Question about Jura Capresso Impressa S9 Coffee Maker/Espresso Machine
Empty tray light on after tray is emptied - Jura Capresso Impressa S9 Coffee Maker/Espresso Machine
Our tech guru in work came up with a bizarre solution to this problem. he covered one of the contact points on the tray with clear sticky tape, his theory being that because the contact point was cold, the machine thought it was water and hence the tray was full. either way, it worked!
Posted on Sep 13, 2012
  • AP71
    AP71 Jun 05, 2014
    Worked a treat! Coffee at last!
It was a last ditch effort and a crazy idea but the clear scotch tape worked for us too.. Not on the left contact but on the right only! YAY!
Posted on Aug 03, 2013
I had same problem. Clean and dry the two metal prongs in the back of the tray with folded paper towel or q tip. Be patient it will work with repeated application.
Posted on May 12, 2011
2 Suggested Answers
  • 4 Answers
SOURCE: Tray empty message
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really skanky!.
If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch. This will be probably gunged up with coffee and the switch will be stuck up, get a can of WD40 and squirt a small amount up into the switch then poke the switch with a small screwdriver up and down until it moves smoothly.
Then replace all the bits, sit down, look smug and have a coffee cos you've fixed it!! :0)
Posted on Oct 13, 2009
Message 'Empty trays constantly displayed, although trays were emptied
Xerox Workcentre 7855 Bypass Tray 5 empty - Customer Support Forum
forum.support.xerox.com/t5/Hardware/...Tray...empty/td.../14901...
XeroxSep 29, 2014 - All my 7855 have the Tray 5 (Bypass) is empty. message. .... as there is no paper in it the message will always be displayed in the driver here:. Error message-Paper Tray is empty
Dec 8, 2011
Phaser 3600 reports as paper try empty
Oct 20, 2011
8560 waste tray error
Dec 13, 2010
More results from forum.support.xerox.com
empty drip tray Questions & Answers - Fixya
www.fixya.com > Forum > Tags
But now the display shows "Empty the drip tray" constantly. ... Empty Drip Tray message Getting the message "Empty Drip Tray" even when the tray is completely .
Nov 21, 2015 | Office Equipment & Supplies
My tray is empty and clean but empty tray keeps coming up
Hi Shoba
Photo sensor or switch is blocked.
Not sure if yours is an Infra Red beam or switch
Clean & inspect with flashlight
Look for light path (blocked) or moveable part (switch)
Actually.... it must use an Infrared Light Emmiter to shine through the grounds holder to the sensor on the other side/
10 Minute Fix.... I hope
Feb 20, 2015 | Jura Capresso Impressa Coffee Makers &...
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
Barista supremo thinks it doesn't have coffee beans
http://www.espressotec.com/media/downloads/57/SA1260_Odea_Giro_plus_manual.pdf The red light comes on, doesn't it? The light indicates that the water tank could be empty or the drip tray is full. Tell the coffee machine that it has enough beans, but to please the machine you will fill the water tank and empty the drip tray. Good luck, kolbrun
Sep 10, 2013 | Saeco Odea Giro Plus Coffee Maker
Empty Tray
@Derekns74 How do you remove the switch? My C3000 also reads "EMPTY TRAY" constantly, even if the tray is empty and clean. It does not display the "EMPTY GROUNDS" error only "EMPTY TRAY"
If I remove the tray it display "TRAY MISSING" but whenever I insert the tray again, it reads "EMPTY TRAY"
On one occasion when our power went out, it fixed the machine, so that it stopped reading "EMPTY TRAY," but after a day or two it stopped working and displayed the same EMPTY TRAY error message again.
Aug 04, 2013 | Jura Capresso C3000 Espresso & Coffee...
SOURCE DISK EMPTY-- when there is master disk in there
The solution to this is simple. On the menu when you see that the # of MB is 0MB. Press the Arrows that change the menu option to #8 Select Source. Change this back to your original DVD-Rom or RW drive.
Jul 26, 2009 | Acard Technology (ARS-2030LD) DVD±RW...
Red Light 28 is flashing even when dregs are emptied
Check the edge of the container that goes in to the machine there is a small part that sticks out, it is possible that that piece is not touching the microswitch in the machine. Remove the drain tray and the dregs tray, check the corners of the machine for loose coffee grounds.
May 31, 2009 | Gaggia Syncrony Compact Coffee...
Why does it take hours for the empty water light 2 go off
take that water pump off and clean it.this worked for me
Jan 22, 2009 | Hotpoint TDC32 Electric Dryer
Lexmark T632 top tray is ejected when empty
Set tray 2 to be default tray. When this is empty, the printer moves to tray 3, and then on to tray 1.
Nov 21, 2008 | Lexmark T632 Laser Printer
Saeco Espresso machine - Empty drip tray (all the time)
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Jul 11, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Jura Capresso Impressa S9 Coffee Maker/Espresso Machine Logo
890 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
