the control panel there is a green...
The normal cool time for a machine is up to 24 hours, so I wouldn;t worry about anything at the moment, but if the product isn'l cool by the morning I would return it as a defect
May 14, 2012 | Hotpoint Refrigerators
Super cool not working
defect botton just replace the botton cost not more than a dollar
Apr 15, 2012 | Radio Communications
I have a KFN 9753 fridge-freezer about over 3 years old. The fridge is not cooling.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 06, 2011 | Miele Refrigerators
Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
Sep 23, 2008 | Liebherr Refrigerators
Miele Fridge freezer - the freezer temperature indicator shows the temperature to drop from 20 to 10 in under one hour despite the door not being opened. By switching on the super freeze the temperature...
first...Check whether the ventilation gaps
have been covered over or become
dusty.
2. Check whether the metal grille (heat
exchanger) at the back of the
appliance has become too dusty.
It needs good area of circulation and clean coils/grilles.
it makes it hard to cool it down if dirty/dusty. I don't think the oven is doing it cuz operating in a room/outside which is too cold will cause the cooling system to switch
off for too long, causing the freezer
section to become too warm.
My best guess is vents and coils dirty/dusty.
Jan 20, 2018 | Miele Refrigerators
Refrigerators Logo
106 people viewed this question
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
