Question about Vicks Healthmist 4100 Humidifier
I am having the water turn black even with daily water changes. Also when cleaning out the filter there are black flakes. Do I need a new machine. This one is only 6 months old.
    Brigadier General:
  • 4,736 Answers
If it's still under warranty, return it for replacement or repair. You will need your Proof of Purchase to do this. Something is leaking internally and contaminating the water.
Posted on Mar 27, 2011
Coating from water panel pad clogging furnace filter
I know of no answer to this except to remove the coating manually to prevent it clogging you filter.
Jun 22, 2017 | Aprilaire 600 Humidifier
I only used my machine for just about two weeks (only in the evenings)with a brand new filter and already the top of the filter has turned yellow/brown and brittle. Is it normal to go through a filter so...
how long the filter will last depends on your water .. if your water has a high mineral content then that is left behind as the water evaporates from the filter/wick ... the yellow brown sounds like calcium deposits .. calcium is often added to water to give it a good taste .. that may be beneficial for you but will build up on the filter .. it doesn't hurt much until it starts to clog the voids in the filter material .. as long as air gets thru then the deposits will be ok .. normally the filter should last about 3 months .. if you use distilled water (with no calcium added) then much longer .. if you have hard water then less .. there is a tablet that you can add to the water to reduce the calcium buildup .. the manufacturer of your humidifier will likely recommend that .. thats often available from hardware stores also ..
so your choices are:
1. don't worry about it until the filter becomes clogged
2. use the anti calcium tablet or something like ProTec PC-1 Humidifier Tank Cleaning Cartridge
3. use distilled water for really long filter life
4. plan on replacing the filter every 3 months
other types of humidifiers have other problems .. the hot water type gets calcium deposits on the heating element requiring cleaning a couple times a year, usually with vinegar or a calcium solvent .. that takes awhile..
the Ultrasonic type doesn't generally have problems with internal deposits because it blows moist air out including the calcium .. that produces a fine dust on surfaces in your house ..
of those types the filter system like yours is easier to maintain than the hot water type and doesn't leave dust behind like the ultrasonic all work better and longer if the water is pure .. distilled water doesn't cost much but you have to be careful .. read the small print .. some of it will say "calcium added" .. you don't want that .. if you use only distilled water then the filter should last the whole year ..
Sep 26, 2010 | Vicks Cool Mist V3500 Humidifier
When the system calls for heat My Aprilaire 700 fan turns on, but the solenoid doesn't open up. The indoor humidity is around 35% now, outside temperature was around 35 with relative humidity of 75%. In...
do you hear a clicking at the solinoid? grab the solinoid and turn it on to see if its getting voltage, you should feel it energize. you can turn off the water supply and disconnect the water line from the solinoid. there is a black pre screen inside the inlet if you have a tiny flat heat screwdriver insert it into the inlet and turn it out. clean it and retry. you can also make sure the orifice isnt clogged its located on the outlet side of the soliniod. when you remove you will probably have a stream of water come out of the feed tube thru the orifice, even if it has sat all summer. if water comes out you dont have a clogged orifice. donot try to **** out the orifice if its clogged you will need to get a new one fron www.aprilaire.com . you can verify it clogged by after cleaning the prescreen reconnect the water line inlet and turn on humidifier if water comes thru the solinoid with the outlet feed tube not connected then the orifice is clogged. If you clean the prescreen and the orifice is fine ,still no water then you will need a new solinoid you should also be able to purchase from aprilaire. here is links to the solinoid and orifice
http://estore.aprilaire.com/catalog/humidifiers/all-humidifier-parts/299
http://estore.aprilaire.com/catalog/humidifiers/all-humidifier-parts/267
hope this helps,
Mac
Nov 07, 2009 | Aprilaire 700 Humidifier
Appril air 600 wont work
the change water panel light is just a timer. it does not sense that the water panel actually needs to be replaced. sounds like you have a solenoid issue. if you have water to the solenoid and are certain you are getting 24v to it, the solenoid is ethier bad or plugged with calcium. most likely calcium. sometimes you can take them apart and clean them. so, it you can hear clicking at the solenoid when you turn the humidstat up and down. try cleaning it.
Jan 14, 2009 | Aprilaire 600 Humidifier
Humidifier leaves a crusty dark substance in water
SPECIAL NOTES
Discoloration/Black Particles
After use, the water residue in the bottom of the container may contain black particles, and, in
some areas the water and the bottom of container may discolor. These conditions are normal and
do not effect the purity of the steam or medicine. The container is easily cleaned with soap and
water. Rinse and dry the container after cleaning.
