Question about Indesit 24 in. IDL700 Built-In Dishwasher
Water wont drain - Indesit 24 in. IDL700 Built-In Dishwasher
  • 822 Answers
If pump is working then theres a blockage in the pipework or drain...........
cheers
Posted on Mar 27, 2011
Wont drain..door locked..what do l do?
put drain hose below water level when empty should spin
Apr 17, 2015 | Washing Machines
My dishwsaher wont drain water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 10, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
My washer has gone through the cycle and the door will not unlock. Please help.
TYpically the door wont unlock due to not all the water draining from the tub so the water level switch isn't satisfied the water has drained and wont allow the door to unlock.
The most likely problem is that the drain pump screen is clogged so its not draining and if it isn't draining it wont spin.
To check the pump remove the lower panel and the lower right side will be the pump, unscrew the big white cap a little and use towel(s) to catch the water that comes out ,when all water out remove completly and check for blockage.
GENE
Aug 28, 2011 | Kenmore HE2 Plus Front Load Washer
Water wont drain
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 12, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
My wf t1001tp wont drain...can anyone help?
sounds like a blocked drain hose or a faulty pump motor..If the machine can be drained by putting the drain hose lower than the water level then the hose is not blocked and it may be the pump...Make sure the hose leaves the machine from under the tub and not high on rear of washer. Obviously water won't flow uphill..If the pump has failed a new pump motor is much cheaper than buying a whole new pump....Nomess
Apr 04, 2010 | LG WFT1071TP Top Load Washer
Whirlpool #907026 filled with water and wont
It is most likely that there maybe something blocking the drain. Check the pump and make sure there is nothing inside it preventing the water from draining properly
Mar 21, 2010 | Whirlpool Washing Machines
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Water just drains, wont fill up washer
the top of the hose must be higher than the water level in the washer for proper operation
or
the drain house should be loose yet fit securely. do not seal the drain hose with tape the hoese needs and air gap
Apr 17, 2009 | Washing Machines
Wont drain or spin is lock up
does not spin all water out, towels are still wet, not overloading, could it be the timer?
Mar 01, 2009 | Estate ETW4400VQ Top Load Washer
Indesit 24 in. IDL700 Built-In Dishwasher Logo
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
