Question about Vacuums
Hello! I purchased the cascade 170 internal filter for my tadpole this past Tuesday. All seemed to be well until I returned home from work this Sunday morning to find him dead. There was a film of little white bubbles all of the top layer of the water. The filter was submersed however it appeared that some of the water had evaporated but was still over the top of the filter. Is there a problem with the filter or the level of water? I'd like to get another tadpole but would like to know what went wrong before I do so. Thanks, Melanie Carter 540-204-2357
New canister filter not keeping tank clear. Why?
take a sample of the tank water to your good pet shop and have the water tested as filters only remove the solids but do nothing for the phosphates and nitrates in the water.
Jun 07, 2015 | Penn-Plax Cascade 700 Canister Aquarium...
How do I clean and with what,a Hoover elite lifetime hepa filter?
Hello! Please follow the instructions below to clean the lifetime Hepa filter on your Elite Rewind.
1. Press on the tab located on the side of the filter cover to remove.
2. Remove the HEPA filter and brush with the combination tool to clean or tap side of filter against a trash receptacle. Return the HEPA filter into the filter cavity.
3. Align tab on filter cover with slot. Press cover closed until you hear a snap.
Hope this was helpful!
Jun 09, 2014 | Hoover U5507900 Elite Rewind Bagless...
The brush does not rotate for cleaning rugs.
have you tried pusing in the little red buton on the side of the brushes cos if thats out they wont work
Jun 05, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
When I switch off my Vax G3 cylinder cleaner it trips out the whole of the ring main circuit - I think the on/off switch is defective and wonder how much it would cost to repair and who - it is just over a...
Hello Lyra_cross, if your machine is in warranty please call the Vax Careline on 0844 4128 455, with your machine and receipt available, and an Advisor will be able to help you arrange a repair/replacement free of charge; if you do not have proof of purchase, Vax can provide a £60.00 repair service which includes collection by courier, inspection and then either repair or replacement and then return to you, again by courier, with a 12 month warranty.
The Vax Careline is open every day, from 8.30am until 6.30pm, Monday to Friday, and 9am until 5pm on Saturday and Sunday. Outside of these times please check the website support section which includes videos to demonstrate how to deal with everyday problems such as changing filters and belts and checking for blockages. With best wishes, The Vax Team
Mar 13, 2010 | VAX Appliances Vacuums
How to change a filter on hoover turbo
Here is a link that has manuals you can download. There are 6 pages for Hoover vacuums. Go through the pages until you find your model. The manual will show how to change filter.
Hope this helps.
Aug 24, 2009 | Hoover Vacuums
Bissell easyvac filters
Replace Filter
As you vacuum, dirt and debris are deposited in the Dirt Cup
while air passes through the filter before being returned to
the room. This process enhances the vacuum path while
dramatically reducing dust, dirt, and potential allergens from
the air you breathe. Replacing the filter periodically enhances
vacuum power and air quality. To replace the filter:
1. Remove the Dirt Cup.
2. Grasp the filter frame and pull it straight from the Cup.
Empty the Cup.
3. Replace the filter. Push new filter into place at the top of the
Cup, place the small tab at the bottom of the Cup into the
slot at the bottom of the Canister cavity, then press the upper
portion of the Cup into place until the lock button snaps
into place. Use only BISSELL Style 6, #32047 Filters
[package of 2] in your BISSELL EASY VAC™ Model 3101-0.
4. EASY VAC™PLUS Model #3102-0 features a high efficiency
3M Filtrete™ Filter. To keep your cleaner operating at peak
efficiency and to remove irritating allergens from your
home, you should change the FILTRETE™ filter every six
months. Use only BISSELL Style 6, #32046 Filters [package
of 2]. The cup-shaped filter lifts out from the top of the
Dirt Cup, and the new one fits into place.
You may purchase these filters
by calling
BISSELL Consumer Services
Monday - Friday 8 a.m. — 7 p.m. EST
Saturday 9 a.m. — 2 p.m. EST
or from the BISSELL website —
Jun 29, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
Hoover fusion plus cyclonic upright vacuum
While I'm having a different problem, the problem you guys are experiencing can easily be fixed by cleaning the two internal filters. My vacuum did the same thing, just stopped running mid-stream. Remove the main filter cup. Look inside the cavity of the vacuum and you'll see a grey bar at the bottom of the cavity, pull this up and you'll find the first of two washable filters. Just rinse it under warm water squeezing as you rinse until the water runs clear. The roll the filter in a few paper towels or towel and unroll, reroll until completely dry - should only take a few minutes. Then, look in the same cavity except up top there is another filter which seems to be hidden. The back wall of the inside cavity will guide you to these filters as well. You will be amazed by the difference cleaning these will make in the suction power of your vacuum. Also, if you remove the belt cover and clean out the hose in this area it will improve suction as well. Hope this helps. Now, if I could just get the darn belt back on mine. First belt smoked and popped. Bought replacement belt, smoked and popped within seconds... HELP!!!
Dec 16, 2007 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Vacuums Logo
150 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
