Question about Roper 24 in. RUD3000 Built-in Dishwasher
Water is holding up inside the dishwasher where the water drains
  • 822 Answers
Pump or pipe blocked...................
cheers
Posted on Mar 27, 2011
  • Roper Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Water drained out of tube, but dishwasher stops and indicators tell me "drain is plugged."
The drain hose on a dishwasher must be long enough to go up above the water level of the dishwasher and then back down to connect to the sink drain. This is to keep gravity from draining the tank. However, you probably replaced the drain hose the same way it was originally.
Try checking the float and float switch for smooth operation. Maybe the float has debris holding it up from dropping to the true water level.
Jan 10, 2014 | Asko 24 in. D3450 Dishwasher
Dishmachine will not hold water. Its draining as you fill it?
0
Does not hold water Faulty #3 micro switch (drain) Replace switch, P/N 00411.00
Clogged or defective drain valve Clean and/ or replace drain valve, P/N 04113.00
Nov 11, 2011 | Cma Dishmachines L-1X Dishwasher
My dishwasher is leaving water in the bottom after finished. The dishes are not cleaning. Are the two related?
Yes more than likely you have a restriction in your pump/drain. you will need to remove the drain cover in the bottom of the dishwasher and clean it out
  • Empty the dishwasher and remove the dish racks so that you can easily locate the drain inside your dishwasher. The drain is under a drain grate, usually at the back of the dishwasher.
  • Remove the drain grate by either popping the grate out, or by unscrewing the screws holding it in place. Different types of dishwashers will have different options.
  • Use the soapy water and the toothbrush or scrub brush to clean inside the drain area and the grate.
  • Rinse the drain area with clean water. Then replace the drain grate.
  • Pour ½ cup of salt, 1 cup of baking soda and 2 cups of vinegar into the drain (in that order). The mixture will bubble. This will clean the drain and the drain hose.
  • Wait until the vinegar/baking soda mixture has stopped bubbling. Then pour 1 cup of bleach into your detergent dispenser. Replace the dish racks and run the empty dishwasher on a regular cycle. This will clean the entire machine
  • If this does not solve the issue your drain hose may be plugged or crimped and lastly your pump may be failing.
    Feb 11, 2011 | Microwave Ovens
    Not cleaning
    If the water doesn't drain from your dishwasher, check these:
    1. Drain line/air gap A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
    2. Pump You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
    3. Drain valve/solenoid The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
    4. Belt A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
    5. Motor Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
    Nov 06, 2009 | Bosch Classixx WVF 2402 Front Load...
    Why water not draining?
    sometimes its not the filter. look for the drain hose that connects to the drain pipe (normally under your sink inside your cupboards).
    Disconnect the drain hose and look inside where it connects to, most of the tim it blocks up in this area.
    Sep 11, 2009 | Hotpoint Dishwashers
    Will not pump water out of the bottom of dishwasher
    UNPLUG THE DISHWASHER. Inside the dishwasher is a covered drain, usually covered with a plastic guard to prevent large objects from getting into the drain. Remove the blades in the bottom (careful but on my GE they come off with a firm pull) Remove the drain cover and see if the drain is plugged. If it does not appear to be plugged, you may have a bad drain pump. This usually requires you to remove the dishwasher but on some you can access it by removing the bottom plate. You then can disconnect it from the dishwasher drain by loosening a band that holds it firmly to the pump housing. Be ready with something to catch the water as it drains out. If the water inside drains out then your pump is bad. Because the water inside drained out, that tells you that the drain to the pump is clear. Your dishwasher has a drain pump that moves the water out. You will need to remove it, check it for obstructions and replace it. If it still does not work, you will need a new pump. There are two water connections to the pump, one for the flow from the dishwasher and another for the flow out. There are two electrical connections that you will have to remove.
    Jul 29, 2009 | Dishwashers
    My G E Power1 Dishwasher is holding in alot of water,I know a little is normal.There is a lot and the water it feels slimmy.Just 2 yrs old well takeen care of.HELP
    Check the following areas for faults. This is an apparent drainage issue.
    1. Air gap / Drain hoses
    If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
    If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
    Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
    2. Broken belt
    Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
    Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
    3. Pump
    Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
    4. Drain solenoid
    Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
    5. Motor
    If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
    Replace the motor if defective.
    Jun 24, 2009 | GE Dishwashers
    Check water light is on
    I had the same problem! First disconnect mains power, then switch off the mains water to the water input hose, and disconnect the hose. Disconnect the waste outlet hose from your drainage. ( this will release some water from the hose ends, so a washing up bowl would be handy ) You will need to tip the dishwasher on to it's back, be carefull not to damage the waste outlet hose, and watch out from more water spillage. Next remove the two screws on the base metal cover, and spring out the cover from the two side clips, the cover can then be removed, you should have a screw holding an earth lead remove screw and lead from cover.
    Inside the bottom of the dishwasher you will see a small electric pump fitted to the side of the dishwashers drain, it has two wires with spade connector on them, disconnect these from the pump noting colour of the wires for reassembling. The pump has the same diameter hose as the outlet hose. Next carefully remove the rubber elbow pipe from the pump and hose end this will need to be washed with clean water. Then to remove the pump, press and hold down the locking tab, where the pump is fitted to the drain, and twist the pump anti-clockwise. The pump will then release from the drain. Inspect the pump impellers for damage, and that the pump has free movement, also check condition of the rubber O-ring. Inspect inside of drain for broken bits of china and glass, remove and clean, also check the outlet hose for any blockages.
    ( run some water though the hose backwards from the water tap and collect it in a bowl from the pump end of the hose ) Reassembly is the reverse of the above, check electrics inside have not got wet, if ok switch on. The check water light should now be off.
    Alan
    Jan 11, 2009 | Bosch 24 in. SGS43C12 Classixx...
    Problem with Kenmore dishwasher model# 15762000
    replace the water inlet valve, something is inside the valve holding it open, dirt small grain of sand, ect.
    Apr 10, 2008 | Dishwashers
    Indesit dishwasher DV62
    You have a blockage in your drain pump. Remove all filters and scoop out as much water as you can from the unit. Check in the bottom for any objects stuck there. Some models have a cover on the bottom inside the unit, which once removed, will expose the drain pump impeller. If yours does, remove the cover(usually 1 screw only) and free the drain pump impeller. NB: DO NOT REMOVE THE SCREWS WHICH HOLD THE BASE TUB IN PLACE! These are the screws on the edge of the white plastic "bowl" inside the unit. The drain pump cover will be INSIDE this bowl and will be quite small, no more than 5cm dia.... If this does not work, you will have to remove the drain pump from the bottom or front of the unit to get the blockage out. Oshie
    Jun 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
    Roper 24 in. RUD3000 Built-in Dishwasher Logo
    164 people viewed this question
    Top Roper Dishwashers Experts
    Mike
    paul
    paul
    Adzhall
    Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
