Question about Hitachi 43UWX10B 43" Rear Projection Television
Green haze not sharp
. A green haze around objects in picture. Especially when showing white on the TV. (Like someone wearing a white shirt.) Does anyone know a solution? The green haze filters over the letter box black bars about 1/3 of the way.In convergencethe blue and green lines are not sharp. how do i fix this? please help !
  • 927 Answers
Good Day;
Sounds like your TV has a convergence problem. If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram. Or call FACTORY SERVICE;
1-800-448-2244.
Good Luck, big IRISH. PS or get from HIT Part X480293: kit.
Posted on Sep 06, 2008
I have a hitachi ultravision and the picture giggles and there seem to be a green haze around objects in the picture
you can have that adjusted and re aligned but a new LED TV is the way to go. less space and power and better picture. easy to move. sorry
Nov 16, 2014 | Hitachi Televison & Video
Remove purple haze around edges
The set needs to be focussed and reconverged. The red and blue images combined make a magenta/purple image. Adding green makes it white. Depending on the type of TV, if it's a CRT projection TV then there's an electronic focus control for each of the three tubes as well as the mechanical adjustment of the optical lenses. Given the description, then I'd have a look at the electronic focus first. A sudden shift in focus suggests that something in that circuit has given out. This would cause the red and blue images to go soft enough to create a halo around objects on screen.
Sep 12, 2014 | Televison & Video
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes. http://electronicshelponline.blogspot.com/
May 20, 2013 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
I have a sony model KP-48V90 All of the sudden the picture started ghosting and the color went green and redish haze
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
To get fixed either call in a local TV repair company or goto sites such as www.TvRepairKits.com to get a repair kit with instructions.
Oct 14, 2010 | Sony Televison & Video
My 60 inch phillips television has a red tint to it it was made in 2003
Usually this is bad fluid in the blue and green CRTs. the tell-tale sign is that the blue will just haze,
look at a guy in a black suit.. you will see the blue just hazing out around his white shirt and tie. This is common for all these philips TVs and is dirty cooling fluid in the blue and green CRTs. A repair shop will charge you about $300 for the fix, maybe less if you're lucky. You could fix yourself for about $40 and some time, but would need to have some mechanical skill and some free time on your hands. Let me know if you need further assistance.
Jun 14, 2010 | Televison & Video
Philips Magnavox Projection T.V
you need to replace a cople of the opticoupers most likely, if you want to repair this and save yourself a lot of dough, contact me at techman32k-at-yahoo dot com
Larry Dillon
Aug 06, 2009 | Televison & Video
Green Haze in middle of TV, Words not sharp
The coolant in the chambers that are part of the CRTs(picture tubes) has been contaminated by foreign matter and the high temps created by the CRTs. The coolant can be replaced but its an expensive and time consuming operation. Some of the parts needed for this repair may also be no longer available. I'd start shopping.
michtech
Feb 17, 2009 | Televison & Video
Green shadows around small red objects (football players with red shirts)
turn tv of by power point for 1 hour then switch back on that resets the picture if still happens may need a service
Jan 27, 2009 | RCA HD61LPW164 61" Rear Projection HDTV
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
210 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
