Question about Whirlpool 24 in. ADG7540 Built-in Dishwasher
I have Whirlpool Quiet Partner III dishwasher, Model number GU2400XTPS3, Serial number FS1820245. I recently had the thermal fuse replaced by an authorized service repair person. My problem is that the dishwasher stops mid-cycle. I noticed that when I try to clean it in the normal cycle, the dishwasher stops with about 46 or 47 minutes remaining, and the green light flashes continuously. I have pressed the Normal and Heated Dry buttons, as well as the Sani Dry and HEated dry buttons to reset the control board. This works to stop the green light from flashing but when I try to clean the dishes again, the same problems occur (stops midcycle, green light flashes), dishes are not clean. Can anyone help me? Thanks!
SOURCE: i have a kenmore dishwasher mode 665.16032402
I have the same problem. I have to go through the test mode at least three times just to wash one load of dishes. This dishwasher is a lemon. Sears she recall it. The techs say that they have at least 50 calls a week with the same problem. We need to hire a lemon law attorney and sue the pants off them. If you here anything email me please.
NewJackSwg@aol.com
Posted on Jan 22, 2008
  • 77 Answers
SOURCE: Won't run - normal light flashes
You may try removing power to D/W for a minute and reconecting. likely cause though is keypad (console). If a light above a pad stays on the pad is likely closed all the time. Normal is probably cycle most often used. you can test the keypad by removing power to D/W and accessing the control panel. remove conncter P-1 and using an ohmeter test resistance between 13 and 4 on the connecter coming from keypad. yes without very small clips or 4 steady hands it is a little tricky. in the field we use a breakout board. if you get any reading when not pushed pad is bad. you may find a manual inside the kickplate which explains the keypad sequence. it may be control but more likely keypad, even if test is inconclusive.
Posted on Jun 07, 2008
When I had this problem, it turned out to be the heating element.
Posted on Aug 16, 2008
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite dishwasher Options light up but nothing runs.
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers.
The problem is usually attributed to water supply temperatures being too low when filling.
Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models).
There is a reset sequence that you can try to clear the fault.
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times.
The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button.
This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.
This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line).
The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits.
If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is.
The flashing light will be a series of flashes, followed by a pause.
If you indeed have a component problem, it will depend on the number of flashing lights in the sequence.
Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a whirlpool quiet
The control board has failed.
CLICK HERE to see the parts breakdown.
CLICK HERE to see/order the part
Open the door & remove the 8 or so allen screws. The board is simply plug and play.
Bad design - the vent is right by the board - so its subjected to moisture.
Thanks!
Posted on Nov 15, 2010
Whirlpool quiet partner III unresponsive. "Washing" and "cancel/drain lights glow dimly. Performed reset and diagnostic mode procedures. No response.
Hello Philip,
We are sorry for the frustrations you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, street address, zip code, model & serial number, date of purchase on the appliance and a brief description of the problem you are experiencing. Thank you.
Best Regards,
Whirlpool Social Care Team
May 20, 2018 | Whirlpool Dishwashers
Whirlpool Quiet Partner III Will not drain at the
It sounds like the control unit has gone bad and you will have to replace it...the replacement is not very hard, just make sure to mark the wires so you get them back were they belong on the new unit.
How to Buy Appliance Parts Online
heatman101
Sep 18, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Whirlpool Gold Quiet Partner Model # GU980SCGQ2 The dishwasher normal light flashes on and off continually. The dishwasher won't stop cycling now, everything seems to work normally other than it won't...
Dlc737, We apologize for your concerns with your Dishwasher. If you have tried to reset from the breaker and it has not fixed the problem then we would recommend scheduling service. We would be happy to assist you further. Can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?We would be happy to assist you further.
Jun 09, 2017 | Whirlpool 24 in. GU980SCG Built-in...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
See below
have you tryed leaving the power cord out of the socket for an hour or so
sometimes they don't lose the memory until they have been left disconnected for a while
Jun 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
The only number on the nameplate of my Costco-purchased "Quiet Partner IV" built-in Whirlpool dishwasher (steel insides) is 8575637. This dishwasher does not clean spoons right-they always have dirt left...
Yes, you almost certainly have a Whirlpool Gold Quiet Partner III Model #8575637
Of course the great news with buying from Costco is the ability to return products you are dissatisfied with. Check with the customer service desk.
Please reply if you want to to get into repairing it and we will get under way.
Mar 31, 2009 | Whirlpool Gold 24" Tall Tub Built-In...
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
145 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
