I have a Niles SW300 subwoofer that continues to blow fuses. I have replaced the fuse, but when it the power is plugged back in the fuse immediately blows.
Ok, temporary cheap fix... (i mean in a ******* engineering kinda way ;-) . . . )
since your primary receiver has a sub-out RCA plug, you can hop into the local pawn shop, buy a cheap receiver and an RCA line splitter, and connect the primary sub-out to the CD or any input EXCEPT phono (resistance is different on the phono rca's). remove the plate from the sub and run the speaker wire from the "pawn stereo" directly to the speaker. replace plate on sub to keep box sealed, and adjust receivers to desired level of bass & volume.
You have spent $50 and now have a decent sounding system again.
Posted on Oct 02, 2011
    Brigadier General:
  • 8,546 Answers
Maybe the amp has a shorted output stage or the speaker is shorted. You might disconnect one from the other and see if that makes a difference. If it blows without a speaker load you need to take it to a technician for a look-see.
Posted on Mar 27, 2011
  • David Dunn
    David Dunn Mar 27, 2011
    And if it stops blowing the fuse without the speaker, the driver is shorted. Test it with an ohmmeter or just touch a battery across the inputs. if it sparks without making any sound it's shorted. If it clicks or makes staticy sounds it's probably ok.
Why would my pw 350 subwoofer lose all it's power? There are no lights at all or sound, please help!!!
There is probably an internal fuse which you can check with the amp unplugged (unbolt the amp from the woofer, noting all gaskets.) If it's blown, it could have fatigued so just replacing it would fix it, or it may have blown because the amp or power supply failed. If that is the case, a new fuse will blow immediately. I can fix it for you if it has a blown amp or supply. Contact me at ken_more@netzero.net.
May 13, 2014 | Polk Audio Audio Players & Recorders
Schematic
Niles keeps that information proprietary, they only let dealers have it. IF you disassemble the unit to get to the main board, you can look for a blown fuse, check fuses with the meter, check the outputs from the transformer with the meter, Other than that you are going to need an audio signal generator and oscilloscope and an ESR meter.
Feb 11, 2018 | Niles PRO-15SW Subwoofer
Yamaha ns-sw300 no sound no power
The first thing id look at is the fuse you have to open this up to look at this.Look inside the fuse and see if theres a rod like thing going from end to end.If there isnt thats your problem or if you see a fog kinda thing in there or if the walls of the fuse is black like a burn would represent.Most likely this is your problem but it could be more further of a problem than i anticipate.
Mar 15, 2013 | Mackie SWA1801 Subwoofer
1501 sub will not power up. i opened, inpected and replaced power fuse 250v 6.3 amps replaced with same fuse and it blew as well immediately. what to do and how. I have some technical experience.
Isolate and look for possible shorted components.
Isolate the main power transformer from the board, and see if the
fuse still blow.
If it doesnt , then the rectifier and capacitors to the regulators.
But don't forget to check for possible shorted transistor
Sep 23, 2011 | Mackie SWA1501 Subwoofer
My SI-1230 was not working on channels 5-6 and 11-12. I opened the amp and replaced the fuses on those channels. Now the fuses blow immediately on channels 5-6 and the red protection light is on...
Chances are the main transistors or whatever powers channel 5 and 6 have shorted out. Fuses blow like this when there is an overload and these power types do that a lot. If it uses transistors, then a ohm meter will show them up quick. Because it will be just like you have touched the test probes together when you put them on the terminals, with the meter on the 1K setting. For the reason these parts are just acting like pieces of wire instead of doing their job.
Mar 12, 2011 | Niles SI-1230 12-Channel Amplifier
Powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Jan 15, 2010 | Onkyo Bass Reflex Powered Subwoofer...
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
Polk Audio PSW202
The power supply or amplifier has a shorted component.
Nov 08, 2008 | Polk Audio PSW250 Subwoofer
AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
Well, so far so good. I reinstalled the newly repaired amp and fired it up and so far, so good. Ran it through about an hour of fairly intense break-in tracks and then ran it through about 2 dozen power up and down cycles to try to get it to fail (better now than a month from now and have to fight them on backing it up).
Jun 01, 2008 | Acoustic Research AR1 Speaker
302 people viewed this question
 Grubhead
Grubhead
