Started blinking and the red light blinking now and no tv screen when i turn on just blinking red power light
  • 4,889 Answers
The blinking light is a self-test diagnostic. If you can tell me how many times it blinks in between each pause and what is the make/model of the tv, I can tell you whats the source of the problem.
Posted on Mar 27, 2011
  • 5 more comments
  • simmerxp Mar 27, 2011
    I have an Insignia ns-lcd19 when plugged in the amber flashes 3-3(pattern of flashes keep changing) When powered on the led turns green ,back light flashes then power led shuts off,then amber led flashes 4-4 (pattern also changes) caps and fuses appear good . When plugged in I am getting the 5v and 12v -both drop when powered on about the time backlight comes on) and voltages recover. Any ideas?
    Touched up solder joints on x-formers and inverters now when plugged in amber light flashes then stays amber. when powered, led turns on and stays green ,back light turns on for 3 seconds off about 8-10 and cycles until power is turned off. Then amber led flashes.
  • eagle338
    eagle338 Mar 27, 2011
    Since the voltages are there when the set is off, my money would be on the short protect circuits. The 12V line is the one that goes to the backlight inverter. So my first question to you would be did you check for shorted or burnt components anything that can cause an open circuit?
  • simmerxp Mar 30, 2011
    I have checked parts on the power supply in circuit . I may have to start pulling some caps but I do not have an esr tester. It does make humming noise in the area of 6 caps , D911,D909 and D908 when the back light comes on( screen is grey when on). I don't see any visual bad parts on either board .
    P.S. is working fine now. Have 12v ,5V, 3V, and 3V.Still have flashing amber led when plugged in or shut off.When powered on the led turns green and the screen is white ,no picture but it has sound.Only 2 boards , T-con must be on main board. only 5 leaded caps on M.B. the rest are SMD . I checked some parts where the cable plugs in from the panel. did not find anything yet. Any ideas?
  • eagle338
    eagle338 Mar 31, 2011
    Well you can test the caps with an ohm-meter too. But if there's no sings of damage on the caps(such as bulging or cracking at the tops) then the caps are out of question. Here's a guide. Do not short the leads like he suggests though sometimes the caps will explode. It will be better just to touch the two contacts of a bulb on the leads of a capacitor to discharge the voltage into the bulb(which glows momentarily and turns off)
    http://reviews.ebay.com/How-to-test-a-ca...
  • simmerxp Apr 02, 2011
    T-con board on back of panel. fuse is good and have 4.1V at fuse.
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
When i go to turn on the tv the red power light turns on and then starts flashing, with an all blank tv screen. I cant get anything but a black screen. The light will flash for a lil while, then the tv...
BLINKING RED LIGHT IS ERROR CODE.
1. Unplug set for a few minutes.
2. Plug back in and turn on.
3. When red power light starts blinking--COUNT THE BLINKS.
4. THREE BLINKS, pause, THREE BLINKS (ETC) IS SHORT PROTECTION AND A DO IT YOURSELF repair for some people. I have complete instructions for this repair.
5. 5 blinks, pause and 5 blinks etc is short on 140 volt line and while not as easy as 3 blink error code it points to places to look at.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
Post a comment here when you know what error code is and I will help.
REGARDS, SD TECH
Aug 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Red blinking light when tv is turned off
You can't fix it. There is a bad board in this set; either the main board or the power supply board. You'll have to call a professional.
Mar 30, 2009 | LG 37LC7D 37 in. LCD HDTV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Nov 27, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
1,123 people viewed this question
Top Televison & Video Experts
