Question about Kenmore 64802 Top Freezer Refrigerator
Water leaking from fridge roof - Kenmore 64802 Top Freezer Refrigerator
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 27, 2011
Water leaking roof
Water leaking from the roof of your CAR? That should have absolutely no effect on your engine, unless it's leaking a huge amount and flooding the whole passenger compartment. Likewise, water leaking from your GARAGE roof shouldn't have any effect unless the whole garage is flooding really pretty deep.
So... I'd say you have one problem with the roof, and a second unrelated problem with the engine not starting.
Jul 31, 2014 | 2003 Renault Renault Scenic 1.6
I have a Whirlpool fridge that needs a new water filter. Twice now, when I remove the filter to change it, water gushes out even though the ice maker is OFF. I quickly turn off the water line and mop
The Whirlpool fridge requires a water supply connection to a cold water line. Before you connect the water supply to the water line on the fridge, make certain the unit is unplugged from the wall. Press the button and drop down the cover. Then twist to release the old filter and twist the new one into the filter head. Run about 2 gallons of water through dispenser to remove any air from the lines. Liquid EPDM Rubber Roof Coatings for Roof Leaks Repair EPDMCoatings
Jan 29, 2014 | Whirlpool Refrigerators
How do I find where the leak is in my roof flashing?
If you can't see where the leak is coming from exactly you can start from where you think the leak is and lift the roof shingles if its the right place you will start to find mold under them and that's where you should start fixing the roof.
Oct 28, 2013 | Roofing
In the roof of the fridge we are getting a huge amount of water build up, which makes the roof of the fridge bow, we have to end up tipping the whole unit forwards to drain all this water out, it is taking...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 06, 2010 | Refrigerators
E440t water pooling inside roof of fridge. then it leaks into fridge when its full. fan was noisy, now not making much noise. maybe its stopped.
THE drain in freezer is frozen over and the water is leaking into the fresh food / clean drain with hot water and turkey baster . this wil correct problem . some units need a drain heater installed to prevent it from doing it again .. mm
Aug 11, 2010 | Refrigerators
Water leaking from inside the fridge
Clear ice build up from drain plug using hot water in a syringe. Works well I just did mine. Located behind access panel inside fridge. Blue tube running down the back. Pull down and remove ice from the drain at the top.
Jun 22, 2010 | Refrigerators
Water leaking from the roof of the fridge inside.
That is condensation. The rubber insulator (gasket) on the door may be damaged or worn. The door does not close and seal properly.
Make sure that nothing that is on top of the refrigerator is "hanging" into the path of the door seal (like a bread bag ponytail).
Also to consider:
Door hinge is loose so that door is not aligned for proper door seal.
Refrigerator is not "level" so that door is not ...
Freezer is defrosting (heating elements will warm up the coils, so "dew point temperature" may have been reached.
Check the door gaskets.
Sep 21, 2009 | Kenmore Refrigerators
Leak in fridge from between fridge roof and freezer, fridge is still cold as is freezer however will not stop leaking
Hi, The drain hole located in the freezer defrost drain is plugged. Get me your model # and I can assist you further.
THanks
Vic
May 17, 2009 | Refrigerators
Slow dripping water from top freezer into the main fridge
We just got rid of our 26 year old Kenmore for this reason. In 26 years I used a hair dryer to thaw out a tube toward the back of the refrigerator. At least in ours when the tube gets frozen shut the water had nowhere to go but in our egg tray.
Oct 23, 2008 | Whirlpool Refrigerators
Kenmore 64802 Top Freezer Refrigerator Logo
85 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
