Question about Kenwood Car Audio & Video
My kenwood car stereo model no. KDVMP5343U is showing protect while switching on
    Scholar:
  • 116 Answers
PROTECT (Blink): The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT" code does not disappear, consult your nearest service center.
Good luck with it
Posted on Mar 27, 2011
Testimonial: "jgoufoufougpiftudiy"
  • kudaafer Apr 04, 2011
    how do i kno what cable is it. front o rear speakers?
  • Dave Maddison
    Dave Maddison Apr 05, 2011
    Without being at the vehicle I personally would unplug/disconnect ALL speakers from the unit end.
    Re insert each speaker one at a time and test unit as you go. If one speaker is reconnected and "Protect" shows again, that is the speaker you have a problem with.
    Hope this helps but it is the simplest way to explain and fault find without the correct equipment.
    Hope that helps a little more?
How do i take my Kenwood car stereo out of protect mode ?
There may be an internal short which will have to be repaired before the radio can be used.
May 25, 2016 | Kenwood Car Audio & Video
Kenwood car stereo is displaying Protect and wont come on
If ur kenwood stereo is going into protect mode, it is because one of ur speaker wires is shorting out. Make sure all of ur speaker wire connections are good, and then wrap them so they aren't grounding out against the chassis. This should solve ur problem.
Oct 09, 2011 | Kenwood Excelon DDX-7015 Double Din Car...
check all your speakers and speaker wires for shorts or bare spots. if they check out you may have a bad amplifier ic in the deck.
Aug 17, 2010 | Kenwood Car Audio & Video
I have a Kenwood car stereo model # KDC-MP342U. Protect mode has been activated on it. I found I had a frayed wire on a speaker from window movement and have replaced the wire. When I reset the radio and...
hold down preset 3 & 6 + reset
press preset 1 - shows dc err
press preset 1 - shows dc ok
press preset 2 - shows dc 2-4
press preset 2 - shows dc 2-0
then unit should be ok with eeprom reset
Jul 18, 2010 | Kenwood KDC-MP342U Car CD Player
MY KENWOOD CAR CD PLAYER IS SAYING PROTECT??
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
Thanks,
Dec 09, 2009 | Kenwood KDC-319 CD Player
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
May 25, 2009 | Kenwood Car Audio & Video
"PROTECT" is displayed on the car stereo when turned on
This is really easy to fix. Look on the face plate for a REALLY small hole. Put the tip of a pen in the hole and it should work. This usually means the stereo isn't wired properly so if the PROTECT keeps coming on after you've re-set it, take it to a dealer. To make sure you're everything is in properly. Hope this helps...
Jan 26, 2009 | Kenwood KDC-MP228 CD Player
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Car Audio & Video Logo
1,054 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
