Question about Neff B1421 Electric Single Oven
Neff series 1 oven
The clock is flashing 0:00 and we cannot seem to set the time and also the oven is not coming on.Is this because the clock isn't set?
Also we do not have a manual.
Please help
Many Thanks
  • spwardle Aug 25, 2008
    The same problem !!!
  • carolred2k Feb 16, 2009
    thank you we have sorted it now
Press the two arrow buttons in at the same time as turning the pop out knob
Posted on Feb 12, 2009
  • Robert Blomberg
    Robert Blomberg Jul 14, 2017
    You saved my bacon (dinner, actually) with this answer. The oven wouldn't heat until the clock was working. So thank you.
My Naff U1721 bottom oven does not turn on. Top oven works o.k. The light to the left of the control knob and inside the oven does not come on. Could you tell me what the problem might be?
clock must be set for bottom oven to work not flashing 00.00 if clock set check its not on auto setting if thats ok then clock has failed will need replacement.
Jan 05, 2017 | Neff Ovens
Changing the time on a Neff oven B47CR32NOB
Press the select button until the clock flashes ( you do this by looking at the time displayed and pressing the select button as required) Use the timer set button by rotating to correct time. Once the time is displayed wait 2 seconds for it to set.
Oct 29, 2016 | Neff Ovens
I have a new Neff U15E52N3GB oven and I have to reprogram the clock each time I want to use it. Am I missing something on the original set up or is it a Naff Neff?
you are, that sounds like your setting the timer for cooking not the clock.....switch the hole thing off at the wall then put it back on, the clock should flash, then set it, check the manual for button config.
infact i just read it, & its on page 10 2nd paragraph on right hand side...........
You can only change the clock when no other clock function is
ie switch it off & back on at the wall.
1.Press the < > clock function button repeatedly until
the< > O(pic of a clock) and symbols light up.
2. Set the clock using the rotary selector.
The setting is applied automatically
Dec 12, 2014 | Neff Ovens
My Neff U1421 bottom oven has failed.
Probably the ring element. If the clock is flashing zeros or 8's the bottom oven will not operate but the top will. Make sure the clock is set (doesn't have to be the correct time, just not flashing) If the fan and light then work but no heat, defo the element part no 499003
Mar 21, 2013 | Neff U1421 Double circotherm Electric Oven
Dont know how to turn off the auto seting
Turn off the mains power. wait about thirty secs. turn back on, you should have either all 0's or 8's flashing. Looking at the clock buttons left to right. press the button fourth from left and the - or + to set the time (doesn't have to be the correct time, just not flashing 0 or 8's). Leave for second until the display is not flashing.You should be able to use the oven now. If not you may have a problem with the clock, this can happen if you have been using the top grill with the door open and the controls have gotten too hot. Neff ovens have no function where the door is left open during cooking or grilling.
Mar 07, 2013 | Neff U1721 Double circotherm Electric Oven
No power to neff bottom oven
Bottom oven is directly linked to the clock, If the clock is on but not set ie 0:00 or 12:00 flashing it won't work, set the time (doesn't have to be right, just not flashing) try oven again. If this is not the problem please contact me again and we'll look further. Cheers
Nov 25, 2011 | Neff U1721 Double circotherm Electric Oven
Clock flashing OOO continously
My son came along and managed to get the clock operating once more by just pressing one of the buttons and turning the knob to set the time. Many thanks for your contact. It was much appreciated. I shall know what to do in case this ever happens again.
Regards, Mary Yorkston
Aug 29, 2009 | Neff B1421 Electric Single Oven
Cant fix the clock to work without the timer
if you are having trouble setting the clock times etc this is probably down to a worn bit generator this is the knob you turn to set the time they get dirty when using oven or grill and wont operate properly,the clock will need changing im afraid as there no way to open the clock without destroying it.
hope this helps
Jul 09, 2009 | Neff B1421 Electric Single Oven
Can't adjust the clock on my 1442 Double Oven
Press the left button 4 times, this takes you to the time which is now flashing and can be changed with the right button. once set, leave it and it will just work from there (i.e stop flashing etc)
Apr 01, 2009 | Neff U1721 Double circotherm Electric Oven
Main oven won't turn on
I'm figuring you've probably resolved this, since you posted in November (and I've just joined the site today). However, I thought I'd post a solution just in case anyone else surfs in and finds the same problem.
We have the same sort of oven. After the power has been off, the oven won't work until you set the time on the clock. I think it's because of all the automatic timer features.
On ours, you have to press the two buttons with arrows on at the same time as turning the clock dial to change the time.
Good luck.
Nov 22, 2008 | Neff U1721 Double circotherm Electric Oven
Neff B1421 Electric Single Oven Logo
677 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Neff Oven Expert? Answer questions, earn points and help others
