Dear sir me have bought philps shm3400 headphone today and using windows 7 me cannot use my mic in my speaker sir
  • Computers & ... Master
  • 27,725 Answers
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
Posted on Mar 27, 2011
A major problem of Skype! I am almost there a year now its metal / Ground Conversation / Offset! this problem even happens by calling "echo / sound test service" (My PC is HP ProBook 4510s) My...
what OS? windows, and What windows, XP?
HP sold it with 7 different OS, (xp to w7 ./32/64bit) and linux.
I cant know what you use for sound at all.
the PC has sound chip and 2 speakers and mic.,
external speakers, or sound buds, what? tell what you have first.
4510s tells little.
if you have U
SB headphones there, it WILL mess up.
USB adds a 2nd sound chip set and they clash with onboard set.
in fact buying new headphones with USB sound and boom mic built in
then going in to device manager and disabling the onboard sound
makes the head phones work real well.
its not metal bs. sorry. that is jive.
i the sound test fails, then it failing that you can be sure.
if no bud, or headphones of any kind
and only internal speaker ;.mic is used
then down load the drivers from HP for you sound
is that hard?
here
https://support.hp.com/us-en/product/HP-ProBook-4510s-Notebook-PC/3934828
Sep 02, 2017 | HP ProBook 4510s FM849UT Notebook
Intel(R) Desktop Board D945GCL,Window 7 ultimate is installed.After installing Audio Driver (Version 5.10.5208.0) Sigma High Defination Codec,in speaker properties,Jack is showing Jack information not...
Please ensure that your bios setting is enabled for audio.
1. Have you installed the correct windows 7 driver or have you configured with the vista driver?
2. If you have installed with windows 7 driver, check it for 32 bit or 64 bit and you are installed perfectly!
3. Check the windows service. Go to "run", type "services.msc" and press enter. In that opened window, direct to "windows audio". Open it and check the service is started or not. Also ensure that the startup type is set to be "automatic".
Hoping you will be short out!
Aug 19, 2011 | Intel D945GCL Motherboard
I have just set up skype on my laptop and tried using the echo /sound test. Though my mic seems to be working I do no hear anything. I have checked the sound settings and skype does play sounds through my...
If you are running Windows 7 you can have audio set up to listen to the mic. I would not recommend this though as there is a slight delay from you talking to it coming out of the headphone. This can cause you to stumble on your words. But solely for testing purposes do this if you use Windows 7:
1. RIght click on the speaker icon in the lower right corner of your display and select recording devices.
2. Make sure the microphone you use is highlighted blue then click properties button in lower right corner of the window.
3. Click on the listen tab, then check the box that says listen to this device.wdaexodus.png
Mar 05, 2011 | Cyber Acoustics AC-201 Consumer Headset
I got a problem with my mic
Good day, sir/ma'am , there are several reasons why a mic does not work, let me give some. 1. its not activated, to check if it is activated, load the sound recorder program on windows. press record and shout on the mic, wave patterns can be seen on the recorder. 2. you may activate the mic and speaker if you cant hear the voices by. opening the volume control settings, options, properties, place a check on mic volume. there are other optons as well. 3. the mic is physically damage due to open wiring. get a new one. hope this may help. thanks
Jul 16, 2009 | Radio Communications
Mic
Try a different set of headphone, if it works, then it is the headphone set.
If you get same problem with all headphones, then
If you get no sound: ensure that you have sound from speaker, if you get sound from speakers and no headphone working, then there is a problem in the headphone connection.
If you have no sound at all , not even with speakers, then check audio settings in control panel, ensure audio is not muted. If audio settings are OK, then you need to reinstall audio driver, or you have a faulty audio card.
Additionally, if it is only the mic not working then do the following:
Go to control panel and open sound and audio device.
Open volume settings and find settings for mic.
Tick off the mute option.
The mic is muted by default in Windows, that is usually the reason why it is not working.
Sep 14, 2008 | Compaq Presario 700 470024-192 Notebook
Headphone and mic
my presario c700 has a built in mic try just connecting headphones in and using the built i mic
Jul 23, 2008 | Compaq Presario 700 470024-192 Notebook
Cannot Head Mic-In Audio
You can use the mic in like a line in just have to turn the volume up on the source or use a program to amplify the data in post processing
Jun 29, 2008 | Microsoft Windows Vista Home Premium with...
Microphone and headphone problem
Usually when you double click the speaker icon in the system tray you'll see the volume settings for all your devices. On microphone there is usually an check box for mic boost. Set those to mic boost. Then check that all the sliders in the volumes are one increment below the top but maximum for Wave. Then set the master volume to a comfortable loudness This you can access by a single click to the speaker icon.
Next, you can go to Control Box, click on Sounds and check the settings for speakers/headphone and also for recording where there is usually a routine for checking the recording settings via your microphone made available to you.
Please do not hesitate to ask me for more information and kindly be specific if you can. I'm here to help and will get back to you in a reasonable period of time.
Hope this fixed your problem and thanks for using Fixya.
Regards,
Worldvet
May 26, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
