Question about Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive
Hi, my computer(s) are not picking up my 4Gb usb. Shouldn't it automatically "plug and play"?
  • 56 Answers
Yes it should. Install the most recent operating system updates and reboot. Check that your USB drive works on another computer to be sure the drive itself isn't broken.
Posted on Mar 27, 2011
I have an 4gb mini drive but i do not how to use it can you explain?, thanks if you do
Just plug it into the usb of your computer wait for it to install automatically by windows one its finished your done. Just drag and drop or copy any files to from your computer to your flash drive. Don't forget to click "remove safely usb device" on your task bar once your done for safety precautions.
Good day.
Jun 19, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
My computer cant recognize SanDisk sansa clip+ 4GB, where can i download drivers???
There are no particular drivers for any USB devices . They are all Plug and Play devices and will be automatically detected unless faulty or if you are using an older version of Windows ( 98 / 95 etc.).
XP /Vista / 7 will detect your device automatically. Try it on some other USB port on the back of the computer instead of the front ( where usually people tend to connect portable devices ) if its a desktop PC.
Apr 29, 2011 | SanDisk Sansa Clip MP3 Player
Your new hardware might not work properly error will appears
This error message comes up when you plugged in your USB Flash drive into a lower version of a USB port. Try using another port in your machine, ports that are USB 2.0 compatible and you shouldn't see this error again.
By the way, there are old motherboards which does not have ports for USB 2.0. You might want to check your motherboard user guide and see which ports runs at 2.0. If there is none, I'm afraid that the only way around it is to upgrade into a better motherboard.
Hope this help.
Apr 27, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sir good after. I have 4GB transcend 2.0 pendrive while copy some thing to penrive this drive a message is comming like " this disk can not be written to bacause it is trite protected please remove...
Go start menu then click run and type regedit then ok.
HKEY_LOCAL_MACHINES/SYSTEMS/current control set/control/storage device policies.
note:if storage device policies key does not exist then download add.bat file and double click it. After double click it is added automatically to registry.
Double click the write protect in the right pane and set the value to 0 in the value data box and press ok button.
restart your computer and again reconnect the pen drive on your computer.
Mar 20, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
COMPUTER IS STATING THAT "THE
Sounds like it shorted out when you plugged it in the first time. I would return it and get a replacement. There is nothing you can do to fix it if this is the case.
Nov 03, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Need driver for pny 4Gb Pendrive. It is saying Please insert disk when i try to open my pendrive. it is displaying in Devise manager.
Normally most of the pen drive are plug and play means the hardware is recognised automatically by windows.
Try the following steps below:
>start
>setting
>control panel
>administrative tools
>computer management
>in left column click disk management
>then you can perform format according to your choice.
ok try this and let me know
Any other help, you are most welcome
Regards
Uttam
Jan 26, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
4gb kinston pandrive
you need to up date all your drivers. and it will detect it. its plug and play.
Jan 19, 2010 | Kingston 4GB Secure Digital High Capacity...
My system asks for installation of my 4GB DT120?
RESTART THE SYSTEM AND PLUG IN THE PEN DRIVE IT WILL WORKS.WHY IT ASK THAT YOU SHOULD INSTALL YOUR 4GB DT120
Sep 25, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to use flash drive
Cruzer Micro is an USB external memory where you can store files.
It is automatically detected and installed on all Windows OS from Windows 2000 onward, same on Mac OS and recent Linux versions.
All you have to do is plugging the device into USB.
After the flash drive had been automatically installed , it will be displayed under Computer as an external disk.
You can copy and transfer files using Cut, Copy and Paste functions, or Send to function in windows, or the file manager, depending on the OS used.
In Windows, before unplugging the memory from USB , it is better to turn off the computer or use the 'safely remove USB' function located near to the clock, on the lower right hand corner.
Read also the documents below:
Introducing the Cruzer Micro
Find Answers || BeCompliant Corporation
How to Use Sandisk Cruzer Flash Drive
May 15, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I don't know how to save to the kingston 4GB USB2.0 data travelter - no instructions with it
You just plug it into a USB port and your computer will automatically detect it.
Please rate this solution and thanks for using FixYa
Jan 06, 2009 | Computers & Internet
Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive Logo
384 people viewed this question
Top Dane-Elec Computers & Internet Experts
Steve
woodzowl307
pankaj rautela
pankaj rautela
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