This was taken from the manual that comes with the humidifier...
Dec 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Filter dries out
2 things could be happening.
#1. Your water has gotten harder in the last year and more deposits are getting caught on the filter. Try soaking it in water and vinegar for an hour. This should clean some of the deposits out and extend the life of your filters. Everytime it gets hard try soaking it.
#2. Your machine is running out of water before you can refill. When this happens and the filters dry out, they aren't as good afterwords.
I would advise trying to clean them with vinegar and water and making sure your machine is always full.
Good Luck.
Feb 20, 2008 | Kenmore 14410 Humidifier
Hunter humidifer
I dont know why your humidifier is spitting water out.
But it sounds like you need to clean the unit and install a new filter. Once the filter becomes used, the humidifier won't work as well. Less water will be used because the clogged filter can't hold as much. Once you replace the filter, your water consumption should go back up and you should feel a difference in your home again.
Good Luck.
Feb 15, 2008 | Hunter 33201 Humidifier
Cool Mist Humidifier Filter Drying Out
How long are you going between filter changes?
A filter that stops wicking water up and turns orange/yellow is one full of deposits.
It sounds like you have hard water. How are you filtering this water before you use it? Distilled water is the best.
Replace the filter. They don't last forever. Mine normally last a month to a month and a half.
Good Luck
Feb 10, 2008 | Honeywell QuietCare HCM-630 Humidifier
Water leak
your drain pipe is clogged up, going to drain- Duh
Jan 13, 2008 | Aprilaire 550 Humidifier
Need to clean the filter
http://homeappliance.manualsonline.com/manuals/mfg/vicks/v3100.html
This is the link to your manual.
Daily Maintenance
1.
Turn switch to OFF position and unplug the cord from wall outlet.
2. Lift the Water Tank from Base. Carefully remove the Water Tray from the base being
careful not to damage the delicate Wicking Filter. Empty excess water from the Water Tray
without removing the Wicking Filter. Remove the Tank Cap and drain any water from the
Water Tank. Rinse the Water Tank with lukewarm water after each use. Wipe accessible
surfaces of the Water Tank and Water Tray clean with a soft, damp cloth.
3. Do not immerse the Base in water. For storage, wipe dry with a soft, clean cloth. Keep
water away from the Air Outlet.
4. Do not leave water in the Water Tank or Water Tray when unit is not in use as it may
result in the build up of mineral deposits and bacteria that can inhibit the output
efficiency of the humidifier. Please note that if water remains in the Water Tank for more
than a day or two, bacterial growth is possible.
5. Replace Water Tray with Wicking Filter. Then replace the Tank. Humidifier is now ready for
use.
Weekly Maintenance
Removing Scale
1.
Remove the Water Tank and empty any remaining water from the Water Tank.
2. Turn switch to the ON position, either low or high speed, and operate Humidifier until the
Wicking Filter is thoroughly dry.
3. Turn switch to the OFF position and unplug the cord from wall outlet.
4. Remove Wicking Filter from the Water Tray by carefully lifting straight up taking care not to
tear filter.
5. Remove the Water Tray from the Base. Fill Water Tray with undiluted white vinegar. Let
stand for 20 minutes.
6. Dampen soft, clean cloth or sponge with undiluted white vinegar and wipe out Water Tray
to remove scale. Do not use soap, detergents or abrasive cleaners.
7. Rinse the Water Tray thoroughly in clean warm water or put in top shelf of dishwasher to
remove scale and vinegar before disinfecting the Water Tray.
Disinfecting the Water Tray and Tank
1.
Fill tank with 1 teaspoon of household bleach in 1 gallon of water. Let stand twenty (20)
minutes, shaking vigorously every few minutes, drain and rinse with clean water until the
bleach smell is gone. Dry with a clean cloth or paper towel.
2. Wipe the Water Tray with a soft cloth dampened in the bleach and water solution. Rinse
the Water Tray thoroughly or place in dishwasher before proceeding.
3. Wipe all exterior surfaces of the Base with a soft, dry cloth. Do not immerse the Base in
water or use water to clean the base. An electric shock may result or the humidifier may
be damaged.
Hope this helps.
Good Luck.
Dec 01, 2007 | Vicks V3100 1.2 Gallon Humidifier
Vicks Healthmist 4100 Humidifier Logo
297 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
