Question about Microwave Ovens
When we push a button for a large cup of coffee it only makes a small cup most of the time
  • Microwave Ovens Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Mar 27, 2011
My Keurig coffee maker will makes a grinding sound when the start button is pushed, the K-cup is in place, but water does not pour through into the cup.
heatman101
May 07, 2011 | Microwave Ovens
Keurig Coffeemaker says to descale. How do I do that?
Hi, unplug the coffee machine and remove the cup.
Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
Unplug the machine and dump the water into the sink.
Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Apr 28, 2011 | Microwave Ovens
The Keurig medium size cup doesn't brew at all, why? The de-scale error is still on my machine and only the large size cup works. Please advise, thank you.
heatman101
Apr 02, 2011 | Microwave Ovens
Saeco Royal Professional Espresso Machine Problem IT KEEPS GIVING ME ENERGY SAVING. WHAT DOSE THAT MEAN? I HAVE FORGOT T TURNED ON THESE MORNING. THANKS
There is a main switch on the lower left side, as well as a standby switch on the front. Make sure the main switch is on, and the press the power button on the front. It will warm up & be ready to make a cup of coffee (about 30 sec.) when you select one of the coffee (cup) buttons.
Dec 15, 2010 | Microwave Ovens
Jura E8 beans will not pass through grinder resulting in "Fill Beans" error message. Saw reference to Kaffeestudio.com for dissasembly instructions but that link no longer works. I assume that the chute...
It seems withthis model you have a 1 year or 4000 cups warranty with this.
If you are within this, then give them a call - here is the Manual if you don't have it -
MANUAL -
I suggest you start by removing the beans in the hopper and wiping around to remove oils.
Then refill with fresh dry beans.
Plug in and set up as normal
Set to brew a standard large cup - and adjust grinder to coarse setting while grinding.
Do not adjust with grinder quiet - it must be done while rotating.
Make at least 10 cups this way at the coarse setting.
I think what has happened is that damp beans (frozen or cold) have entered the unit and caused the coffee to gum up at the top of the burr.
This will just push fresh beans out of the way instead of starting to grind them.
If you use dry (light loast) beans, it doesn't seem to happen as much.
Just ake sure you refrigerate most of your stocks, but keep a small stock at room temperature in an airtight tin to prevent this kind of thing.
You can actually push down on the bean stack slightly with a wooden object while the grinder is running if nothing moves on the coarse setting to get things moving.
Feb 10, 2010 | Microwave Ovens
GE Microwave Model JVM1650
the diode is open when the voltage arive at the anode junction it locks off due to the diode is not passing the voltage,change the diode and the microwave will resume operation.good luck.
Aug 04, 2007 | GE JVM1650SH Microwave Oven
Microwave Ovens Logo
141 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
