Question about Beko TLDA662
It doesnt work long enough. just 40 minutes and then cut off only to start again after hours. it rarely retain frost.. pLEASE HELP
  • 2,133 Answers
Please check gas pressure. There is short of gas or no gas in the system. Due to this compressor is getting overheated and taking longer time for restart.
And due to above, no frosting retain or good cooling in fridge compartment.
Hence, call repairman to check leak test and rectify.Thanks.
Posted on Mar 28, 2011
Starts great but cuts out after 30/40 minutes wont start again for about 1/2 hours.
Possible Ignition control module ,crankshaft position sensor
Sep 06, 2015 | Cars & Trucks
The engine on my 2000 MPV cuts out and dies when I press the accelerator. After it sits for an hour or so, I can travel for 20 min. or so before the problem starts again. HELP!
if its been a while change the fuel filter and then have the fuel pressure and volume checked.these symptoms are very common for a fuel pump problem.
Feb 07, 2012 | 2000 Mazda MPV
ER203 NOT CHARGING,INDICATE THE RED LIGHT.WHAT IS THE PROBLEM PLEASE.
Your Trimmer uses Ni-cd battery, which provides 40 minutes of shave time with one full charge of 8 hours. It seems that either your battery is dead or the cutting element is clouged. I'd suggest that you wash the cutting elements with warm soupy water and then try to turn it on again.
If that doesn't work, your battery is probably dead. If the unit is within warranty, you can contact Panasonic support for a replacement or else try replacing batteries with the help of a local technician or a repair center.
Hope this helps..
Mar 06, 2011 | Panasonic ER 203 Beard Trimmer
Doesnt get cold n freezer doesnt freeze
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Feb 07, 2011 | Siemens KS30R423 Refrigerator
After thanksgiving, and loading the fridge with cooked food, after a couple of days water started accumulating under & in the vege drawers. How to correct?looks like the hing in top center of...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Dec 10, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
My Toshiba 32wlt58 cuts out every ten minutes.
I have just had that problem. Repairer said it was a chip in the power supply. Just got the set back this morning, ok for about 6 hours then cut out. Felt quite hot on LHS Will switch on again after a while, then cut out again. Suspect overheating problem took out PSU chip. Chip replaced but original fault still present
Oct 04, 2009 | Toshiba 32WLT58 32 in. LCD Television
Ice built up in the frost free freezer section
It sounds like the freezer fan(evaporator) is wearing out. This problem is very hard to diagnose because the fan spins but no fast enough to circulated the chilled air thru the freezer and refrigerator. The parts and labor are around $300.00
Aug 01, 2009 | Freezers
The freezer automatic defroster element is not coming on enough to prevent ice build up on frezzer coils. Is there a way to trick system to make the hot coil work more. Often?
If yours is not staying on long enough the defrost thermostat may be defective and cutting it off too soon. It's clamped to the evaporator coil.
You have an adaptive defrost control which determines when and how long to defrost. I could be malfunctioning.
Jul 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer is "frosting over...refrig part not cooling????
it sounds like the defrost system is not operating and getting rid of the frost. the common fault is that the defrost heater has gone, or the heater cut out has gone or the defrost timer is faulty. how is the door seal in the area- that can cause frosting with warm air ingress.
Mar 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
WHIRLPOOL NO-FROST REFRIG/FREEZR MODEL-EHT201ZKWR5
looks like operating normally...
the fridge as it reaches it's temperature shuts the compressor off and then after a few minutes..the fridge would increase temperature again and would turn back the compressor again.
its the thermostat which is cutting on and off the compressor.
and i think it is normal. based on the temperatures that you indicated..it is cooling very well..0 F in the freezer and 40 in the refrigerator... that's good.
drcool
Nov 06, 2008 | Whirlpool Refrigerators
Beko TLDA662 Logo
Top Beko Refrigerators Experts
AJMAL KHAN
ray gallant
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
