Question about Toro Lawnmower 20099 Mower Mowers Lawn
Have a mower that was left out all winter so the gas is bad. mower starts but wont stay running, changed the gas and cleaned the carb a little but still same result
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 344 Answers
The trick to cleaning the carburetor is to use a carburetor cleaner and wire out the main tube or emulsion tube that feeds fuel to the engine. I always recommend putting a carburetor kit into the engine for safety.
Contact a company like www.arcolawn.com and make sure a briggs and stratton part # 498260 will fit your machine and have it shipped asap to get the job done. Good luck
Joe
Posted on Apr 08, 2011
Doesn't act like it is getting gas. Cranks but wont start. Will start if I pour gas in carboretor but won't stay running. Changed gas filter and fuel pump.
Hi: I sounds like it is not getting gas, it probably need the carburetor cleaned out. but first make sure the gas is turned on, tighten the carb . I you have left it for a long time with out running the gas out it most likely needs the carb cleaned Good Luck I hope I was of some help
Dec 19, 2015 | John Deere EZtrak Z225 Zero-Turn Riding...
Lawn mower wont start
clean out carb.
Mar 14, 2015 | Garden
Wrong gas in lawn mower, what to do
if its a briggs and stratton engine with the plastic carb fixed to top of the fuel tank then you will need to replace the diaphragm and blow out the fuel pick up pipe
Jun 26, 2014 | Briggs & Stratton Briggs Stratton...
Mower wont start changed plug still wont start checked gas line seemed okay but what is that plastic piece in the line never seen one before
Getting a mower out of its winter slumber takes some time. Start with fresh gas, new oil, and air filter. Sometimes carbs get gummed up(varnisized gas). Donyboy73 on youtube shows how to remove Briggs n Stratton in tank carb systems and clean the parts and passages.
Apr 27, 2013 | Toro Power Lawn Mower
6.25 190 cc mower wont stay started
your running out the gas in the carb out you need to rebiuld the carburator probably dirt in the carb from bad gas
Jul 22, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
I have an old Craftsman 286707 riding lawn mower that will turn over but not start - ideas of where to look - it worked fine 4 days ago for the first time this season but took about 5 tries
Did you have gas in it over the winter? I would try some starting fluid and see if its fuel related or something else.. If it will run with a little starting fluid for a minute then you have some kind of fuel issue.. Gas with ethanol blend is bad for carbs over the winter. .. I would use some really good fuel stabilizer once you get it working again.
May 05, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Like I said the mower will start but it doesn't stay running. When I prime the carb it seems like it stays running until the gas is burnt. By stated I checked the obvious I mean, there is no clog in the...
Hi it sound like a blocked jet in the carb, petrol crystallizes when left over winter time, it blocks the holes in the fuel jet, when you come to use it again next summer, best thing is to drain all the fuel/petrol from the float chamber in the carb over winter time. TO FIX IT you can strip the carb down and clean the restricted holes with a needle or fine wire to clear the blockage.if they've become blocked.
Oct 27, 2009 | Garden
My Mower won't start for more than 8 sec. I changed the spark plug, gas, oil, etc. I cleaned it inside and out including the carb. left in rain for 5 min accedentaly, cleaned, na da. Help. Thanks Craftsman...
the problem is that your carbeurator is gummed from from sitting idle all winter with gas in it. Get an aerosol can of carbeurator cleaner, remove the air filter and give the air intake two squirts of carb. cleaner. Then start the mower. When it stalls again let it sit for an hour while the carbeurator cleaner works at dissolving some of that gum. Repeat the process until the mower runs again. Sometimes there is so much junk in the carb. that you have to remove it and soak it in cleaner for about three hours, and then rebuild the carb. with the proper little kit. hopefully you won't have to take this step.
Next fall let the mower run out of gas and stall then you won't have the gum in the carbeurator in the spring.
May 23, 2009 | Garden
Wont start
Apr 04, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawnmower 20099 Mower Mowers Lawn Logo
244 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
