Question about LG Washing Machines
LG washing machine WF-T1031TP erra light flashing bE which i think means Abnormal ball sensor
  • Elizabeth Jeynes Aug 04, 2008
    yes it is "be" the machine is not doing anything just sounds an alarm and as mentioned the manual says abnormal ball sensor but dont know what that means . Thanks Liz
    sorry did not understand last coment ? Liz
  • 4,472 Answers
Are you positive the error is reading "bE"? Please don't reject my assistance until we work through the problem.
Thank you,
Lee
Posted on Aug 04, 2008
  • 2 more comments
  • Lee A.
    Lee A. Aug 04, 2008
    could it be "dE" also is the washer not washing then? Does it do anything?
    Thanks,
    Lee
  • Lee A.
    Lee A. Aug 04, 2008
    I believe it is flat and white with looks like two groups of wires going into it.
    there is a few of them i think so i dunno how to find which one it is. You should see it when you take off the back panel. I would make sure you know what you are doing before replacing it, always make sure its unplugged when doing things of this nature. Though it doesn't take but a few minutes to change.
    Thanks,
    Lee
  • Lee A.
    Lee A. Aug 04, 2008
    http://www.yourspares.co.uk/proddetail.a...
    It looks like you can purchase the service manual for the washer, and you can contact LG, or a local repair shop on getting the part. If you need anything else let me know. If you found this helpful I would greatly appreciate if you would accept and rate accordingly.
    Thanks,
    Lee
  • Lee A.
    Lee A. Aug 04, 2008
    I'm sorry I don't know what part you didn't understand. If you take off the back panel it is white and flat like I explained. . If you are trying to service this yourself I would get the service manual. I believe you can get it through that link, though I would contact them to make sure that it is correct.
    Thanks,
    Lee
    Genius:
  • 1,847 Answers
Light flashing means that there not sufficient water coming through the inlet.
  • Legin Varghese
    Legin Varghese Aug 04, 2008
    this flashing light will also come up if it, will not do a spin cycle. If it making racking sound then I think the bearings have gone bad.
LG Fuzzy Logic 8.5 kg washing machine WF-T855A Turbo Drum I sensor will not fully spin, stops with 2 minutes to go till end and clothes are in a ball, not spun properly,never had a problem until now??
Unplug the machine over night and then plug it back in the morning. this should reset the internal cycle back to manufacturers specs.
This problem occurs because someone may have opened the door during operations and the onboard computer recognized and remembered this, so it is now part of the standard operating proceedure.
Nov 10, 2016 | LG Washing Machines
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
WF-F7061DN washing machine water level lights flashes
Are you overloading the machine? If you run the machine without anything inside and this happens, check the motor or belt.
Jan 14, 2014 | LG Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
My washing machine model is LG WF-660.. it cannot function due to failure indicator at water level.... it keep on "beeeping" cannot do other operation.... plz help....tq...
pl check the bp sensor or the conector of the wire harness.according to my knowledge there is no door sensor in wf-660.if bp sensor is ok change the P.C.B
Feb 03, 2011 | LG Washing Machines
LG +3 turbodrum wf t851 bE error code
I have the same problem. I do not think this has a micro switch to activate the wash cycle or spin. I have looked carefully.
I have a gut feeling that this works on a sensor similar to that of a sonic car alarm. It may have gone out of sync and needs to be retuned.
I have tried to find the software but it is not commercially available.
Dec 29, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
407 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
