Question about Sony PlayStation Portable (PSP) Console
My psp is stuck on saved data utility i can hear the dics spinning but the umd does not come on
  • 3 Answers
SOURCE: PSP
ive had the same problem with my psp and i recently called to find out that its the lens inside the reader that has "98-ish%" to fail. they said i could send it in and theyd fix it. so about 2 weeks after i get it back it fails agian. sent it back in and they gave me a new.
Posted on Sep 18, 2006
  • 8 Answers
SOURCE: UMD Icon Not Showing Up Under "Games" in menu
You've cleaned the disks but have you cleaned the laser? That'd be the next step before looking @ repair options.
Posted on Sep 05, 2007
  • 916 Answers
SOURCE: PSP Not Loading Games
You most likely need to clean the lens. Local game stores have kits that clean it for you.
Posted on May 28, 2009
  • 105 Answers
SOURCE: My psp won't load umd's and all i hear is a scrathing sound
The UMD laser might be dirty or broken. Open up the UMD drive and give the laser a clean with a lint-free cloth. Then pop the disk back in and try again. If that doesn't work, you will need to get the PSP repaired or buy a replacement laser and do it yourself.
Posted on Jul 14, 2009
  • 64 Answers
SOURCE: i have a psp with software 6.20 i add software
that is a (your firmware is a official firmeware)you cannot run any software like umd dumper you shoud have custom firmware if you want custom firmware if you a fat or slim and light psp you aree in luck you can make or buy a pandora kit and downgrade from any firmware if you are using psp go u cannot have psp custom firmware although the dark alex(creator of m33)is finding a way to make custom firmware in psp go and if you have psp slim and brite you cannot make the custom firmware yourself you may consider giving it to a game store for custom firmware thanks rate 4 thumbs i helped you naa
Posted on Dec 27, 2009
Hey there i bright a psp and its not reading the games wat can cause that???
Hello
Switch on on your PSP and remove the UMD that might be inside
When you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red (do not stare directly at the laser)
Inspect to see If the Motor is spinning or not.is it moving slightly?
Take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser,check the cables to the PSP and see if there is a bad connection.
If both are running well then put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be too much pressure for the disc to spin freely
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky do the fpllowing;
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing.
try and scrape the gears themselves to make sure there is no gunk or debris in the gear..
After this try and see if it is reading UMD again.
If none of this is working, it is time to open your PSP unit
If you are able to find out what's wrong from the troubleshooting steps above you can replace the problem by
Replacing the UMD, Assembly,Replacing UMD Disc Motor,Replacing UMD Laser Motor or by Replacing PSP Motherboard
Dec 15, 2010 | Sony Video Game Consoles & Games
My problem is my umd disc is not working in the psp.
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
Dec 03, 2010 | Sony PlayStation Portable (PSP) Console
When I insert a new UMD i get the game could not be started. 80020148. The UMD is recognised and the thumbnail appears on the menu, but the game will not start. Please help.
Solution: 1) You must first backup ur data on your memory stick to your PC. Mainly the saved games data. ( directory is PSP\SAVEDATA) 2) Format the memory stick using the PSP format tool in system settings...not your PC. 3) In System Setting UNCHECK or UNSELECT "UMD Cache" this must be off!!!! 4) Connect your psp via USB cable 5) Copy your game saves / data back to your psp remember >> PSP\SAVEDATA . 6) Do a hard reboot of your psp ie hold the power switch for 3 seconds and it will reboot. 7) Your UMD games should now work with no probs.
Nov 25, 2010 | Video Game Consoles & Games
My psp2006 ver5.03 cant read games
PSP UMD Repair: Not reading UMD discs
All photos and content copyright © Llamma Corp. 2002-2006
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
Jul 16, 2009 | Sony Video Game Consoles & Games
Cannot load umd games
If you have custom firmware, make sure your "execute boot.bin" and "plain modules" are both disabled under your advanced configuration settings of the recovery menu. Also, make sure your ISO/CSO games are saved in the ISO Folder of your memory stick and that your UMD MODE is set to NO UMD REQUIRED. Your PBP Games should be saved in your PSP/GAME Folder.
Jul 06, 2009 | Sony PlayStation Portable (PSP) Console
When i put games in my sons sony psp it doesnt read them
You should reformat the psp memory stick if the game is copied, but for the UMD, for M33 versions firmware, you press Select on your psp and select UMD instead of memory stick. You should press the select on other parts of your selections on your psp. Do not press other things such as saved data utility, etc.
Mar 14, 2009 | Sony PlayStation Portable (PSP) Console
Sony portable psp says the game could not be started (80020321)
On all games or just one?
Sounds Like Bad UMD drive. not uncommon.
Feb 27, 2009 | Sony PSP PlayStation Portable Headphone...
UMD on PSP Slim will not spin
No idea, if its not spinning u definitely need to buy a new Laser Assembly. Sry!
Nov 13, 2008 | Sony PlayStation Portable (PSP) Slim...
It won`t read my game
First we will do some trouble shooting with what might be wrong with your PSP unit. About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
if you need more infomation please just ask ... Symo02
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
Help!
You might have PSP stop reading UMD discs, First you will do some trouble shooting with what might be wrong with your PSP unit.
first is the Disc Spinning motor. This will not let The disc in the UMD spin. On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
2nd is something stuck in the UMD gear, try to clean the gear of arm of dust, plastic, soda, and even hair.
and at the last is the actual laser itself. It will not focus the laser to read the UMD disc.
Hopefully this help, Pls post back should you need additional information...!
Jun 01, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
106 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
