Question about Microwave Ovens
How do i change the clock on a Logik Microwave model L20MS10
My microwave model number is WM009. I am unable to change the current clock time. How do I do this?
push clock the up or down then clock again till its set then start
is what I would try
Dec 21, 2016 | Microwave Ovens
FMT 148G1W2 model how to turn the clock off
Good Morning Friend, that's a great question!
The clock display on your Frigidaire microwave (FMT148GW2) may be turned off by pressing and holding "0" for about three seconds. You can redisplay the clock by pressing "0" again. Hope this helps! - Z
Jul 06, 2014 | Frigidaire FGMV174K Microwave Oven
Change time on frigidaire microwave no clock button
Hi ssullivan013 - Here are some generics instructions that I found for the model number posted above. Hope the information is helpful.
Suppose you want to enter the correct time of day 12:30 (A.M or P.M.).
1. Touch Clock pad.
2. Enter time 1,2,3,0 and press CLOCK pad again
This is a 12 hour clock. If you attempt to enter an incorrect clock timer, ERROR will appear in the display. Touch the CLEAR/OFF pad and re-enter the time.
Mar 18, 2013 | Frigidaire PLMV169DC Microwave Oven
L20MS10 need a manual
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 19, 2010 | Microwave Ovens
Setting clock
It depends on the brand and model.
Normally it's a sequence like:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
If not, please post a new inquiry with your correct brand and model.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
May 23, 2010 | Magic Chef MCD1311ST Microwave Oven
How to set clock on sharp microwave
normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
Sep 21, 2009 | Sharp R-1480 Microwave Oven
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
When the microwave oven is plugged into an outlet,
the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
the oven is cooking or defrosting.
You can actually download your owner's manual here
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 10, 2008 | Microwave Ovens
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Panasonic Microwave Dimension 4 convection (11 yrs old)
You need to press clock 3 times, then start 3 times and then clear/reset 3 times. Then you can reset the clock by pressing clock 1 change the time and press clock again.
Mar 11, 2007 | Panasonic NN-T888S Convection/Microwave...
Microwave Ovens Logo
236 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
