What is the green light that looks like a lock with a 1 next to it?
  • 56 Answers
Posted on Mar 27, 2011
Battery not charging
Sounds like it could be two things with that, first look at the battery symbol, is it flashing orange or is it green. If its flashing orange means you have a bad battery, if its solid green all ok, if its switching between green and yellow its charging. if the symbol isn't lit at all it doesn't detect your battery and try to remove and reinsert battery. Next look at the plug light, is it green?
Dec 16, 2012 | Lenovo IdeaPad Z560 Notebook
How to remove/replace the water filter
If the light on your refrigerator is green, you don't need to change the filter. If it's red, then it's time to change it.
Next, locate the filter knob at the base of the refrigerator. Turn it 1/4 to the left and then pull out the filter. Put in the new filter, then lock it by turning th knob back to the right.
Reset the indication light inside the refrigerator by pushing it 5 times within 10 seconds. The light should then turn green again.
Feb 21, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do you put the childlock on
To turn the childlock/Control Lock on, simply press the Energy Saver Dry button for approximately 4 seconds until a green light appears next to the words Control Lock. Do the same to unlock the controls. (The green light will disappear when unlocked.) Hope this helps!!
Oct 19, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
How to set up th ebatteries in my sentry safe DSW5781?
Locksmiths agree
1. Remove and discard the screw (if
equipped) at the base of the lock case.
2. Turn the electronic lock case to the
right (clockwise), from 12 o’clock to
2 o’clock, and remove.
• Insert 4 new AA batteries (not included) to power
this lock.
• Replace the electronic lock case and turn to the
left (to 12 o’clock) to reassemble.
NOTE: The yellow LED will light when the batteries
need to be replaced.
3. Turn the key (if your safe is equipped with a key
lock) to the right so the lock cylinder pops out.
4. Enter the factory code. When the green light appears, you
have four seconds to turn the handle down to
open. Try this several times before proceeding to
the next step.
To unlock safe:
Enter the 5-digit factory code, a pre-programmed
user code, or a pre-programmed user pin
programming instructions. When the
green LED lights you have 4 seconds to turn the
handle and open the safe.
To lock safe:
Close the door and return the handle to the
horizontal position. For greatest security, depress
the key lock (if equipped) with your finger.
Aug 15, 2010 | Sentry Fireproof Safe
I have a Toshiba 4200 series and would like to know what each of the five light are for.
From the left,
1, Mains power connected
2, On (glows green when system is on)
3, Battery orange when charging green when fully charged
4, Hard Drive green when accessing
5, Floppy or CD drive activity
Light above keyboard<
1, caps lock
2, arrow mode
3, num lock
May 11, 2010 | Toshiba Satellite Pro 4270CDS PC Notebook
Top right of keyboard next 2 the green light that comes on when ian in caplocks is another green light thats on whats it 4 ty
The lights are as follows from the left... Num(ber) Lock, Cap(ital) Letter Lock, Scroll Lock.
Feb 11, 2010 | Computers & Internet
Wires pulled out of crank sensor plug yellow blue green need to know order
The yellow goes on the terminal B.Blue to terminal A AND green to terminal C.You should be able to see the letters on the connector.Good luck.
Nov 19, 2009 | 1999 Chevrolet Silverado 1500
The remote opener reset button goes off and will not work
The green button is not a reset it is the program button.
If you hold the button down for about 20 seconds it will erase all codes. Then, press and release the button - press and hold the button on your remote for about 10 seconds. the next time you press it it should activate the door. Repeat the 2nd step for all additional remotes.
The lock button on the wall control locks out all radio signals for vacations etc.
If the lock has been activated the green led in the wall control will flash - when the lock is deactivated the led stays solid green.
Hope this helps
May 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Gateway keyboard shows a lock
I'm not sure what I did that unlocked the keyboard, but I was finally able to turn off the green light. I tried rebooting and pressing all sorts of buttons, but the one that might have worked was the 'end' key.
Apr 26, 2008 | Gateway 2520915 Keyboard
Maytag washer panel show a red light that say control lock what if anything i can do to releaseit
Try the "End of Cycle" button to the right of panel front, next to Start button. Mine says hold for three seconds to lock/ unlock control.
Mar 10, 2008 | Washing Machines
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
