Question about Linksys Wireless-G Broadband Router
How Do I Hook up lines - Linksys Wireless-G Broadband Router
    Sergeant:
  • 192 Answers
First find your internet modem cable from your high speed internet box. Unplug it from your previous router or computer. This cable should run from your internet box to your router plugging it into the slot labeled internet. Then plug in the power cord to the router and let it power up.
Next you need to go to start then control panel and select the network and sharing center. Select Change adapter settings and then right click on the wireless network connection and then left click on enable. It should find several networks and your should be LinkSys. Select this and then connect.
You should now be able to access the internet after you restart your computer.
Posted on Mar 27, 2011
Singer 3314c need help with timing
Hi the point of the hook should be in line with the needle and just above the hole in the needle with the needle 2.5mm up from the lowest needle position. The gap between the bottom line and bush should be 2.5mm in the lowest position
Sep 14, 2017 | Singer Sewing Machines
Connectingit hooking it up
The exact list of parts for a dishwasher hook-up would depend on the existing plumbing and electrical . There are three hook-ups needed; a hot water feed, typically from under the sink. A Tee is installed on the hot water line with a valve, and the hot water line to the dishwasher is connected to the valve. A drain line from the dishwasher is installed under the sink. It connects to the sink drain. The Electrical connection can be made using the appropriate electrical cord.
There are specific guidelines and considerations on how to connect the drain line under the sink, and what is required for the electrical hook-up. If you do a search on "how to install a dishwasher" you will be able to find extensive information.
2q== 9k=
Apr 10, 2014 | Dishwashers
Craftsman chainsaw fuel line and fuel filter
go to sears and purchase the fuel filter and fuel line kit for the chainsaw. in that kit will have a hook that you fish through the outside of the tank to the inside, you attach the new fuel line after attaching the fuel line to the fuel filter, to the hook, then pull it through the hole. disconnect the hook from the fuel line, cut the small piece off where the hook made the hole and attach to the carburetor. finish by pushing in the fuel filter inside the fuel tank. the kit will also have more detailed instructions and possibly with illustrations. if sears doesnt have the kit, check with a lawnmower repair shop.
Sep 19, 2012 | Craftsman Garden
Replaceing fuel line in polan 3300 chain saw
Hi owjbhend...
Use a piece of wire and insert it into the fuel line, then bend a hook in the end and hook it over the end of the fuel line...lubricate the fuel line with some vaseoline very lightly...about the first one inch of the fuel line and then use your fingers to start the fuel line into the tank, once you have the fuel line in the tank give enough to hook the fuel filter to and so it can be dropped back into the tank.
Below is a drawing of how to route the fuel lines.
Please take time to rate me thumbs up
Sep 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My son has bought a deluxe starter fishing set for freshwater fishing,and there no instructions how to set up the tackle.e.g floats weights ect.
you can put the weights on leaving about 3 feat of line then tie the hook on by putting some line through the loop in the hook and twisting it about 7 times upward and pulling the excess line through the bottom loop in the line. Or just attach the floater with a little bit of weight under it with the hook put on the same way.
Mar 06, 2010 | Dmm Fishing Tackle Box
How to hook up phone lines? on Brother MFC-5890cn I don't have a manual on where the fax lphone line goes
The phone line goes to the plug marked L or line, the one with the picture of a phone is for an answer machine.
Jan 30, 2010 | Office Equipment & Supplies
I would like to know what size water hook up ineed to hook water line to fridge
It will either be 1/4 inch or 3/8 inch. It depends on your manufacturer.
Jul 11, 2009 | Refrigerators
My hp officejet v40xi says off hook when I try to send a fax. I hear not dial tone. can you help me I am using sbcglobal service
It will say 'off the hook' if the line is in use. There should be dial tone on the line before you can fax something.
Mar 06, 2009 | HP Office Equipment & Supplies
How to hook my altec lansing speakers to my TV? and my laptop @ the same time
You can do this through a receiver (like a stereo receiver). Hook the tv up to line 1 and the computer up to line 2, then hook the stereo receiver output to the input of your subwoofer. Then shift the receiver from line 1 to line 2 (as easy as pressing a button on the front of the receiver) to hear either one through your speakers.
Nov 26, 2008 | Altec Lansing ADA 885 Computer Speakers
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
