Question about Whirlpool Washing Machines
Only the bottom part of the agitator works the top does not move and the clothes dont circulate
    Problem Solver:
  • 4 Answers
Needs dogs
Posted on Mar 27, 2011
The agitater is not solid and clothes catch under the arms on the bottom and tangle and have even ripped. What can be done about to stop this? It seems like a design flaw to me.
It is not the best of designs.
Sometimes, clothes will get stuck at the bottom when the agitator dogs are worn out. Check to see if the upper part of the agitator is working during the wash cycle. If it isn't, the clothes stay at the bottom and just move horizontally, not from the bottom to the top. The clothes then get stuck in the gap between the lower agitator vaens and the bottom of the agitator. This is a very easy repair, you need only a socket wrench set (SAE) with an extension.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/2744
You can also buy the dogs (pawls) by themselves in a pack of four for about $5.
When I first saw this agitator set-up, I asked myself, 'What were they thinking of?'.
Good luck.
Mar 09, 2011 | Estate TAWS800JQ Top Load Washer
Only the bottom agitator works, not the top
replace the dog ears in the upper part of the agitator not expensive and not hard to do ,,,, pop the cap off the upper agitator remove the 7/16 bolt and lift off the upper part and replace the plastic dog ears and reinstall!
Mar 08, 2010 | Kenmore 12502 Top Load Washer
Agitator: bottom moves, top does not
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
On the Sears parts site:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691&pop=flush
replace the 110.26902691 with your model number (lift the lid and the model number should be printed on the cabinet) and look at the section on the Sears site for Agitator, basket and tub.
This is what they look like:
pd_26_110_80040?$pddetailsth$ #21 on diagram Dog, agitator (4) Number:3366877Substitution:80040 $9.25Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Sep 13, 2009 | Kenmore 23822 Top Load Washer
I have the dog agits to replace Whirlpool top load washer LLR6233AWO I have the dog agits to replace in my top agitator and cant figure out how to take the top off the bottom
On mine I pulled on the fabric softener plastic top.And under it was a cap. I pulled the cap off and looked inside to see a bolt (I think it was a 1/2" size. I needed a 1/2" socked and a 6" long extension and took the bolt completly loose. Righty tighty ,Lefty loosey. Then I just pulled up on big center plastic part and the dogs are under it. I hope this helps you.
Sep 04, 2009 | Whirlpool Washing Machines
Whirlpool washer does not agitate/wash but the spin cycle seems to work. I've found that the bottom section of the agitator blades are turning but the top section does not turn. I can also turn the top...
The problem that your washing machine is not agitating, you will need to check certain things.
Please check the timer to see if it is in good working order or not. Next you will need to check the motor and the motor switch. On some of the newer washers the door switch also controls the motor.
If the motor starts running after the washer has filled to the selected level, but the agitator doesn’t move, you will need to check the following parts.
The agitator dogs. They are located inside of the agitator clothes mover. You will need to remove them and check to see if they are in need of been replace.
The clothes mover. This part is the top part of the dual action agitator. Its job is to move the clothes from the top of the spin drum to the bottom part of the agitator.
You will also have to check the inside of the clothes mover to make sure that the gear like cuts are not worn out.
However another problem could be a broken motor coupler.
Thank you for contacting Fixya.com
Aug 09, 2009 | Whirlpool Washing Machines
Lint from washing machine
Fill the tub to the bottom of the agitator with hot water and add 1/2 to 1 gal of white vinager and let it sit for a few hours. Spin out the water and run thru a light load without clothes. When you are running a load lift the lid and observe the clothes movement, The items should be circulating from top to bottom. If they are just wiggling around it is overloaded and the clothes do not have room to move. This wears on the fabric creating lint. The agitator is for the water not the clothes contrary to popular belief. The clothes are actually washed with the water movement not beaten by the agitator.
Eric
Jul 02, 2009 | Washing Machines
Agitator won't work
you need to replace agitator dogs,they are located in agitator.pop top off and one bolt holds it to tub,remove bolt and remove agitator.pop top part off agitator and you will see little plastic agitator dogs.should be 4 of them.that is what grabs agitator to circulate your clothes.very cheap part to replace.
Mar 09, 2009 | Kenmore 20722
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Top Agitator is not moving
This washer has a set of cheap plastic dogs that grab the inside wall of the upper agitator to move the clothes downward and help them get a better cleaning. The older style These dogs will wear out. To test whether or not these are bad just grab the agitator while in wash mode. The dogs should advance the top portion easily. If not then they are worn out. To replace them you must remove the agitator and sit it on the floor. Hold the base down with your feet and yank the top upwards. After seperating the 2 pieces you simply install the new dogs and line up the bottom with the top being careful not to break the little tabs on the bottom agitator that hold the top in place. The newer style you simply pop the cover of the agitator and use a 3/4 drive extention to unscrew the upper agitator. replace the dogs and put the top back on. Nothing could be easier.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 30, 2008 | Estate TAWS800JQ Top Load Washer
Washing Machines Logo
19 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
