Question about Sony PS-LX250H Turntable
Belt is out of position use it when it wasnt unplug it
  • 61 Answers
Replace the belt with a new one or re-aligned the existing one see the video below
http://www.youtube.com/watch?v=bqVRrkXdlME
Posted on Sep 28, 2011
How to fix 0016 code
Did you need to unplug either harness to due the timing belt? Possible the cam timing is off by a tooth and putting everything out of synch
Apr 05, 2015 | Cars & Trucks
Detrola cd player spins too fast
Did you undo any leads when you changed the belt, are they in the correct position, it's spinning fast because it can't focus.
Aug 29, 2014 | Televison & Video
Kia rio not starting
Timing belt should have been changed at 60,000 miles. A loose timing belt or teeth missing from synchronous belt will lose timing. Damage to valves can occur if timing is not correct.
May 29, 2017 | 2004 Kia Rio
How to troubleshoot noise coming from dryer
A whining noise could be either a worn drive belt on it's way out or a piece of clothing trapped at the back of the drum. To check this, you can unplug the machine, unscrew the lint trap on top of the dryer and using a flathead screwdriver, pop the top off the dryer. Once the top is up, you should be able to inspect the drive belt and be able to feel around the back of the drum for any debris or clothing. If the belt requires replacement, you will need to unscrew the front of the dryer to get the front panel off.
Dec 16, 2011 | Whirlpool Washing Machines
How to tell if a camshaft position sensor is bad?
Check the pins in the cam sensor,one might be bent and not making a good connection.I am assuming you did not have a cam sensor code before unplugging the sensor.
May 30, 2017 | 2004 Kia Rio
I have a problem in my canon IR105 it started with a paper jam at the finisher, when i solve that it gave me and error code : E000578-0002 and ask me to shutdown and restart so i did that, but the error...
The knurled belt motor is faulty. The knurled belt home position
sensor is faulty.
Condition
0001 The knurled belt motor does not return to home position when the
knurled belt motor is driven for 1 sec or more.
0002 The knurled belt does not leave home position when the knurled
Check motor and sendor in the finisher, if not solved - there are an technician required to set sensor, deatach the finisher from the copier & unplug their socket from copier and operate copier without finisher when technician not come.
Mar 04, 2009 | Canon imageRUNNER 105 Copier
HOW DO I ?
You probably need to thread the new belt over the drum by removing the circular rubber front seal temporarily. After putting the seal back on, ease the belt into the correct position and thread over the pulley on the motor. You will probably find it easier to put it over the pulley wheel of the motor first, with the belt partially off the drum. Then rotate the drum manually whilst easing the belt over it.
Mar 24, 2008 | Dryers
Sony PS-LX250H Turntable Logo
18 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
