Question about Whirlpool GU2400XTP Built-in Dishwasher
I have Whirlpool Quiet Partner III dishwasher, Model number GU2400XTPS3, Serial number FS1820245. I recently had the thermal fuse replaced by an authorized service repair person. My problem is that the dishwasher stops mid-cycle. I noticed that when I try to clean it in the normal cycle, the dishwasher stops with about 46 or 47 minutes remaining, and the green light flashes continuously. I have pressed the Normal and Heated Dry buttons, as well as the Sani Dry and HEated dry buttons to reset the control board. This works to stop the green light from flashing but when I try to clean the dishes again, the same problems occur (stops midcycle, green light flashes), dishes are not clean. Can anyone help me? Thanks!
  • eskuse Mar 27, 2011
    I counted and the green light flashes in a series of 7 flashes.
  • 77 Answers
SOURCE: Won't run - normal light flashes
You may try removing power to D/W for a minute and reconecting. likely cause though is keypad (console). If a light above a pad stays on the pad is likely closed all the time. Normal is probably cycle most often used. you can test the keypad by removing power to D/W and accessing the control panel. remove conncter P-1 and using an ohmeter test resistance between 13 and 4 on the connecter coming from keypad. yes without very small clips or 4 steady hands it is a little tricky. in the field we use a breakout board. if you get any reading when not pushed pad is bad. you may find a manual inside the kickplate which explains the keypad sequence. it may be control but more likely keypad, even if test is inconclusive.
Posted on Jun 07, 2008
When I had this problem, it turned out to be the heating element.
Posted on Aug 16, 2008
  • 15935 Answers
SOURCE: I have a whirlpool quiet
The control board has failed.
CLICK HERE to see the parts breakdown.
CLICK HERE to see/order the part
Open the door & remove the 8 or so allen screws. The board is simply plug and play.
Bad design - the vent is right by the board - so its subjected to moisture.
Posted on Nov 15, 2010
  • 43501 Answers
SOURCE: I have a Whirlpool Quiet Partner II and the Lock
Have you tried turning off the power for a few minutes before then trying to unlock the dishwasher?
Remove power by turning off the circuit breaker, for a few minutes and then turn the breaker back on....let the dishwasher start up and then try to press the heated dry for 4 should unlock.
If that don't work then try the 4 hr delay button for 4 seconds if your dishwasher has one...
Seems like you scrambled the brain a bit... recycling the power should help straighten things out...
Posted on Jan 27, 2011
  • 2468 Answers
SOURCE: My Whirlpool Quiet Partner II
have you tried powering it down,shutting off power to the unit for 15 minutes,sometimes the electronics will glitch as a computer does,if this is to no avail,then try removing all connections from the interface(control panel) to the main control panel and clean each cable and re-plug in,then see if this solves your problem,otherwise it may be time to replace either the interface or main control board
Posted on Apr 08, 2011
Whirlpool quiet partner ii dishwasher has quit working. Power is getting to the dishwasher but it is not coming on at all. There is water standing in the bottom of it and a very foul smell is present.
This dishwasher has a thermal fuse that attaches to the main control board that may have failed, it can be tested with a meter for continuity if it does not have continuity then it is your problem.
Apr 21, 2012 | Whirlpool Dishwashers
Whirlpool Quiet Partner III Will not drain at the
It sounds like the control unit has gone bad and you will have to replace it...the replacement is not very hard, just make sure to mark the wires so you get them back were they belong on the new unit.
How to Buy Appliance Parts Online
Sep 18, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Whirlpool Gold Quiet Partner Model # GU980SCGQ2 The dishwasher normal light flashes on and off continually. The dishwasher won't stop cycling now, everything seems to work normally other than it won't...
Dlc737, We apologize for your concerns with your Dishwasher. If you have tried to reset from the breaker and it has not fixed the problem then we would recommend scheduling service. We would be happy to assist you further. Can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to would be happy to assist you further.
Jun 09, 2017 | Whirlpool 24 in. GU980SCG Built-in...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
See below
have you tryed leaving the power cord out of the socket for an hour or so
sometimes they don't lose the memory until they have been left disconnected for a while
Jun 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
The only number on the nameplate of my Costco-purchased "Quiet Partner IV" built-in Whirlpool dishwasher (steel insides) is 8575637. This dishwasher does not clean spoons right-they always have dirt left...
Yes, you almost certainly have a Whirlpool Gold Quiet Partner III Model #8575637
Of course the great news with buying from Costco is the ability to return products you are dissatisfied with. Check with the customer service desk.
Please reply if you want to to get into repairing it and we will get under way.
Mar 31, 2009 | Whirlpool Gold 24" Tall Tub Built-In...
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
67 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
