Question about Lenovo G560 06793JU Notebook
1. My Lenova G560 has Windows 7. When I loaded it with XP, the HDs capacity has reduced from 330 GB to 130 GB. Kindly advise, how can I restore it to its full capacity of 330 GB. Which software to use partition and formating. 2. no laptop has floppy drive to use a boot-up floppy disk. How can I boot up, using a cdrom that has FDISK and Format in DOS. Would it work if I copy FDISK and Format applications from a floppy to a CDROM in order to boot up on starting a corrupt HD? Kind regards vhdas
  • vhdas Apr 01, 2011
    Probably I did not give the full details of my complaint. When I bought the laptop, it was with Win 7 loaded in a 300 GB HDD. As I was working in an Island (Maldives) I had no internet connection for any update including Win 7 update. My C Drive was 270 GB and D drive 30 GB
    (That is how it was partitioned) C Drive had about 170 GB of Data (video and movies) and the OS. When I returned after one year, I connected it to the net for upgrade. As the process was going on for some time, Istopped it and shut it down. Later when I restarted it I found all that data of 170 GB are missing and the C Drive volume is also reduced by 170 GB.
    I applied the one key restoration by which all the lost data were recovered yet the 170 GB space was lost when I check the volume graph of C drive.
    As Win 7 was not user friendly as XP, I thought of loading XP as OS and as such I formatted the C Drive from XP CD thinking that it would format the entire 270 GB. of C Drive. When loading was complete, I noticed that the C Drive showed only 100 GB and lost 170 GB.
    The XP OS was functioning as usual except for the lost 170 GB of space within the entire C Drive. This is what the problem I am facing to rectify. Can anyone kindly suggest a software that can recover the entire volume of 300 GB as raw so that I can do partition and format later.
    I don't want to recover any data, partion etc for that matter but I wanted it in a raw state of 300 GB, its full capacity (as you buy a new HDD from dealer).
    Thank you very much.
    Regards, V.H. Das
  • 734 Answers
Hi There,
You can access the functions in DOS you desire from any XP Disc. I prefer an XP SP3 but all will work.
1. Insert the disk and reboot, using whatever F key at boot that gets you to device selection.
2. Boot from the Optical Drice
3. Let Setup run until you reach the point where you are offered the options of installing or repairing by hitting the R key
4. Hit the R key and you'll immediately be shunted to the DOS command prompt.
5. Type HELP and then hit Enter key
6. All available DOS commands will be displayed
7. Hit the enter key a few times and you'll have the list and a command prompt.
8. Type in your choice and hit enter.
Regards,
Selk
Posted on Mar 27, 2011
  • 592 Answers
Hi.
Yes, it should work if you copy them onto a cd. Just make sure that when you burn the cd, make sure that you select to " make a bootable cd".
As far as the size of the drive goes, xp should have recognized the correct size to begin with.
If you click on " computer" on your start tab, it shows all the drives.
Right click on the drive in question, and select properties.
Next select the "tools" tab.
Click on the button for " error checking".
If it is the same drive that your operating system is on, then it will ask if you want it to run at the next boot.
Tell it yes, and then close the properties box, and reboot and allow the system to run error check.
It may just have been a MFT glitch, where it reported the wrong size to windows.
After it runs, it will then boot the system up into windows.
When it's done booting up, open "computer and see if it now shows the correct size.
It may, or may not.
If so, then you are good to go, if not, then you may have to format the drive so that it uses the unallocated portion of the drive.
I hope this helps you out, good luck to you.
