Question about Brother Sewing Machines
Needs a new shuttle machine No XL2230 part no xc3152-021
2 Suggested Answers
Plastic shuttle not slotting into brother XL-2220
Look in your book or download one for the XL2230 (nearly the same as the XL2220) here:
http://www.brother-usa.com/VirData/Content/en-US%5CHAD%5CConsumer%5CUsersManual%5CUM_XL_2230_EN_205.PDF
Apr 07, 2014 | Brother XL-3510 Mechanical Sewing Machine
Needle hitting the shuttle
since you were sewing harder material it's possible that the
machine jumped time & needs to be checked at a sewing machine
shop
but try putting in a new needle first
if it still is hitting the shuttle then it needs to be checked.
Oct 16, 2012 | Singer Sewing Machines
How to remove brother XL2230 sewing machine case
Take off the panel that conceals the lamp (see your instruction manual) and you will see another screw that needs to be removed before you can take the larger back panel off.
Jun 15, 2012 | Brother XL-2230 Mechanical Sewing Machine
My New Home 346 Sewing machine thread gets caught in shuttle
Make sure you have the correct shuttle for your machine. Some shuttles will work in other machines, but my first reaction was that maybe someone might have included the wrong shuttle with that machine. They can look exactly alike. You can buy them on eBay. You will need the model number to order one.
Feb 21, 2018 | New Home L-372 Mechanical Sewing Machine
Help me !!!!! Got a brother XL2230, bobbin winder broken
Hi, I have the same problem, use a car 'o' ring that should fix it, should cost about
May 20, 2010 | Brother XL-2230 Mechanical Sewing Machine
I have an old white sewing machine that works wonderful. I didn't get it new,so I don't have a instruction book with it. I think I need to adjust the tension because my thread keeps breaking..?
Thread breakage is not caused by tensions. If it is an oscillating shuttle machine ONLY, (do not do this on a rotary shuttle), check your shuttle tip for damage, if there is even the smallest damage on the tip, the thread will break. Find some 600 to 1000 grit emery paper and extremely gently remove any burrs.
Feb 11, 2010 | Sewing Machines
Bobbin and shuttle case pop out of machine .
You might need to clean the shuttle assembly.
1. Raise the needle bar to its highest position and remove the bobbin case.
2. Push levers sideways of the shuttle assembly and liftshuttle and shuttle race cove out by the center pin.
3. Clean the shuttle race of any lint or small particles of thread with a small brush.
4. Put a drop of oil on the center pin of the shuttle and on the shuttle race.
to reassemble, hold sjuttle by center pin and it carefull into assembly opposit the shuttle driver. Slip shuttle race cover into place. Snap the levers into position.
Occasionally remove the needle plate and clean feed dog with soft brush.
I hope that helps!
Apr 23, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother XL2230 Elastic Overlock function not working properly
First of all check your needle size and utility, for the tension machine it must be the same on top and bottom example pull the top thread and the lower thread they must be the same.
When sticthing the elastic you must devide the amount of elastic versus the fabric : dise the amount before stiching
Hope this will help
Good day
Feb 16, 2009 | Brother XL-2230 Mechanical Sewing Machine
Sewing Machines Logo
224 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
