Question about PUR (FM-9500) Air Purifier
Can't remove the filter from my Pur Flavor Options faucet mount water filter
I've been unable to get the the filter to come apart so that I can change the filter. Now, when I'm trying to get filtered water almost no water comes out. Please help! Thanks!
When mine gets stuck I stick the handle of a fork or spoon into the hole where the water comes out and use that to unscrew it. Works like a charm every time.
Posted on Feb 25, 2009
  • 3 Answers
According to the owner's manual -
You must relieve pressure from the faucet mount housing to ease removal of the front cover. To do this, slowly rotate the water switch until it is about half way between filtered and unfiltered positions. This will vent the pressure from the housing and allow the front cap to be easily removed for filter replacement.
I have found this to be correct.
Posted on Aug 27, 2009
On the PUR Horizontal Faucet mount filter (which is the same as I have, it sez model # FM 9400 or FM 9500 on the bottom side of the pseudo chrome plated filter barrel in such "extremely small black type" that is hard to read against the chrome background no matter how hard you squint) take a thin rubber "jelly jar cover remover", they're about a scant sixteenth of an inch thick and about six to seven inches in diameter, mine is yellow and looks like a small sunflower shape. Take it, drape it over the front 'business' end of the faucet unit, kinda center it, then (it should be dry also) treat it like a stuck jelly jar cover and wrap your hand around the face part, squeeze and turn to slowly start the unscrewing process of the filter cover face. You need to get a good starting, firm grip on the spherical shaped removable front piece. There's a small depression near the bottom of the face that also helps when you get finger pressure combined with the jelly jar lid remover. It takes firm constant turning gripping pressure to start the part to unscrew. Once started it gets real easy and the whold face part spins off. Set it aside, pull out the old filter, put in the new, screw the cover back on. The depression part ends up at the bottom and the LED light portion at the top. Run the water through the filter for 5 minutes and you're back in business. Now, if someone can tell me how to stop the bloody thing from leaking all over hell after you've replaced your third and fourth filter that would solve my current problem. Good Luck! Steven S.
Posted on Nov 30, 2008
Hello to Harveycm7
EUREKA! it WORKS! i have been struggling with replacing these filter cartridges for years. The rubber grip mentioned by sschwengel helps. I tried using a strap wrench, but it slips right off the rounded face. I would add to your helpful solution: be careful not to crack the faucet fitting / hold the body of the filter firmly as you turn the removable front face of the filter to remove it (i used a small flat blade screwdriver) THANK YOU!
Posted on Jul 24, 2009
Problems installing water filtration replacement filter GE gxulqr
After you shut the water off, unscrew the canister, remove old filter and check it against new filter. (They should be the same) check fo arrows (if there are any point in upward position) insert and screw canister back on, fasten securely, turn water back on.
Jun 27, 2014 | GE SmartWater GXULQR Replacement Water...
Unable to remove back panel
There are two Philip screws located on the edges of the back. Remove them this will allow the back to be taken off. Then remove the two screws at the top bracket that holds the filter in place..Ypu can remove the filter and bracket No need to remove any more of the screws on the back . From there you will see the plates and another filter. You can get at them by removing the two screws on the left and right of the plates..You can take the plates and filter out for cleaning and change the bulb if needed....NOTE; the filter on the back is resting on a activation switch just make sure when replacing the filter and bracket is pushed down to activate or the machine will not work..good luck....
Mar 24, 2014 | Ecoquest Fresh Air Air Purifier
There are 2 holes on underside of filter housing & when turn on filter water , out both holes, why I hate running it as you don't know if you are getting filtered water from both holes.Help
The main problems I'm seeing on these posts for this filter are design and operater issues. 1. I never run hot water through the unit in filter mode. 2. I never run cold water through the filter turned on high (pressure issues arise), it doesn't filter the water any faster. You just want enough flow to run through the filter. 3. The steel sleeve was a good solution (again pressure) but came up alittle short (ie my epoxy fix). 4. The light is powered by a chip batterey that is unreplaceable and may be bad. Try reinstalling the cartridge. I personally pay no attention to the lights other than a clue. I change my filter when the taste changes or there becomes a flow issue. 5.There are filter screens prior the filter that can become clogged if you live in a poor water area. 6. The filtered water only comes out of the spigot and no other leaks (something loose or pressure issue).
Sep 30, 2013 | PUR (FM-9500) Air Purifier
Chemcial taste in water after changing water filter
Well this never happens with me but surely you might get some unusual result.
Chlorinated Solvents Exporters
Sep 12, 2012 | Whirlpool Gold GSS26C4XXB 26.4 cu. ft....
I need a filter for Amcor Ficus Tree Air purifier
If the activated charcoal filter, take your old one apart and trim down a larger on from a competitve machine to fit yours. The same if it is a HEPA filter you want to change as well.
Otherwise metal and plastic filters can be washed. Spray with a grease cutter like 409, which will also lightly etch the metal without reacting with the plastic.
Jan 31, 2012 | Amcor Ficus Tree Air Purifier & Ionizer...
Which glue to reattach chromed plastic to plastic?
Use old fashioned model cement. Not the child safe type. The old type will melt the styrene to the styrene. The new stuff only fills the gap but never really makes a good bond.
Mar 10, 2009 | PUR (FM-9500) Air Purifier
Red led light on constantly
electronic circuit needs replacement
Feb 01, 2009 | PUR (FM-9500) Air Purifier
Water Filter Leaks
Since you weren't very specific where it leaks or when it started (like after a filter change) it could be tough to troubleshoot this leak.
If it is leaking at the faucet connection try tightening up where it screws onto the faucet. Depending on your strength (or lack of) you may need to use pliers to get a tight connection. Don't go crazy tight or it will crack the plastic fitting. If it still leaks remove the unit from the faucet and check the rubber washer inside where it screws onto the faucet. Make sure it's still there and is centered inside the cup and seated properly. Then reattach the unit to the faucet and tighten it well.
If it's leaking from the main body try removing the filter and reinstalling it making sure you have seated the filter properly and screwed on the cover correctly, and all the way. When it is tight the water outlet will be exactly at the bottom of the unit. Sometimes it's tricky getting it tight enough especially with wet hands.
Finally, if the leak is coming from the filter on/off selector this could be tough to fix. I would try firmly pushing and pulling the selector knob in and out several times while in both the on and off positions. This may re-seat the leaking seal. I wouldn't be too hopeful about this fix though. You may need to replace the unit if this part is leaking.
Nov 18, 2007 | PUR (FM-9500) Air Purifier
PUR (FM-9500) Air Purifier Logo
2,053 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