  • vhdas Apr 02, 2011
    Probably I did not give the full details of my complaint. When I bought the laptop, it was with Win 7 loaded in a 300 GB HDD. As I was working in an Island (Maldives) I had no internet connection for any update including Win 7 update. My C Drive was 270 GB and D drive 30 GB (That is how it was partitioned) C Drive had about 170 GB of Data (video and movies) and the OS. When I returned after one year, I connected it to the net for upgrade. As the process was going on for some time, Istopped it and shut it down. Later when I restarted it I found all that data of 170 GB are missing and the C Drive volume is also reduced by 170 GB. I applied the one key restoration by which all the lost data were recovered yet the 170 GB space was lost when I check the volume graph of C drive. As Win 7 was not user friendly as XP, I thought of loading XP as OS and as such I formatted the C Drive from XP CD thinking that it would format the entire 270 GB. of C Drive. When loading was complete, I noticed that the C Drive showed only 100 GB and lost 170 GB. The XP OS was functioning as usual except for the lost 170 GB of space within the entire C Drive. This is what the problem I am facing to rectify. Can anyone kindly suggest a software that can recover the entire volume of 300 GB as raw so that I can do partition and format later. I don't want to recover any data, partion etc for that matter but I wanted it in a raw state of 300 GB, its full capacity (as you buy a new HDD from dealer). Thank you very much. Regards, V.H. Das
  • 569 Answers
To check and alter your hard drive partitions I suggest you use Easus Partition Manager - it's freeware and can be downloaded here:
http://download.cnet.com/EASEUS-Partition-Master-Home-Edition/3000-2248_4-10863346.html
I'm not sure what you are trying to do with the second question. Are you suggesting formatting the disk again and re-installing XP?
If you want to boot from CD and run diagnotics then you can download Ultimate Boot CD from here and burn it to a disc that will then be bootable.
thttp://www.ubcd4win.com
This is also freeware.
  • David Richards Apr 01, 2011
    OK, now I understand your problem better. Thanks for the more detailed description.
    I think the issue is caused by the Rescue and Recovery utility that is provided by IBM on the Lenovo. Other users that have experienced this problem have been able to free up the space by going into Rescue and Recovery and deleting all backups.
    I would suggect that you make sure you have a backup of all data first and then try the above.
    If this is successful I would also suggest that you remove the Rescue and Recovery program as it is known to cause such problems, and Windows recovery features should be more than adequate for future use.
I have Lenovo G560 -15.6 - 300 GB preloaded with Win 7. As I was working in an Island (Maldives) I had no internet connection for any update including Win 7 update. My C Drive was 270 GB and D drive 30 GB...
Hi try downloading the ultimate boot cd it has tools for partitioning hard drives and should be able to recover your lost partition space .AS for installing xp you may find some of the components cant get a driver for them for xp .
I hope this helps
Andrew A
Apr 02, 2011 | Lenovo G560 - 15.6 - 500GB - Black -...
Tip
Probably I did not give the full details of my complaint. When I bought the...
Hi There,
It really helps us help you when you include the brand name, model number, and operating system of your computer when you present your request. Just this much information added to your description of your problem can make a huge difference to whoever responds, and can make the difference between solving your problem or not even feeling able to respond.
on Apr 02, 2011 | Computers & Internet
How to load backup from one computerWindows XP (now on Verbatim USB 320) to a new computer running Windows 7
This is not really a solution but for information. There is no direct upgrade path from Windows XP to Windows 7. So, unless you have a compatible program installed on your Windows 7 PC, you will not be able to import a backup from your XP PC. (To My Knowledge).
Oct 16, 2010 | Verbatim External, USB 2.0, 750GB...
What is the maximal capacity hard disk for a intel 440 BX mothercard ? Thank you for your answer
Hardrive capacity is based upon the operating system capabilities not your motherboard. If you are running Windows XP SP2 or later, you should be able to attach any sized IDE drive you want to that board with no problems. Just remember that you must be running XP Service Pack 2 or later to run a drive over 130 GB in size. If you try to XP or XP SP1, a larger drive will work but only 130 GB of it will be useable.
Mike Vail
Oct 05, 2009 | Gateway Computers & Internet
Sir
This is a known issue with the Mp4 players. The first thing you should do is to format the player. After formatting you get close to 954MB/
Jan 21, 2009 | Microsoft Windows XP Professional for PC
Lenovo G560 06793JU Notebook Logo
161 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
