Question about Raypak Spapak Electric Spa Heater - Els552 - 2 - 5.5 Kw
Raypak spa heater not turning on, checked all circuit breakers..fine the light that lights when in on position does not come on. When I turn temp control I do not hear heater kick in. Cleaned skimmer and filter to increase flow still doesn't work
  • 31 Answers
Probably a relay.
Posted on Mar 31, 2011
What is a high limit condition
temp sensor failure. when sensor read temps that are way too cold or way too hot
Apr 21, 2014 | Raypak 2100 Pool Heater Gas 266000 BTU'...
I have a Raypak RP 2100 R405 pool heater. When I
Yes its faulty PC board.As no Power Coming from the board.Click this link directly to get PC board. http://www.a1poolparts.com/-strse-Heaters--dsh--Parts-cln-Raypak/searchpath/1015892/start/61/total/103/Categories.bok ------------------ To confirm the fault in PC board. Check for exact 24 volts on PC board. One yellow and One Blue wire. --------- For checking transformer check 120/240 volt to transformer(time clock circuit breaker wire connections). Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 10, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
The heater is not turning on . digital display doesn't light and I dont hear the heater turning on.
Check for voltage (110/or 220) at the Circuit breaker if you are comfortable doing this. Then check for voltage on the secondary side of the transformer inside the heater.
Jun 11, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Heater works intermittently
Sounds like it needs to be cleaned. Seen many over the years act the same way.
Aug 19, 2009 | Pool & Spa
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Pool Heater
check to see if ignitor is lighting if so check gas line to ignitor if no ignitor replace and check safety circuit
Nov 05, 2008 | Raypak DOOR ASSEMBLY
Raypak Spapak Electric Spa Heater - Els552 - 2 - 5.5 Kw Logo
136 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
